Hi Hugh
I'll have to defer to John Daigle, Colum or another that
regularly uses the Server component to provide details if this is
unclear. However, it's my understanding that the RoboHelp Server
has a component that acts as like the server Admin console. I
believe you use it to configure how RoboHelp Server behaves. I
understand that using this application, you can elect to have the
server either automatically merge projects for you or not.
In your case it would seem that you don't want the automatic
merging. So you would probably want to turn it off.
That part seems clear enough. At least to me. Here is where
it grows pretty fuzzy for me. If you aren't automatically merging
projects, there would have to be SOME way to determine the URL for
each project published. I'm thinking that if you knew the URL, you
could then code either a TOC entry, Toolbar button or some other
way to cause other systems to load up and display.
Cheers... Rick
