Show 1 reply
1. Re: Print pdf in Windows Command Problem
Rave Oct 31, 2014 8:35 AM (in response to Phinehas1234)Hi Phinehas1234,
You can display and print a PDF file with Acrobat and Adobe Reader from the command line. These commands are unsupported, but have worked for some developers. There is no documentation for these commands other than what is listed here: http://help.adobe.com/livedocs/acrobat_sdk/10/Acrobat10_HTMLHelp/wwhelp/wwhimpl/common/htm l/wwhelp.htm?context=Acrobat10…
In command line printing approach using Acrobat/ Reader to print the PDF, the Adobe Reader can print a PDF from a command line but it has some drawbacks. The most important drawback is that the Reader does not close itself after printing the PDF.
Rave
