Hi there,
since installing OSX lion my InDesign 5.5 crashes at startup. I tried renewing permissions, but that dind't work.
Maybe someone here knows, how to fix this.
Thanks for your help!
Java is up and running. Uninstalled/reinstalled ID twice. Other user accounts work without any problems. It s really strange...
OK, the information that other user accounts work means it really cannot be an installation problem. So reinstalling won't help and Java isn't related to the problem., etc., etc.
As Peter suggested, I have a list of folders/files to remove from your user Library directory. Note that under Lion, you must hold down Option to see the Library folder in the Go menu of the Fin
...Copy link to clipboard
Did you trash your preferences?
Trash, Replace, Reset, or Restore the application Preferences: http://forums.adobe.com/thread/526990
Hi John and thanks for the reply. Yes, actually i did trash the preferences, but it didnt help.
Did you install Java?
Try a different user account?
If that doesn't fix it, I'd reinstall InDesign. OS upgrades can be troublesome, and an ID uninstall/reinstall doesn't take that long anyhow.
Hi John,
Uninstall again, then run the clean tool: Resolve installation problems with CS5 Cleaner Tool and reinstall, or you can wait for John to come back with a list of files/folders to try removing from your user library. Something in there is corrupt.
Wait, wait. I think we don't think the cleaner tool is going to help. As far as I'm aware, it does not remove user-specific state, so if the problem goes with a user account, the cleaner tool won't help...gotta find that list, back in a bit...
OK, I've never had to run the tool on any of my systems, and I'm on Windows, so I don't know for sure, but I've always assumed it would remove all traces, including user profile or library folders (the uninstallers will do that, if you tell them to). I've got a test system to break down in the next month or two, though, so I'll try to remember to run the tool and see what happens before I restore my clean image.
Hi Peter,
thanks for the help, Johns tip worked out quite well, no crashes anymore.
That's great.
Hi Peter,
believe it or not but right now i've got the same Problem with Photoshop. If i open a psd file, photoshop crashes almost instantly.
Any suggestions, what it could be this time?
I will post the crash report in a minute.
Thanks a lot
Ben
Do you run Suitcase?
Have you tried trashing the Photoshop prefs? I think there's just one file for them.
Hi Peter,
just trashed the preferences, it didnt help.
Here is the crash report:
Thanks for the help!
John is the main man for this, but it looks to me like the problem is in Font Xplorer, so most likely either there is a bad font on the system, or there's an incompatibility. You might want to see if there are updates, or remove the auto-activation plugins.
Hi Peter,
good idea, i thought about a font problem,too. Where do i remove the plug ins?
There should be plugins folders for each application. I'm on Windows, so I can't tell you where, exactly, to look on your Mac.
Hi Peter,
i just updated fontexplorer to the latest free version 1.2.3 and it seems to work now.
Thanks for the fast reply, very much appreciated!
Ben
Looks like it got straightened out, but yes, the crash was clearly in Font Xplorer.
At the end of the crash report it tells you where the files are:
0x111bb3000 - 0x11249aff7 +FontExplorer X Pro for Photoshop CS5 (3.2.1 - ???) <C8383148-9AB8-2C07-43C6-3B19E7D0E0B6> /Applications/Adobe Photoshop CS5.1/*/FontExplorer X for Photoshop CS5.plugin/Contents/MacOS/FontExplorer X Pro for Photoshop CS5
So in this case: /Applications/Adobe Photoshop CS5.1/Plug-Ins/FontExplorer X for Photoshop CS5.plugin
InDesign crashing 5 seconds after the start up, tried deleting the files as mentioned in the earlier thread...
Help!
Version? OS? Do you have a crash report?
First things first, patch InDesign to 8.0.2
still not working!!
Post a new crash report...
I tried patching it dint work...
