1. Re: Can't Install Pluraleyes 3.5.3 for Premiere Pro 2014 Extension
kevinh3682 Sep 29, 2014 7:27 AM (in response to RobSher1)Mine was working fine for a couple weeks, now plural eyes won't launch from premiere cc 2014. I click on it and nothing happens, very frustrating!
2. Re: Can't Install Pluraleyes 3.5.3 for Premiere Pro 2014 Extension
RobSher1 Sep 29, 2014 8:01 AM (in response to RobSher1)I reinstalled Premiere Pro CC and am not able to install Pluraleyes extension. I'm getting a popup that I saw earlier: "The extension 'com.redgiant.pluraleyes35' does not contain a valid signature. The extension will not be installed." I have logged a support ticket with Red Giant and haven't heard from them yet. Will update if they have any suggestions.
3. Re: Can't Install Pluraleyes 3.5.3 for Premiere Pro 2014 Extension
kevinh3682 Sep 29, 2014 9:25 AM (in response to RobSher1)Thanks Rob,
I am also having the extension signature error on my other mac editing system( not the one where it won't launch). I installed the extension on 2 of my 3 editing systems, so I don't have a clue why it wouldn't work on the third.
4. Re: Can't Install Pluraleyes 3.5.3 for Premiere Pro 2014 Extension
RobSher1 Sep 29, 2014 11:59 AM (in response to kevinh3682)I received this response to my RedGiant support ticket and will try it later tonight.
The issue you are currently experiencing is a brand new issue that cropped up in the past couple weeks. The issue involves a broken connector issue between Premiere and PluralEyes. Our developers released a fix on Friday that should address the problem and is available for download here: http://cdn.redgiant.com/redgiant/products/singlesuites/shooter/PluralEyes3.5_Connector_for _PremierePro.zxp.zip
To get setup with that file, follow the guide below:
• Close all programs
• Download and extract the new Connector file: http://cdn.redgiant.com/redgiant/products/singlesuites/shooter/PluralEyes3.5_Connector_for _PremierePro.zxp.zip
• Launch the Adobe Extension Manager
• Click Install
• Navigate to the the file that you'd extractedThat should cover everything. Try re-launching PluralEyes from Premiere and check for better results. If you run into problems or have other questions, respond back and we'll troubleshoot from there.
5. Re: Can't Install Pluraleyes 3.5.3 for Premiere Pro 2014 Extension
kevinh3682 Sep 29, 2014 12:52 PM (in response to RobSher1)Thanks Rob! That worked! Fixed both problems!
6. Re: Can't Install Pluraleyes 3.5.3 for Premiere Pro 2014 Extension
PeterCorbett Oct 3, 2014 1:58 AM (in response to kevinh3682)It's not working here on the latest Pluraleyes download, CC 2014, connector-fix and a MacPro. VERY frustrating.
7. Re: Can't Install Pluraleyes 3.5.3 for Premiere Pro 2014 Extension
MarkDGibson Nov 9, 2014 9:15 PM (in response to PeterCorbett)I've don everything as requested above, and it's not working for me too.
Any suggestions? Does Yosemite on mac have anything to do with it?
