0 Replies Latest reply: Sep 29, 2014 6:21 AM by Stellas RSS
    Need Help!  Cannot get SourceControl3.1  to work correctly.
    Stellas Community Member
      We are using RH8.  We have a project that needs updating to be current with newest software release.  There is a project manager in the home office and a technical writer working remotely in another state.  Our IT staff followed all the steps listed on setting up the SourceControl and this is what is occurring:
      I've tried it both as file system and as full embedded database solution. For files based solution I did create a history path. This is what I was working on Friday.  I had to set up another test machine here with RoboHelp in order to test it.  Same problem.  I can check out from either machine and checkin in. However the changes never get propagated to the other instance, even if you do a Get All.
      Not sure if this is related, but the open project from Source Control does not work from within Robo Help 8 either. When I try to open a project that way, it just sits there on the open file dialog box.  From what the tutorial showed, it should start downloading the files and then you select the project file to open.
      Here's a sample screen shot.
      I setup a brand new test database and project
      This one is using embedded database, not stored as files.
      Files are set to single checkout
      I modified on one machine
      Checked in ALL files
      Open project on other machine and get all files
      Changes not reflected
      Forced Get All
      Here it is in the project directory... note the mod dates... the file is not updated.
      I would be so very grateful if someone could help figure out what is going on.  Thank you in advance.
      Stella
