How do I import slides from one Captivate 7 .cptx file to another Captivate 7 .cptx file? On Mac version I can only do this using copy/paste one slide at a time. I'm trying to merge already completed work from a .cptx into a new templated (which has more master slides added) .cptx.@
Only copy/paste is possible. Open both files, Captivate put them in tabs.
When I do this in Captivate 7, it only lets me copy and past one slide at a time. How do I do multiples at the same time? I'm pretty sure I was able to do this in Captivate 5. When I select all of the slide in a single CPTX project, "copy" is grayed out. How do I do this for multiple slides at the same time?
Select multiple slides in filmstrip, you can even select all with CTRL-A.
If you use the copy-and-paste approach to merge some eLearning Brothers interactions into another project, it has the potential to break the interactivity. See Captivate 9 using an elearning Asset .
