I get this warning:
Unable to launch Adobe InDesign as you do not have sufficient permissions to access the preferences folders. Ensure that you have appropriate permissions and then restart Adobe InDesign.
Any helpers out there?
Try to give permissions to Adobe Indesign Folders
Step 1:
In the Finder, choose Go > Go To Folder.
Step 2:
In the Go To Folder dialog and type
~/Library
Click Go.
Step 3:
Open the Caches Folder > Open the InDesign folder > select Version 9.0 and Right Click to select Get Info
• Unlock the Security lock in the bottom right hand corner
• Under Sharing and Permissions, Click the “+” to add User (yourself) will display under Name
• Under Privilege it will say Read Only, change this to Read & Write
• The
...Copy link to clipboard
Step 1:
Step 2:
~/Library
Click Go.
Step 3:
• Then select the Settings Icon (cogwheel) and Select Apply to Enclosed Items
Step 4:
Open the Preferences Folder > Open the InDesign folder > select Version 9.0 and Right Click to select Get Info
If that does not work, create root user on MAC and then try to launch the application.
Thanks a lot! this solve my problem.
You are welcome.
Is there possibly another solution? I have printed these instructions, gone to the iMac that will not open InDesign and followed instructions exactly. Still InDesign will not open. InDesign's not opening now has happened on two different computers, an iMac and a Mac Pro. We have about 4-5 iMacs that have updated InDesign CC 2014 with no problem. We work off a networked server. Now we are having to go in and backward save some files to make them available to workers who cannot open the Indd 2014 files.
I wonder if Adobe couldn't just fix their installer so it works with a new install.
Any help is greatly appreciated.
Hi
I have a similar issue but I don't have InDesign folder in either of the locations where you say I should find them for steps 3 and 4.
Maybe this could be why its not opening, how do I get those folders back. I have already uninstalled and re-installed, to no avail.
thanks olivia
Step 3:
Step 4:
Are you showing hidden folders?
Thank you Nikhil this solved my very frustrating problem!
I did this and my Indesign opens again but the "skin" isn't black/dark grey anymore its Light grey and looks like cs5 or something.
CS6 never had the dark interface. That was introduced with CC (version 9), and your crash report was from CS6. Do you have multiple versions installed?
You made my day! Thanks a lot
Thank you SO much!
Thanks a lot!!
Thank you!!!!
Thank you all!!! It was within the Step 4 for me, I had version 7 and 10.
Thanks so much! It worked:)
Didn't work.
Please start a new thread and tell us your version of InDesign and OS, how it was installed (clean install or migration), and what is happening, including any error messages.
Thanks, this worked for me too, once I had figured out which preferences file you meant. Just to clarify for anyone else who was confused like me - go back to step 2 and the Preferences folder is in the Library
A quick note to this solution. It worked for me too but after finagling around with the permissions
I went to
When I reopened InDesign CC, it worked.
I hope this helps.
Thank you very much. I am good to go 🙂
Thank you! This was driving me crazy!
Thanks, this made my day!
Perfect. Thank you.
