1. Re: RoboHelp 10, HHC4006: Warning: The file "xxxx.gif" is already listed in the [FILES] section of the project file.
Captiv8r Sep 23, 2014 2:55 PM (in response to eyesave)Hi there
This is likely just an innocuous warning that the files are listed as Baggage or something. If you add a file as Baggage and it exists in a topic, it really doesn't hurt anything.
If the warnings bother you, you might want to perform a quick double-check of your baggage and see if they are listed there.
Cheers... Rick
2. Re: RoboHelp 10, HHC4006: Warning: The file "xxxx.gif" is already listed in the [FILES] section of the project file.
eyesave Sep 23, 2014 3:58 PM (in response to Captiv8r)Hi Rick,
I took a leap of faith and removed the problem xxx.gif from the baggage files... Clean run!
I still need to do a little more research/education regarding Baggage Files.
Thanks again!
jean
3. Re: RoboHelp 10, HHC4006: Warning: The file "xxxx.gif" is already listed in the [FILES] section of the project file.
Captiv8r Sep 23, 2014 4:32 PM (in response to eyesave)Think of Baggage files as a simple way to include content that the help system may not be aware of. Imagine going on a trip with a child. Perhaps you are traveling to the beach. The child may need a large umbrella to keep shaded. You know this, but the child doesn't. So you toss a big umbrella in the trunk of the car. When you get to the beach, you now have access to the umbrella because it is in the trunk. The same holds true for RoboHelp and Baggage.
Cheers... Rick
