Hey guys!
The same is also possible in ppt 2003. You can also create
the same kinds of effects for the feedback boxes, although I
wouldn't normally recommend it because of the likelihood of having
different sized feedback text elements. If you resize the feedback
text box, you could end up with some rather funky-looking
images...even with the resizing option enabled.
As for the submit/reset buttons, you can also style the
individual components that make up the buttons...you just have to
be careful where you click. I have an example here:
http://www.robrode.com/Breeze_demos/myIdentity/.
Navigate to the third slide and hopefully you'll see that the
main "face" of the button was treated with a gradient and the
nested rectangle in the background has a different color stroke.
Couple other things to note: once you style the buttons:
1. the formatting should remain intact EVEN if you go back
and mess around with the Quiz Manager dialog box
2. the buttons you've styled can be copied/pasted from one
question slide to another. Caveat: make absolutely sure you've
deleted extra instances of the submit/reset buttons...you don't
want to leave copies hanging around! This has drastically cut down
the amount of production time to create various assets for a Breeze
course. Even with Sean's idea of using imagery for the buttons
(which not only works, but it's a great alternative to the boring
grey-on-grey scheme [kudos to you Sean!]), you'd either need to
treat each button on a slide by slide basis, or you could simply
copy/paste whereever you need the buttons.
Last note (promise!): It is also possible to create an asset
library of Breeze objects...feedback boxes, buttons, etc (we have a
deck titled BreezeLibrary.ppt). The idea here is that if you have a
presentation with these elements in it, you could also copy/paste
from your library deck into a destination ppt. We have a few for
various clients; in all cases, things like the submit/reset buttons
have already been styled according to our client's branding
guidelines.
Rob
