CF8, GRID,BIND
Aug 06, 2007 Aug 06, 2007
I am trying to get the ajax grid to work but have a small hurdle.
The application sits on a D:drive, with a virtual dir : Apps : http://myserver/apps = web-root
/component/ are in a subdir, now I am I am trying to use
bind="cfc:component.mytest.getNames({cfgridpage},{cfgridpagesize},{cfgridsortcolumn},{cfgridsortdirection})"
But it does not -see- my component. The only thing that works is copying the mytest.cfc to the c:\coldfusion8\wwwroot\
What do I miss here ? Thank you
Advanced techniques
405
Aug 07, 2007 Aug 07, 2007
i'm not sure that using the folder name in the bind statement will work.
Try setting your cfc locations in application.cfm - <cfset REQUEST.CFCLocation="cfc"> something like that, where cfc is the folder name.
Hope that helps a little.
Mat Evans
Thanks, will try,
sofar my conclusion is that virtual directories are not accepted in the path.
Aug 16, 2007 Aug 16, 2007
I think you'll have to do a mapping. You can do it in the admin under
mapping: name: components path: D:\apps\components
CF8 did introduce application.cfc mappings you might look into that as well.
"Hanno1962" <webforumsuser@macromedia.com> wrote in message
news:f99r3g$b2l$1@forums.macromedia.com...
> Thanks, will try,
> path.
Guest
Aug 22, 2007 Aug 22, 2007
Unfortunately if you want to use a cfc:bind statement you need to have the cfc be somewhere under the webroot. You can not even use mappings, which frankly blows.
From the Adobe LiveDocs:
quote:
Using bind expressions
To specify a bind expression, use one of the following formats:
cfc:componentPath.functionName(parameters)
Note: The component path cannot use a mapping. The componentPath value must be a dot-delimited path from the web root or the directory that contains the current page.
Documentation
