I seem to be having quite a problem with baggage files in
RH6. I did not have any problems with baggage files in RH X5 at
all. This particular project I am discussing was converted from X5
and is about 250 pages. These are some of the issues I have
encountered:
1. Baggage files have an X through them and are tagged as
missing when in reality, they are there. I've read some of the
posts on that issue and have to say, I have encountered some of the
same iproblems. I renamed the file, attached the new file where it
was supposed to be and the new file works fine. If I then try to
delete the old file that RH could not ....no luck.
2. When I add baggage files to my projects, compile, and then
try to view the baggage files from View Primary Layout, they will
not open. I have to actually go to the Help folder and open the
start page from there. Then the baggage files open in the right
pane of the Help window. This is a real pain.
3. Although the baggage files open, now I seem to be having a
problem with those. For example, I created several Excel
spreadsheets with about 6-8 tabs each. I added each file as a
baggage file, added a TOC page for each, and linked each TOC page
to the appropriate spreadsheet. When the first TOC page (linked to
a baggage file) is clicked on in the Help TOC, the spreadsheet
opens in the right panel of the Help window and looks great. I
click on each of the tabs and they display fine. Now, when I click
the next TOC page, each time I click on a tab in the displayed
Excel file - the tab disappears. The same thing happens for each
Excel file after that. I have to close the Help system and open it
again to start all over again.
I don't know if this is an Excel problem or a RoboHelp
problem. I would really appreciate any assistance you might have on
this. I am sure our clients are not going to like this at all. We
have tried it on several different computers and it does the same
thing.
Mary
