Show 5 replies
1. Re: Can I use the redemption code for more than one machine for Photoshop Elements?
David__B Sep 22, 2014 5:16 PM (in response to stover)Hi Stover,
Typically you use the redemption code to retrieve your serial number for Elements products. The licensing for Elements allows the owner to install on two of their computers.
See these for reference:
How many computers can I install Photoshop Elements on?
Hope that helps,
- Dave
2. Re: Can I use the redemption code for more than one machine for Photoshop Elements?
Barbara B. Sep 22, 2014 5:17 PM (in response to stover)You use the redemption code only once, to get a serial number. But you can use that serial number on two machines at a time.
3. Re: Can I use the redemption code for more than one machine for Photoshop Elements?
stover Sep 22, 2014 5:42 PM (in response to Barbara B.)After I put in the redemption code it say Oops Oops! This code has already been redeemed using a different Adobe ID.
4. Re: Can I use the redemption code for more than one machine for Photoshop Elements?
stover Sep 22, 2014 5:44 PM (in response to David__B)After I put in the redemption code it say Oops Oops! This code has already been redeemed using a different Adobe ID.
5. Re: Can I use the redemption code for more than one machine for Photoshop Elements?
Barbara B. Sep 22, 2014 7:22 PM (in response to stover)Well, have you used it before? If not you'll need to contact adobe to get it straightened out:
