I am using RH 10 file in RH 11 by upgrading it. But search functionality is not working for pages created in RH 11, search functionality is fine with pages created in RH 10. I am using multiscreen html 5 output in IE 8 and safari (Mac). Please let me know
Message was edited by Peter Grainge Title put into body of question and body used as title.
IE8 is not supported on the HTML5 outputs, so no surprise there.
Precisely how do you use the RH10 files? Upgraded a project? Are you sure the pages are in the output, not exluded with tags? Also, do the new pages have the 'Exclude from search' option enabled in the topic properties?
Kind regards,
Willam
Hi William,
Even after upgrading the IE from 8 to 9, issue exists.
I upgraded RH 10 file in RH 11 and then started making changes. The pages appear in TOC, and never checked the 'Exclude from the search' box, and never checked 'exclude unreferrenced....' , right now also they are unchecked. still the issue.
Even in sample projects the search dont work.
If it was browser issue before upgrading IE, then why didnt work atleast in Safari, as RH 11 supports safari.
Please let me know solution for this,i need this urgently.
It doesn't seem to be a setting in that case. Does the search work if you use one of the sample projects? Also, if you create a new, blank project and add one or two topics. Does the search work in the output in that scenario?
Kind regards,
Willam
No. Search doesnt even work in Sample projects. Have got salesbuilder2 and Employeecare2 project as sample. In both project it is not working.
What might be the issue??
Even after creating blank project adding two or three topics, search doesnt work.
Does search work in Firefox?
What operating system are you running Rh11 on?
Do you have the patches applied?
Are you generating the output to the same drive as where Rh is installed? (Just the same drive, not to Program Files).
Dont have firefox. Not able to check in that. RH 11 installed on windows 7. Output and Rh 11 are in same drive C: because i am connecting to Windows 7 machine through Macbook Pro and windows 7 has only C drive. No other drives in it.
No Patches applied.
I think that must be the first thing then. If the patches do not solve the problem, can you not install Firefox just to test?
Tested in firefox now. Not working there also.. same issue.
and have no patches applied
But if drives are same,output should not work in IE, but atleast on firefox and safari it should work. But same issue on safari and firefox also.
what can be done regarding this?
As I said, the patches are the first thing to try.
Can you provide me the link to download patches?
And where i need to place those files?
Access them by clicking Rh's Help menu.
You need admin rights to install.
Under Robohelp HTML - Help, have below options
Contents&index
Project Manger
Adobe web site
Adobe user forms
Online support
About ROBOhelp HTML
Improvement program.
From which of these options?
Something is wrong there. I have just checked both Rh10 and Rh11 and both have an Updates option. Also Project Manager has never appeared there to the best of my knowledge.
Hover over the menu to see if it reveals further options or right click a blank area of the toolbar and click Customise. Then click the Options tab and Show Full Menus.
Do you have admin rights on the PC?
You meant On Project Manager that accesses help on that when a topic is opened.
Yes i have admin rights..
Got Updates Option from Help Menu.
I do get 2nd option in help menu as 'On Project Manager' / 'On Topic'/ 'On TOC' dependeing upon the cursor point. If cursor on project Manger and then click on help menu, i do get 2nd option in help menu as 'On Project Manager' and same for TOC and topic.
I had thought you were seeing Project Manager, then I realised what you meant and added another post.
Let us know if it all works after applying the updates and regenerating the help.
Ok sure. Thanks for the suggestion. will try applying patches.
Hi Team,
Please let me know from where i can patches for above issue for RH 11.
As suggested by william from updates option(Help menu) we can get, but i am connecting to windows 7 machine through macbook pro and in that machine we have RH 11.This machine is can't be connected to internet to download updates.
So please suggest me the link from where can i get updates files.
Please let me know asap.
Reena
sorry, suggested by peter*
Adobe - Support : RoboHelp Support Center : Service Releases
Peter, Updates option is disabled in Help menu for RH11. How can i get patches now?
