5 Replies Latest reply: Sep 25, 2014 2:03 PM by bregent RSS
    Code wont work when trying to upload image!
    Max Resnikoff Community Member
      My Code wont work when I try to upload an image to mysql. (Field in mysql is BLOB)
      <!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
      <html xmlns="http://www.w3.org/1999/xhtml">
      <head>
      <meta http-equiv="Content-Type" content="text/html; charset=utf-8" />
      <title>insert</title>
      <script src="SpryAssets/SpryValidationTextField.js" type="text/javascript"></script>
      <link href="SpryAssets/SpryValidationTextField.css" rel="stylesheet" type="text/css" />
      <?php require_once('Connections/drama_database.php'); ?>
      <?php
      if (!function_exists("GetSQLValueString")) {
      function GetSQLValueString($theValue, $theType, $theDefinedValue = "", $theNotDefinedValue = "")
        if (PHP_VERSION < 6) {
          $theValue = get_magic_quotes_gpc() ? stripslashes($theValue) : $theValue;
        $theValue = function_exists("mysql_real_escape_string") ? mysql_real_escape_string($theValue) : mysql_escape_string($theValue);
        switch ($theType) {
          case "text":
            $theValue = ($theValue != "") ? "'" . $theValue . "'" : "NULL";
            break;
          case "long":
          case "int":
            $theValue = ($theValue != "") ? intval($theValue) : "NULL";
            break;
          case "double":
            $theValue = ($theValue != "") ? doubleval($theValue) : "NULL";
            break;
          case "date":
            break;
          case "defined":
            $theValue = ($theValue != "") ? $theDefinedValue : $theNotDefinedValue;
            break;
        return $theValue;
      $editFormAction = $_SERVER['PHP_SELF'];
      if (isset($_SERVER['QUERY_STRING'])) {
        $editFormAction .= "?" . htmlentities($_SERVER['QUERY_STRING']);
      if ((isset($_POST["MM_insert"])) && ($_POST["MM_insert"] == "form1")) {
        $insertSQL = sprintf("INSERT INTO databaseimage (name, image) VALUES (%s, %s)",
                             GetSQLValueString($_POST['name'], "text"),
                             GetSQLValueString($_POST['image'], "double"));
        mysql_select_db($database_drama_database, $drama_database);
        $Result1 = mysql_query($insertSQL, $drama_database) or die(mysql_error());
      $query_image = "SELECT * FROM databaseimage";
      $image = mysql_query($query_image, $drama_database) or die(mysql_error());
      $row_image = mysql_fetch_assoc($image);
      $totalRows_image = mysql_num_rows($image);
      </head>
      <body>
      <form action="<?php echo $editFormAction; ?>" method="POST" enctype="multipart/form-data" name="form1" id="form1">
      Name:  <span id="sprytextfield1">
        <label for="name"></label>
        <input type="text" name="name" id="name" />
        <span class="textfieldRequiredMsg">A value is required.</span></span>
        <p>
          <label for="image"></label>
          <input type="file" name="image" id="image" />
        </p>
        <p>
          <input type="submit" name="Upload" id="Upload" value="Upload" />
        </p>
        <input type="hidden" name="MM_insert" value="form1" />
      </form>
      <script type="text/javascript">
      var sprytextfield1 = new Spry.Widget.ValidationTextField("sprytextfield1");
      </script>
      </body>
      </html>
      <?php
      mysql_free_result($image);
      Any help would be very much appreciated!
