1. Re: Can't see how much time left for the export/rendering to finish
Mark Mapes Sep 27, 2014 4:14 PM (in response to DV2FOX)What are your export settings? In prior versions, were exporting to the very same settings?
The fact that the progress dialog shows “Pass 1 of 2” or “Pass 2 of 2” part tells me that you're exporting with Bitrate Encoding set to VBR, 2 pass. But as far as I know, when encoding to VBR/2 Pass via Direct Export (by clicking Export in the Export Settings dialog), the progress dialog has always behaved the same. Perhaps in the past you were either encoding CBR or VBR/1 Pass or you queued the jobs to Adobe Media Encoder, where the Encoding panel shows the estimated time remaining regardless of the Bitrate Encoding setting.
2. Re: Can't see how much time left for the export/rendering to finish
DV2FOX Sep 28, 2014 1:41 AM (in response to Mark Mapes)I've set the Format to H.264, then Youtube 720p HD. However,i modified the preset to 29,7FPS , progressive,Aspect 1.0 squared pixels,NTSC,High Profile,3.1 Level, VBR 2 Passes, 5/5 Mbps, key frames 90, checked "use maximum processing quality".
Back in time i never used the Passes or atleast had 1 pass or something,and the time left was shown whenever i directly clicked Export in the Export Dialog you're telling me. I don't know why it's not happening now..For a future update i hope that both Pass X of X and the TIME LEFT appears.
I've tried this "Queue" button and it opened Media Encoder CC (2014?) and pressed a Play button..It then showed the vid's preview progress as in "Where in the encoding the vid is at",along with the TIME LEFT thing at the top right of that area (area called "Codification")
Thanks. It seems that using this Media Encoder CC uses the same settings for exporting that i've chosen in Premiere Pro CC 2014 but in ..Another fashion (among the queue option for multiple rendering in a click)
