quote:
Originally posted by: Peter Grainge
In another post you are asking about a problem with your project, here you cannot open the project. Is that correct and if so can you clarify?
>Yes, I had a problem with pop-ups in a HTML compiled file .(CHM) Not the project source.
Ignoring that, open RH but do not point to one of your projects, instead point to one of the supplied projects. Does that open OK?
>No, RH crashes with the "Microsoft Visual C++ Runtime Library
Run time Error!
Program: c:\ProgramFiles\Adobe\RoboHelp6.0\RoboHTML\RoboHTML.exe
This application has requested the Runtime to terminate it in an unusual way.
Please contact the application's support team for more information."
From there, create a new project onto your hard disk. Is that OK?
>No, RH crashes with the above error.
You are definitely opening a source project rather than some generated webhelp?
>Yes, source project from ClearCase snapshot view on hard disk.
