6 Replies Latest reply: Sep 29, 2014 11:34 PM by mcsekharmcs RSS
    Edge Animate JS files
    mcsekharmcs
      Is it possible to place edge animate js files in one folder when same html file is in different folder.
        • 1. Re: Edge Animate JS files
          Atul_saini Adobe Employee
          Moving the discussion to Edge Animate CC forum.
          Atul Saini
          • 2. Re: Edge Animate JS files
            Robyn_cpl Community Member
            Yes, this normally happens when you add in the js file through Edge. It automatically creates a js folder for you
            • 3. Re: Edge Animate JS files
              vivekuma Adobe Employee
              I assume that you want to put the files "projName_edge.js" and "projName_edgeActions.js" in a separate folder say "jsFolder" which is present where the file "projName.html" is present.
              You can do that but then you have to modify two files:
              1. In file "projName_edge.js", search for "projName_edgeActions.js", and replace it with "jsFolder/projName_edgeActions.js".
              2. In file "edge.5.0.0.min.js" present in "edge_includes" folder, search for 'a+"_edge.js' and replace it with 'jsFolder/" +a+"_edge.js'
              hope that helps,
              Vivekuma
              • 4. Re: Edge Animate JS files
                mcsekharmcs Community Member
                Hello Vivekuma,
                Thank you for your reply,
                I need to keep all edge animate Js files(which is automatically generated in edge animate) in one folder and I want to keep html file is outside that js folder.
                Structure:
                Inside main folder:
                1. edge_includes folder
                2. js Folder(all js files)
                3. Html file
                Thanks & Regards,
                Chandrasekhar M.
                • 5. Re: Edge Animate JS files
                  Hi Chandrasekhar,
                  There are 3 files that are automatically generated by Edge. One in inside "edge_includes" folder, and other two(_edge.js & _edgeAction.js) are kept along with .html file.
                  My last comment assumes that you will place the two(_edge.js & _edgeAction.js) files in jsFolder. But this will end up using two folders for edge created js files, one being "edge_includes" and other "jsFolder".
                  But if you want to put all in one folder, then put the two files(_edge.js & _edgeAction.js) in the folder "edge_include" so that all 3 edge files are in one folder, and then simply follow my last comment and replace "jsFolder" with "edge_include".
                  hth,
                  Vivekuma
                  • 6. Re: Edge Animate JS files
                    Hello Vivekuma,
                    Thanks a lot, its working fine....
                    Thanks & Regards,
                    Chandrasekhar M.
