1. Re: TOC generated from Robohelp 6 cannot be viewed in Internet Explorer 11
Peter Grainge Oct 2, 2014 1:57 AM (in response to howoonfoong)Even Rh9, 10 and 11 have had to be patched because of IE issues. Probably Rh11 is your only answer if IE support is a must.
2. Re: TOC generated from Robohelp 6 cannot be viewed in Internet Explorer 11
Jeff_Coatsworth Oct 2, 2014 6:41 AM (in response to howoonfoong)It’s a long-shot but won’t hurt to try it – see if you can add the location of your help to IE’s list of Trusted Sites (Tools > Internet Options > Security tab > Trusted sites > Sites button)
3. Re: TOC generated from Robohelp 6 cannot be viewed in Internet Explorer 11
howoonfoong Oct 6, 2014 9:02 PM (in response to Jeff_Coatsworth)Jeff,
I managed to solve the issue. It is a setting issue in IE. In IE, go to Tools > Compatibility View Settings > select the Display intranet sites in Compatibility View. By enabling the option, I can now see the table of contents in the left pane of the online help file.
4. Re: TOC generated from Robohelp 6 cannot be viewed in Internet Explorer 11
Willam van Weelden Oct 9, 2014 5:15 AM (in response to howoonfoong)But this is only a solution for a single browser installation. All other readers will have the same issue. If you want to support IE11, the only real fix is to upgrade RH.
Kind regards,
Willam
