I am sure I am missing something really easy, but I cannot get my css stylesheet to work on my fresh installation.
Does this error indicate an apache or coldfusion problem?
Thanks in advance for any help, Wayne
Hi Wayne,
Could you please confirm if the webroot you are referring to is the ColdFusion webroot, or Apache webroot.
CSS files in the ColdFusion webroot may not be served when explicitly requested through the Apache port, since Apache would not even forward the request to ColdFusion.
Of course, when a CFM page is requested, stylesheet's referenced within CFM pages must get loaded!
- Immanuel
Dear Immanuel
The webroot is the ColdFusion webroot, not Apache.
I am guessing then that I have to edit httpd.conf to get my cfm files to work as I hope?
Wayne
Wayne,
You have to change the webroot directoty from httpd.conf file and that will take care of the issue, if your files(cfm/jpg/css) are in ColdFusion webroot folder then make the change and restart Apache.
Priyank
Dear Priyank
I went into httpd.conf and changed the document root from "c:/wamp/www/" to "c:/ColdFusion11/cfusion/wwwroot/", then restarted the server.
Then when I browsed my application I received a "403 Forbidden" error?
Wayne
You have to make another change in httpd.conf. There an entry for
<Directory "<apache webroot>" > change it to <Directory "C:\ColdFusion11\cfusion\wwwroot">
Restart and it will work.
Priyank
