1. Re: Subform: Flow content only within certain boundaries
Magus069 Oct 2, 2014 10:16 AM (in response to Gray Strickland)Hi, if you want your text 1.3 Subcontractor means: followed by the textfield on the right, you should insert the text in the caption of the textfield..
Insert Caption:
The caption in the design view is placed on left of the textbox if you can see in your picture above, there's 1 line on the left that limits the textfield area and one other line that is over the left line of the the textbox itself,
You can also change some of the settings in the Layout Palette at the bottom under Caption. Change its position and/or reserved space
The caption text can be inserted directly in the design or you can access it via the Object Field Palette in the Caption: textbox...
Expand TextField:
To be able to expand the textfield vertically, you will need the textfield's parents' subforms to be all Flowed Content.
For the TextField's properties you will need to set 2 different things:
1. Object Field Palette: Check Allow Multiple Lines
2. Layout Palette: Check (under Height) Expand to fit
Hope it helps!
