4 Replies Latest reply: Nov 10, 2014 1:08 PM by BalddogRobin RSS
    cfgridupdate hidden field
    rboudwin Community Member
      Is there a way to insert a hidden field using cfform, cfgrid, and cfgridupdate?
        • 1. Re: cfgridupdate hidden field
          BKBK Community Member
          It is unclear to me what you mean. Insert into into what? You could just declare the type of an input field in a form to be 'hidden'.
          • 2. Re: cfgridupdate hidden field
            BalddogRobin Community Member
            I don't think using a hidden field will work with cfgrid and cfgridupdate.  It's not working for me, but maybe I'm missing something.
            • 3. Re: cfgridupdate hidden field
              Again, what do you mean? What is the context?
              You could just use a hidden form field next to the cfgrid, like this
              <cfform>
              <cfgrid>
              </cfgrid>
              <cfinput type="hidden">
              </cfform>
              • 4. Re: cfgridupdate hidden field
                I did exactly what you show, and it doesn't insert the hidden field when using Insert a Row.
                <!---Output Grid--->
                <cfform>
                <cfgrid name = "PrioritiesGrid"
                  query = "priorities"
                   width="100%"
                insert = "yes"
                delete = "yes"
                rowHeaders = "No"
                  rowHeight="25"
                colHeaderBold = "Yes"
                selectMode = "EDIT"
                insertButton = "Insert a Row" deleteButton = "Delete selected row" sort="yes" >
                    <cfgridcolumn name="pmsppriorityid" display="false">
                    <cfgridcolumn name="pesttypeid" header="Pest Type"  display="yes" width="100" valuesdisplay="#variables.pesttypes#" values="#variables.pesttypesid#" valuesdelimiter=",">
                    <cfgridcolumn name="prioritytypeid" header="Priority Type"  display="yes" valuesdisplay="#variables.prioritytypes#" values="#variables.prioritytypesid#" valuesdelimiter="," width="100">
                    <cfgridcolumn name="cropstageid" header="Stage"  display="yes" width="300" valuesdisplay="#variables.cropstages#" values="#variables.cropstageids#" valuesdelimiter=",">
                    <cfgridcolumn name="prioritynumber" header="Priority Number"  display="yes" width="100">
                    <cfgridcolumn name="criticalneed" header="Critical Need" display="yes" valuesdisplay="True,False" values="true,false" valuesdelimiter=",">
                     <cfgridcolumn name="priority" header="Priority" display="yes" width="1500">
                    </cfgrid><br />
                    <cfinput type="hidden" name="pmspid" value="#url.pmspid#">
                <div align="center"><cfinput type="submit" name="prioritiesEntered" value="Save Priorities"></div>
                </cfform>
