I can't find my timeline at all yet when it goes to miniature size on the desktop the timeline is there on the bottom. I am on a Mac laptop and the screen is for a large screen, therefore, I can't scroll down to see it at all. I've done the CTRL CMD T and that doesn't work, I've change the workspace size to no avail.
I just updated Adobe Effects.
Please, this is an older thread. Which version do you use (look under Help, About Captivate)? Are you working in the Newbie UI which is the default one? In that case the timeline is collapsed at the bottom. Double-click the Title bar and it will open. You can resize the timeline in the height but in the newbie UI it is fixed in that bottom docking station.
Adobe is having me uninstall and reinstall the program now to see if that
solves the problem. If not, I'm certainly going to try what you suggest
except right now I can't even get to the title bar. On the re-install I
have a timeline but also the wheel of death. So we're now addressing that
problem.
Anytime you do an update or reinstall for Captivate you also need to reset your Preferences. You can use the file Adobe supplies for that purpose inside the Utils directory inside the Captivate install directory. Hopefully your Adobe professional told you to try resetting the Preferences first before putting you to all the trouble of reinstalling the app. It may not have been necessary.
Basically, they made me go through all the files through to the common
folder, delete the cache and peak files, then because I then had the wheel
of death, they had to go in and do permissions for Adobe to fix that. It
was a five-hour process back and forth to correct that problem, basically
my whole day.
