Locked
1
Flash not pulling updates from internal server
Guest
Jul 09, 2014 Jul 09, 2014
Hi
About two years, I configured an internal server to distribute Flash updates to Windows endpoints. This has been working well, until it appears, this May.  My endpoints are therefore stuck on 13.0.0.214. So something has changed
Checks I've made:
1. Update script on the server still pulls files. Destination folder shows v14 has been downloaded
Pulling the version.xml from the internal update server (over https) confirms this.
For info:
<version>
<ActiveX major="14" minor="0" buildMajor="0" buildMinor="145"/>
<Plugin major="14" minor="0" buildMajor="0" buildMinor="145"/>
<MacPlugin major="14" minor="0" buildMajor="0" buildMinor="145"/>
<SAUConfig checkFrequency="1"/>
</version>
2. CNAME "flashupdate" is still in DNS
3. Domain wildcard cert is valid and bound to HTTPS such that I get no cert warnings when browsing to the internal update server https://flashupdate.domain.local (IIS 7)
On an endpoint, here is a sample flashinstall.log (can't find what the error codes mean!) for about the last 30 mins. I've been using FlashPlayerUpdateService.exe to kick it off manually.
2014-7-9+14-45-44.830 [info] 1628 flashupdate.domain.local
2014-7-9+14-45-44.830 [info] 1629 flashupdate.domain.local
2014-7-9+14-45-44.831 [info] 1614
2014-7-9+14-45-44.831 [info] 1616
2014-7-9+14-45-44.832 [info] 1618
2014-7-9+14-45-44.835 [info] 1608
2014-7-9+14-45-44.835 [info] 1612
2014-7-9+14-45-44.837 [info] 1620
2014-7-9+15-18-0.225 [info] 1628 flashupdate.domain.local
2014-7-9+15-18-0.236 [info] 1629 flashupdate.domain.local
2014-7-9+15-18-0.238 [info] 1614
2014-7-9+15-18-0.239 [info] 1615
2014-7-9+15-18-0.240 [info] 1618
2014-7-9+15-18-0.242 [info] 1619 1063
2014-7-9+15-18-0.282 [info] 1628 flashupdate.domain.local
2014-7-9+15-18-0.283 [info] 1629 flashupdate.domain.local
2014-7-9+15-18-0.283 [info] 1614
2014-7-9+15-18-0.284 [info] 1615
2014-7-9+15-18-0.284 [info] 1618
2014-7-9+15-18-0.287 [info] 1608
2014-7-9+15-18-0.288 [info] 1612
2014-7-9+15-18-0.289 [info] 1620
2014-7-9+15-18-0.289 [info] 1604
Here's an LS output on the endpoint for C:\Windows\SysWOW64\Macromed\Flash showing that nothing is changing
total 43871
-r--r--r--   1 user     group    16435888 May 15 12:18 Flash32_13_0_0_214.ocx
-rw-rw-rw-   1 user     group     4609272 Jul  9 16:18 FlashInstall.log
-rwxrwxrwx   1 user     group     1863856 May 15 13:18 FlashPlayerPlugin_13_0_0_214.exe
-rwxrwxrwx   1 user     group      257712 May 15 13:18 FlashPlayerUpdateService.exe
-rw-rw-rw-   1 user     group      511152 May 15 12:18 FlashUtil32_13_0_0_214_ActiveX.dll
-rwxrwxrwx   1 user     group      847536 May 15 12:18 FlashUtil32_13_0_0_214_ActiveX.exe
-rwxrwxrwx   1 user     group      847536 May 15 13:18 FlashUtil32_13_0_0_214_Plugin.exe
-rw-rw-rw-   1 user     group    16361136 May 15 13:18 NPSWF32_13_0_0_214.dll
-rw-rw-rw-   1 user     group     1583299 May 15 12:18 activex.vch
-rw-rw-rw-   1 user     group         856 May 15 13:18 flashplayer.xpt
-rw-rw-rw-   1 user     group           0 Jul  9 16:25 ls.txt
-rw-rw-rw-   1 user     group         135 Jul  9 15:52 mms.cfg
-rw-rw-rw-   1 user     group     1598803 May 15 13:18 plugin.vch
The mms.cfg looks like:
AutoUpdateDisable=0
SilentAutoUpdateEnable=1
SilentAutoUpdateServerDomain=flashupdate.domain.local
SilentAutoUpdateVerboseLogging=1
I know that
1. the internal update server is able to contact Adobe and download updates (I've used wget in verbose mode to verify the output).
2. On the endpoint, I manually browse and download the updated v14 files without issue, so web-hosting permissions and config appears ok
3. The endpoint update for some reason steadfastly refuses to pull the updated files. The clue therefore appears to be in the mysterious error codes?
So I'm stuck - please help!
997
Adobe Employee , Jul 10, 2014 Jul 10, 2014
Hello,
I'm glad this is working for you now.
The install log file you posted doesn't contain any errors, just informational codes that indicate proper functionality of the background update functionality.
To clarify one of your points, the internal update server does not communicate with the Adobe servers to download the update package.  As the Administrator, you or someone else, would need to download the update package (fp_background_update.cab) and post the files (in the structure provided) to y
Guest
Hi, just to date. I've found that the V14 deployment guide has slightly changed and there are now 14 files to pull. I've download the latest Background Update package from http://download.macromedia.com/pub/flashplayer/current/licensing/win/fp_background_update.cab and extracted to the correct location as per procedure.
However flashinstall.log is unchanged.
Guest
I reported the above to Support this morning over the phone. This afternoon, mysteriously, endpoints have started to pull down the V14 update.  That's a bit odd!
Adobe Employee ,
Hello,
To clarify one of your points, the internal update server does not communicate with the Adobe servers to download the update package.  As the Administrator, you or someone else, would need to download the update package (fp_background_update.cab) and post the files (in the structure provided) to your internal server.  This is a manual process unless you automate it.  Once the files are posted to your server, it can take up to an hour for the updates to start showing up on your users machines (of course, depending how your environment is set up, you may been to clear your server's cache in order for the new files to be downloaded).
Maria
Sep 22, 2014 Sep 22, 2014
I am having a similar issue today trying to update to version 15.0.0.152. My log looks the same however I do notice in my log I have the following:
2014-9-22+10-41-0.265 [info] 1631 /pub/flashplayer/update/current/sau//currentmajor.xml
2014-9-22+10-41-0.345 [info] 1630 /pub/flashplayer/update/current/sau/14/xml/version.xml
I am thinking my client still thinks we are on 14 and that is why I haven't gotten the update? I replaced the files in the SAU folder and still haven't had any luck.
Following the above my log shows this
2014-9-22+10-41-0.345 [warning] 1411
2014-9-22+10-41-0.345 [warning] 1409
Then the following repeats over and over:
2014-9-22+10-41-0.345 [info] 1612
2014-9-22+10-41-0.345 [info] 1620
2014-9-22+11-41-0.235 [info] 1628 wsus.domain.com
2014-9-22+11-41-0.235 [info] 1629 wsus.domain.com
2014-9-22+11-41-0.245 [info] 1614
2014-9-22+11-41-0.245 [info] 1615
2014-9-22+11-41-0.245 [info] 1618
2014-9-22+11-41-0.245 [info] 1619 1063
2014-9-22+11-41-0.285 [info] 1628 wsus.domain.com
2014-9-22+11-41-0.285 [info] 1629 wsus.domain.com
2014-9-22+11-41-0.285 [info] 1614
2014-9-22+11-41-0.285 [info] 1615
2014-9-22+11-41-0.285 [info] 1618
2014-9-22+11-41-0.285 [info] 1604
2014-9-22+11-41-0.285 [info] 1608
Any help you can give would be much appreciated.
Adobe Employee ,
Hello,
Please paste a screenshot of the sau directory on your local server and post the currentmajor.xml and version.xml files using the instructions here, How to share a document.  Please do not copy and paste the files.
Maria
do I need a version.xml in the SAU folder as well?
Currentmajor.xml contains the following..
<version>
<Player major="15" majorBeta="15"/>
</version>
I downloaded the CAB file from the website extracted it and that is what I got. Copied the files out to the server under SAU and no luck..
Adobe Employee ,
The version.xml file is saved inside the xml directory in each of the /11, /14, and /15 sub-directories, and Flash Player knows which directory to go to based on the version currently installed.  Please post (How to share a document) the /pub/flashplayer/update/current/sau/14/xml/version.xml file and the entire FlashInstall.log file.  Please don't copy the contents into the response.  Also, which version of 14 is currently installed on the system?
You may also need to delete the following two registry entries, as they may be interfering with your testing:
  • On a 32-bit OS, delete:
    • HKEY_LOCAL_MACHINE\SOFTWARE\Macromedia\FlashPlayer\LastUpdateCheck\
    • HKEY_LOCAL_MACHINE\SOFTWARE\Macromedia\FlashPlayer\UpdateAttempts\
  • On a 64-bit OS, also delete:
    • HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Macromedia\FlashPlayer\LastUpdateCheck
    • HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Macromedia\FlashPlayer\UpdateAttempts
Sep 23, 2014 Sep 23, 2014
I think I must have had a bad version.xml file in the 14 folder all the sudden my updates started to work.
Adobe Employee ,
I'm glad it's working now.  The best thing to do is to replace all of the files on your server with the new files in the fp_background_udpate.cab file when we release an update.  This will ensure the files are what the player expects them to be.
Maria
Oct 24, 2014 Oct 24, 2014
@TechSupportGuy,
What did you do to determine the version.xml was corrupt/bad? I am having the exact same issues you've described.
