Interesting. I got an email from RoboWizard with some
information on this. This is what he said,
I don't believe the .LNG file is among the mix of output
files. Seems there is an issue with the LNG file not working to
influence a change in the output.
However, the fix seems easy enough. Inside the topic, where
the code for the show link appears, a function named
addShowButton() is called. A brief look at the .JS files seems to
indicate the file named whtopic.js holds the function. Soooo, to
set things the way the user wants to see, they will need to amend
the whtopic.js file, locate the addShowButton
function and configure the text they wish to see. Once they
do this, the topic should display as intended.
It's interesting because I did find the LNG file in my
output! I didn't however test changing anything.
Hope that helps.
