Hello,
I'm owner of two Flash Builder 4.7 licenses, they are listed in my Adobe account, under Products and Services sections as
Flash Builder Std 4.7 multi
Flash Builder Prem 4.7 multi
I recently formated my computer and installed back Flash Builder 4.7.
My problem is, if I click on "License this product" and enter any of my license key, I have the following error :
Serial Number you provided is valid, but a qualifying product could not be found on this computer.
I tried to install Flash Builder 4.6 instead, but it launch me the same error.
Could you help me please ?
Thanks a lot.
Hi Draadounet,
Please try the following steps.
This should help.
Atul Saini
Hello @Atul_saini123,
Thanks for your answer.
Flash Builder 4.6 is not listed in the drop down menu. This is the options listed :
- Adobe Flash Builder 4.5 for PHP Premium
- Adobe Flash Builder 4.5 Premium
- Adobe Master Collection CS5.5
- Adobe Master Collection CS6
- Adobe Web premium CS5.5
Of corse, I tried to select Adobe Flash Builder 4.5 Premium, but it's not working and launch me this error : This serial number is not for a qualifying product. Please try another.
Hi Atul_saini123,
So I checked your link and all seems correct on my computer.
At the bottom of the link you provided there is "see also" section, about activation / deactivation.
I did not deactivated my licenses before my window re-install, and if now I go to Flash Builder -> Help , desactivation button is greyed out. Could it be the source of my problem that I used my licenses on two computer and did not deactivated them ?
If yes, how could I deactivate thoses products ? I searched on my profile but I can't find a way to do it.
Or is there any way to download adobe flash builder 4.5, as it is listed in the drop down menu?
Hi Draadounet,
Kindly check the your Private Messages and revert to it with the serial number.
Atul Saini
I have the same problem. I have a valid license buyed 12/12/2012 and can't use it in my new macbookpro
I need to activate product ASAP.
The Adobe Application Manager says is not for my Adobe Flash Builder 4.7 Premium, and wants me to select another 4.5 for PHP Premium, 4.5 Premium, CS 5.5, and so on...
What can I do it to solve it?
