I see I misread your first post but panic not.
You uninstalled RH6 but it looks like you also need to
uninstall and reinstall X5.
When that is done, projects that were not opened in RH6
should open OK in X5.
With any project that was opened in RH6, you will need to go
through the process I advised. That should be sufficient but files
can go missing. However, It is only source files going missing that
is a problem and they cannot be in the output folder. When source
files go missing like this, it is because the HHP file had not been
updated prior to the problem occuring. To get the source files
back, you need to import them and it should then be all systems go.
Do the reinstall first, then if you still have a problem
opening the project, note that I did say delete the CPD and XPJ
file. I regularly use the HHP file when people send me a project
that I need to open in an earlier version for some reason.
Try that and post back.
