1. Re: Bridge open file run photoshop action combo
Pedro Marques Oct 7, 2014 2:03 AM (in response to ojodegato)The listeners on photoshop will work to auto-start any action when you use 'Open'.
Unfurtunetly, there is not a listener to the 'OpenInCameraRaw', this took me crazy for years!
So Photoshop can't detect automatically when a image was just opened from the use of the CameraRaw plugin.
2. Re: Bridge open file run photoshop action combo
ojodegato Oct 7, 2014 8:37 AM (in response to Pedro Marques)Pedro,
I am compositing hundreds of tif images. The work flow stars by making collection stack in Bridge. Then I open the stack with Dr.Browns services Place-A-Matic 8bit tool. Next, apply a photoshop action. Finally, close and save the new layered image.
I am trying to find out if this process can be automated.
The ideal workflow would include opening each image stack one at time, run the photoshop action, close the file and then proceed to open the next image stack in the Bridge collection.
I am not clear how to build this work flow yet.
So far it occurred to customize Dr.Brown's Services Place-A-Matic script by adding a run action command at the end of the script.
Dr.Browns Services is listed under the Bridge >> preferences >> startup scripts but it is not in the Bridge Startup Script folder.
The first step would be to find the script in my local system.
Any other ideas?
3. Re: Bridge open file run photoshop action combo
Pedro Marques Oct 7, 2014 9:56 AM (in response to ojodegato)I can only help you with the code specific for Bridge.
I have never used Dr.Browns services Place-A-Matic 8bit tool and I can't figure how to integrate it inside another script.
Still, I think you must use BridgeTalk to send the code related to photoshop from Bridge to Photoshop. I can't help you with that.
// In a specific collection, load all stacks
var allStacks = app.document.stacks;
// create a routine on each single stack
for (var a in allStacks) {
// on each single stack, load all inner thumbnails
var thisStackInnerThumbs = app.document.stacks[a].thumbnails;
for (var b in thisStackInnerThumbs) {
$.writeln("stack_" + a + " | " + thisStackInnerThumbs[b].name); // this will add ESTK console the name of each individual tif image in each stack
// ???? Dr.Browns services Place-A-Matic 8bit tool [BridgeTalk ???]
// running a photoshop action [BridgeTalk]
// saving layered tiff [BridgeTalk]
// closing all opened images [BridgeTalk]
4. Re: Bridge open file run photoshop action combo
ojodegato Oct 7, 2014 10:22 AM (in response to Pedro Marques)Thanks for the providing this reference script.
Perhaps someone with advanced Bridge scripting knowledge can help construct the script. My knowledge of Bridge scripting is limited.
I have ben using the Dr.Browns's Place-A-Matic script i my composting workflow. I can also achieve the same compositing file structure using the Bridge >> Tools >> Load Files into Photoshop Layers which might simplify the scripting process.
