Flex Message Service with JMS Dynamic Destination
Avatar
Level 1
Any of you folks knows if Flex Message Service supports JMS
Dynamic Destinations? From what I have read about Flex Data Service
so far indicates that all JMS destinations must be pre-defined in
messaging-config.xml file. Our application requires that the
destinations be created at runtime and therefore we can not
pre-define them in the messaging-config.xml file. I would greatly
appriciate any pointer to solve this problem. Sample code would be
helpful. Thanks in advance.
Tam
Avatar
Former Community Member
We do indeed support any dynamic messaging destinations,
including those that use JMSAdapter, from LCDS 2.5 onwards. Check
out documentation of LCDS 2.5 for Runtime Configuration and you'll
see some examples. If not, let me know and I'll try to provide some
samples but dynamic messaging destinations that use JMSAdapter is
definitely possible with LCDS 2.5 onwards.
Avatar
Level 4
Thanks! I'd just come to the forums to try and find an answer
that exact problem, and there it was on the first page
Just a minor query, the example from the Runtime
Configuration docs ("Configuring components with a remote object")
has a line:
ns.setSessionTimeout(30);
I can't see this in the javadocs, so I assume that this
changed to setSubscriptionTimeoutMinutes() to more closely match
the property from the config files it represents, correct?
Avatar
That's correct. Session timeout did not really represent what
that value was so it was changed, I think in LCDS 2.5.
Avatar
Level 1
We only have FFlex 2.0.1. Can we do this Runtime
Configuration with Flex 2.0.1 or we have to purchase LCDS?
Tam
Avatar
Level 4
I'm probably missing something, but how do I set the
important config specifically related to JMS, i.e. what appears in
the <jms> tag for the xml config?
I can see the more generic messaging config options, but I
can't find where to set, for instance, the queue JDBC name.
Avatar
Level 4
in reply to tt9488:
You will not be able to do any JMS with straight Flex 2.0.1,
you need FDS or LCDS too. There's a free but limited version of
LiveCycle Data Services, single CPU no clustering. Have you
purchased Flex Data Services already? If so there may be an upgrade
path.
edit: and yes, the dynamic config is LCDS only.
edit: but the way it's looking to me right now runtime config
may not be viable for jms destinations directly, you may need to
write an MDB bridge.
edit: Figured it out, there were some JMS config classes I'd
somehow missed
Avatar
Hi Robert, can you elaborate further why you think
dynamic/runtime messaging destinations using JMSAdapter are not
viable?
Avatar
Level 1
In reply to Robert
We do have FDS with our Flex 2.0.1. Sorry for the confusion.
Tam
Avatar
Level 1
I have been searching the internet for how I can set JMS
destinations at runtime using LCDS 2.5.1 and still could not find
it. I saw the following code in ChatRoomService that allows setting
runtime destination:
public void createRoom(String id) {
if (roomExists(id))
throw new RuntimeException("Room already exists");
// Create a new Message desination dynamically
String serviceId = "message-service";
MessageBroker broker = MessageBroker.getMessageBroker(null);
MessageService service = (MessageService)
broker.getService(serviceId);
MessageDestination destination = (MessageDestination)
service.createDestination(id);
destination.addChannel("my-rtmp");
ServerSettings serverSettings = new ServerSettings();
serverSettings.setMaxCacheSize(1000);
serverSettings.setMessageTTL(0);
serverSettings.setDurable(false);
destination.setServerSettings(serverSettings);
if (service.isStarted())
destination.start();
rooms.add(id);
The above code is not for setting JMS destination, isn't it?
If it is not, can someone give me some sample code for setting JMS
destination at runtime?
Tam
Avatar
Level 1
What IDE is used for develop LCDS applications? I tried
eclipse-3.2.2 with Flex 2.0.1, FDS 2.0.1, and LCDS 2.5.1 plugins
and it did not work. And eclipse-3.2.2 with Flex 3 plugin does not
seem to have option for me to create new Flex Data Service
application. Can someone give my some pointers on this issue?
Tam
Avatar
Level 4
"Hi Robert, can you elaborate further why you think
viable?"
I edited my post shortly afterwards, see bolded text at the
bottom. I'd missed classes related to JMS config classes, I'd been
looking at the LCDS integrated messaging classes and assumed these
were supposed to be general purpose. I left the original post there
since I don't mind people knowing I make mistakes
Although.... I still haven't actually got this working yet,
and looking again with fresh eyes after a holiday, it looks like
the JMSSettings class can only contain 1 destination JNDI name, and
only one JMSSettings class can be attached to each JMS adapter.
Am I right in saying that this means a separate adapter will
need to be created for each temporary topic?
Perhaps I'm looking at it wrong, is there another mechanism
I've missed besides JNDI which Flex can use to find a JMS topic?
@tt9488
Did you make your new project with the correct Flex.war file?
If you used Peter Martins FDS plugin to create a new LCDS project
in eclipse, then ensure that it points to the correct flex.war
file, through the settings page (remember you can't change the FDS
war location on the new project dialog).
If you need to convert an old project, you can the old jars
and SWCs from the web-inf and meta-inf folders and extract the new
version from flex.war over the top (backup first) then redo your
config files using the new config templates in the resource folder
of LCDS 2.5.1. It gets really messy depending on how much you've
added it may be easier to make a new LCDS project and copy files
across to that. This can get pretty tricky.
I'm using LCDS 2.5.1 with the FB 2.0.1 plugin for eclipse
3.2.2 and it works a charm, although I so far have only upgraded
existing projects to LCDS 2.5.1 and not made any new ones.
Currently I'm working mainly with the SQLAssembler, but hopefully
I'll be returning to the dynamic JMS before too long.
edit:
Just been googling and I've seen you got quite a good
reply
from Jeff Vroom, stating that the best approach might be to
translate JMS topics into LCDS subtopics by subclassing.. that
would certainly be more efficient than the idea I had when I
thought dynamic JMS was not at all viable, that is linking an MDB
to the dynamic JMS topic, and using this as a bridge to translate
messages to a dynamically created AS/LCDS topic. I'll post an
update if I get either approach working.
