Show 1 reply
1. Re: If RH Server's database goes down, does RH Server go down also?
John Daigle Oct 6, 2014 12:35 PM (in response to kdeuler)- Rh Server *is* a database-driven application and as such it requires a database be up and working for both serving content as well as reporting.
- Your IT person raises good points. I have used the "SQL Express" version without issues. As your IT person already knows, there are certain Microsoft connection and size limitations on its use. Otherwise it would be better than Access and assuming it fits the other DB/OS combination requirements I noted in the links above.
- Unless something has changed, the open-source Apache Tomcat Server itself does not support "Load Balancing" and so I don't think you can "spread the CPU load". Although I am not that network savvy, so a call to Adobe support (asking to be escalated for Rh Server-specific assistance) to verify this would be a good idea. That said, I know organizations that have set up "fault tolerance" configurations to their satisfaction (but can't be more specific than that.)
John Daigle
Adobe Certified RoboHelp and Captivate Instructor
Evergreen, Colorado
303-670-8955
