Show 1 reply
1. Re: Tabbed Panel Widget
Willam van Weelden Sep 22, 2014 7:12 AM (in response to cgwhitehead83)This is probably due to the CSS of the layout you are using. The WYSIWYG does't work very well. Really, forget about the WYSIWYG if you want to change layouts.
The easiest way to do this is to create a new Screen Layout page and don't assign a CSS to it. Then insert the tabbed panel widget. You can then use the buttons to add a new panel. Copy the HTML of the panel and paste it in the HTML of the target layout.
Kind regards,
Willam
