1. Re: Sensibility on flash cc 2014
Sangeeta J Yelamali Oct 6, 2014 10:54 PM (in response to animatiki)Hi,
Issue cannot be reproduced on the latest Flash Pro Version 14.1.0.96.Can you please provide the following information
Flash Pro Version Number
Tablet model
Tablet driver version Number
Mapping mode set for the tablet ,Is it PEN mode or MOUSE mode.
----------------If its Mouse mode pressure and tilt does not work.
PS : Generally updating to the latest wacom driver and restarting the system and Flash Pro resolves most of the issue.Please try this once.Latest wacom drive can be downloaded from http://us.wacom.com/en/support/drivers/
Sangeeta
2. Re: Sensibility on flash cc 2014
animatiki Oct 6, 2014 11:12 PM (in response to Sangeeta J Yelamali)I updated today the flash cc 2014 pro (14.1.0.96 ) and I have the last driver for the cintiq 13 HD ( 6.3.9w3 )
The problem is not of the wacom, because in the setup menu I can see how the presion works perfectly on the pen.The problem is of flash. I can activate the button for the presion, and it shows darker, but the brush keep on painting the same thickness.
Please, tell me there are a solution.....
3. Re: Sensibility on flash cc 2014
animatiki Oct 7, 2014 1:19 AM (in response to animatiki)...in photoshop the pen pressure is working all right, I cannot understand why this problem appears only in flash...
Please help -
4. Re: Sensibility on flash cc 2014
Mukesh R Shah Oct 7, 2014 3:20 AM (in response to animatiki)Can you please check mapping mode set for the tablet ,Is it PEN mode or MOUSE mode?
FlashPro only supports Pen mode.
5. Re: Sensibility on flash cc 2014
animatiki Oct 7, 2014 4:19 AM (in response to Mukesh R Shah)Cintiq have not "pen mode", not "mouse mode" neither...
I had an Intuos some time ago, so I know what you said, but this option doesn't appear in the cintiq setup menu. -
6. Re: Sensibility on flash cc 2014
animatiki Oct 7, 2014 6:44 PM (in response to animatiki)Well, I tried to desinstall completely the cintiq and reinstall with the cd (not downloading the last driver!) and I saw a new problem. The pressure worked, but the lines appear a few cm (or inches) from the pen tip, at the left.
I found a solution to this new trouble in another line of questions in this forum. I solved it opening up the file location of the program in question and going into Properties > Compatibility and checking the "Disable display scaling on high DPI settings" option.
7. Re: Sensibility on flash cc 2014
Mukesh R Shah Oct 7, 2014 10:43 PM (in response to animatiki)Thanks for confirming.
