Hi guys!
One thing to keep in mind is that by inserting a logo via the
Preferences setting, that will only result in displaying your logo
in the navigation panel of the presentation (where the thumbnail,
search and notes tabs can be found, for example). If someone
chooses to collapse that panel, you won't see your logo anymore.
And assuming that you can publish locally to your computer,
another method of adding your own logo is to make a simple change
to the vconfig.xml file (which gets created anytime you publish
your ppt deck). The benefits are twofold: 1) even if the navigation
panel gets collapsed, your logo will still be seen, and 2) you'll
automatically kill off the MacroDobe logo that appears by default.
Extra bonus: by killing off Adobe's logo, you won't have to worry
about folks accidentally clicking
their logo which points to the Presenter product page!!!
It's actually pretty easy to do, and involves just 3 basic
steps (although the first step does require just a little work in
flash):
1. In flash, modify the stage dimensions to 50 x 29 pixels.
Drop your logo within that area (you may have to resize/scale to
get your logo to fit the stage area). Jpg's are okay, but if you
have vector artwork, you'll have better results. Save your flash
doc, then publish it to .swf by hitting Control + Enter on your
keyboard or Shift + F12.
2. Publish your ppt deck if you haven't already.
3. In the folder of your published PPT deck, you'll find a
subdirectory titled "data". Within that folder is a file titled:
"vconfig.xml". Open the xml doc (like Notepad for example); you're
looking for the following tag:
<uireplace name="logo" value=""/>
From here, all you have to do is change the value
parameter...such as:
<uireplace name="logo" value="myLogo.swf"/>
Simply relaunch the index.html page, and your logo will
appear in the bottom left corner of the content area! There is one
catch to this technique however: if you republish your deck, the
plugin will automatically overwirite the vconfig.xml file. Small
price to pay, but it beats leaving / having the presentation with
default settings!
Hope that helps too!
Best,
Rob
www.robrode.com/yabb/
