15 Replies Latest reply on Dec 11, 2014 10:28 AM by darwin.campa
    Did CC 2014.2 break textItem.size?
    darwin.campa
      Scripts that worked before the update are now broken, and text layers created via script are all 12px. See this simple script:
      var docRef = activeDocument;
      var TextLabel = docRef.artLayers.add();
      TextLabel.kind = LayerKind.TEXT;
      TextLabel.name = "Test";
      TextLabel.textItem.contents = "This text should be 50pt";
      TextLabel.textItem.size = new UnitValue("50 points"); // other variations, such as TextLabel.textItem.size = 50 also fail.
      TextLabel.textItem.font = "Monaco";
      Any help? Thanks.
        • 1. Re: Did CC 2014.2 break textItem.size?
          xbytor2 Level 4
          This is a problem that I think was previously seen.
          Here's a slight revision of your test code.
          var doc = app.documents.add();
          var layer = doc.artLayers.add();
          layer.kind = LayerKind.TEXT;
          layer.name = "Test";
          var titem = layer.textItem;
          titem.contents = "This text should be 50pt";
          titem.size = new UnitValue("50", "pts");
          titem.font = "Monaco";
          alert(titem.size);
          Run it in CS6 and the alert is "50 pt".
          Run it in CC14 (and maybe CC) and the alert is "12 pt".
          I'll see if I can find a work around for this because it's causing problems with some of my code.
          X
          • 2. Re: Re: Did CC 2014.2 break textItem.size?
            darwin.campa Level 1
            Thanks for the adjusted test code! Truthfully I don't know if the UnitValue() method was broken before 2014.2 or not, but I know for sure that this shorthand method was working fine in both CC and CC 2014:
            titem.size = 50;
            Note that this method isn't the documented one and is probably more likely to give unexpected results, but this is the one that I can say for sure was working. If I'm remembering correctly, the unitless number is interpreted as pixels (even if your measurement unit is currently set to points), so this would only yield 50pts if your resolution is set to 72.
            • 3. Re: Did CC 2014.2 break textItem.size?
              xbytor2 Level 4
              I found the/a problem. When you create a new text layer, the size is getting stuck at 12 pixels. And there is no way using the DOM to change that. Run it in the debugger with a breakpoint and try to change it to anything other than 12 px. I couldn't.
              I'm going to see if I can find a workaround with some AM code.
              • 4. Re: Re: Did CC 2014.2 break textItem.size?
                xbytor2 Level 4
                OK Using  ActionManager code can work around the problem. Below I have an object called PSCCFontSizeFix with a single method setFontSize that takes a layer and the font size in points. This needs to be the first operation on the text layer or odd things may happen. Also, you will need to explicitly set the font type-face as the one embedded probably isn't the one that you want. Sample usage code is down at the bottom.
                PSCCFontSizeFix = {};
                PSCCFontSizeFix.setFontSize = function(layer, pts) {
                var idsetd = charIDToTypeID( "setd" );
                    var desc70 = new ActionDescriptor();
                    var idnull = charIDToTypeID( "null" );
                        var ref13 = new ActionReference();
                        var idTxLr = charIDToTypeID( "TxLr" );
                        var idOrdn = charIDToTypeID( "Ordn" );
                        var idTrgt = charIDToTypeID( "Trgt" );
                        ref13.putEnumerated( idTxLr, idOrdn, idTrgt );
                    desc70.putReference( idnull, ref13 );
                    var idT = charIDToTypeID( "T   " );
                        var desc71 = new ActionDescriptor();
                        var idTxt = charIDToTypeID( "Txt " );
                        desc71.putString( idTxt, """tmp""" );
                        var idwarp = stringIDToTypeID( "warp" );
                            var desc72 = new ActionDescriptor();
                            var idwarpStyle = stringIDToTypeID( "warpStyle" );
                            var idwarpNone = stringIDToTypeID( "warpNone" );
                            desc72.putEnumerated( idwarpStyle, idwarpStyle, idwarpNone );
                            var idwarpValue = stringIDToTypeID( "warpValue" );
                            desc72.putDouble( idwarpValue, 0.000000 );
                            var idwarpPerspective = stringIDToTypeID( "warpPerspective" );
                            desc72.putDouble( idwarpPerspective, 0.000000 );
                            var idwarpPerspectiveOther = stringIDToTypeID( "warpPerspectiveOther" );
                            desc72.putDouble( idwarpPerspectiveOther, 0.000000 );
                            var idwarpRotate = stringIDToTypeID( "warpRotate" );
                            var idOrnt = charIDToTypeID( "Ornt" );
                            var idHrzn = charIDToTypeID( "Hrzn" );
                            desc72.putEnumerated( idwarpRotate, idOrnt, idHrzn );
                        desc71.putObject( idwarp, idwarp, desc72 );
                        var idtextGridding = stringIDToTypeID( "textGridding" );
                        var idNone = charIDToTypeID( "None" );
                        desc71.putEnumerated( idtextGridding, idtextGridding, idNone );
                        desc71.putEnumerated( idOrnt, idOrnt, idHrzn );
                        var idAntA = charIDToTypeID( "AntA" );
                        var idAnnt = charIDToTypeID( "Annt" );
                        var idantiAliasSharp = stringIDToTypeID( "antiAliasSharp" );
                        desc71.putEnumerated( idAntA, idAnnt, idantiAliasSharp );
                        var idbounds = stringIDToTypeID( "bounds" );
                            var desc73 = new ActionDescriptor();
                            var idLeft = charIDToTypeID( "Left" );
                            var idPnt = charIDToTypeID( "#Pnt" );
                            desc73.putUnitDouble( idLeft, idPnt, 0.000000 );
                            var idTop = charIDToTypeID( "Top " );
                            desc73.putUnitDouble( idTop, idPnt, -52.739868 );
                            var idRght = charIDToTypeID( "Rght" );
                            desc73.putUnitDouble( idRght, idPnt, 108.017578 );
                            var idBtom = charIDToTypeID( "Btom" );
                            desc73.putUnitDouble( idBtom, idPnt, 25.253906 );
                        desc71.putObject( idbounds, idbounds, desc73 );
                        var idboundingBox = stringIDToTypeID( "boundingBox" );
                            var desc74 = new ActionDescriptor();
                            desc74.putUnitDouble( idLeft, idPnt, 2.640000 );
                            desc74.putUnitDouble( idTop, idPnt, -42.960000 );
                            desc74.putUnitDouble( idRght, idPnt, 104.651719 );
                            desc74.putUnitDouble( idBtom, idPnt, 12.720000 );
                        desc71.putObject( idboundingBox, idboundingBox, desc74 );
                        var idtextShape = stringIDToTypeID( "textShape" );
                            var list13 = new ActionList();
                                var desc75 = new ActionDescriptor();
                                var idTEXT = charIDToTypeID( "TEXT" );
                                var idPnt = charIDToTypeID( "Pnt " );
                                desc75.putEnumerated( idTEXT, idTEXT, idPnt );
                                desc75.putEnumerated( idOrnt, idOrnt, idHrzn );
                                var idTrnf = charIDToTypeID( "Trnf" );
                                    var desc76 = new ActionDescriptor();
                                    var idxx = stringIDToTypeID( "xx" );
                                    desc76.putDouble( idxx, 1.000000 );
                                    var idxy = stringIDToTypeID( "xy" );
                                    desc76.putDouble( idxy, 0.000000 );
                                    var idyx = stringIDToTypeID( "yx" );
                                    desc76.putDouble( idyx, 0.000000 );
                                    var idyy = stringIDToTypeID( "yy" );
                                    desc76.putDouble( idyy, 1.000000 );
                                    var idtx = stringIDToTypeID( "tx" );
                                    desc76.putDouble( idtx, 0.000000 );
                                    var idty = stringIDToTypeID( "ty" );
                                    desc76.putDouble( idty, 0.000000 );
                                desc75.putObject( idTrnf, idTrnf, desc76 );
                                var idrowCount = stringIDToTypeID( "rowCount" );
                                desc75.putInteger( idrowCount, 1 );
                                var idcolumnCount = stringIDToTypeID( "columnCount" );
                                desc75.putInteger( idcolumnCount, 1 );
                                var idrowMajorOrder = stringIDToTypeID( "rowMajorOrder" );
                                desc75.putBoolean( idrowMajorOrder, true );
                                var idrowGutter = stringIDToTypeID( "rowGutter" );
                                desc75.putUnitDouble( idrowGutter, idPnt, 0.000000 );
                                var idcolumnGutter = stringIDToTypeID( "columnGutter" );
                                desc75.putUnitDouble( idcolumnGutter, idPnt, 0.000000 );
                                var idSpcn = charIDToTypeID( "Spcn" );
                                desc75.putUnitDouble( idSpcn, idPnt, 0.000000 );
                                var idframeBaselineAlignment = stringIDToTypeID( "frameBaselineAlignment" );
                                var idalignByAscent = stringIDToTypeID( "alignByAscent" );
                                desc75.putEnumerated( idframeBaselineAlignment, idframeBaselineAlignment, idalignByAscent );
                                var idfirstBaselineMinimum = stringIDToTypeID( "firstBaselineMinimum" );
                                desc75.putUnitDouble( idfirstBaselineMinimum, idPnt, 0.000000 );
                                var idbase = stringIDToTypeID( "base" );
                                    var desc77 = new ActionDescriptor();
                                    desc77.putDouble( idHrzn, 0.000000 );
                                    var idVrtc = charIDToTypeID( "Vrtc" );
                                    desc77.putDouble( idVrtc, 0.000000 );
                                desc75.putObject( idbase, idPnt, desc77 );
                            list13.putObject( idtextShape, desc75 );
                        desc71.putList( idtextShape, list13 );
                        var idTxtt = charIDToTypeID( "Txtt" );
                            var list14 = new ActionList();
                                var desc78 = new ActionDescriptor();
                                var idFrom = charIDToTypeID( "From" );
                                desc78.putInteger( idFrom, 0 );
                                desc78.putInteger( idT, 4 );
                                var idTxtS = charIDToTypeID( "TxtS" );
                                    var desc79 = new ActionDescriptor();
                                    var idstyleSheetHasParent = stringIDToTypeID( "styleSheetHasParent" );
                                    desc79.putBoolean( idstyleSheetHasParent, true );
                                    var idfontPostScriptName = stringIDToTypeID( "fontPostScriptName" );
                                    desc79.putString( idfontPostScriptName, """Monaco""" );
                                    var idFntN = charIDToTypeID( "FntN" );
                                    desc79.putString( idFntN, """Monaco""" );
                                    var idFntS = charIDToTypeID( "FntS" );
                                    desc79.putString( idFntS, """Regular""" );
                                    var idScrp = charIDToTypeID( "Scrp" );
                                    desc79.putInteger( idScrp, 0 );
                                    var idFntT = charIDToTypeID( "FntT" );
                                    desc79.putInteger( idFntT, 1 );
                                    var idSz = charIDToTypeID( "Sz  " );
                                    desc79.putUnitDouble( idSz, idPnt, pts );
                                    var idimpliedFontSize = stringIDToTypeID( "impliedFontSize" );
                                    desc79.putUnitDouble( idimpliedFontSize, idPnt, pts );
                                    var idHrzS = charIDToTypeID( "HrzS" );
                                    desc79.putDouble( idHrzS, 100.000000 );
                                    var idVrtS = charIDToTypeID( "VrtS" );
                                    desc79.putDouble( idVrtS, 100.000000 );
                                    var idsyntheticBold = stringIDToTypeID( "syntheticBold" );
                                    desc79.putBoolean( idsyntheticBold, false );
                                    var idsyntheticItalic = stringIDToTypeID( "syntheticItalic" );
                                    desc79.putBoolean( idsyntheticItalic, false );
                                    var idautoLeading = stringIDToTypeID( "autoLeading" );
                                    desc79.putBoolean( idautoLeading, true );
                                    var idTrck = charIDToTypeID( "Trck" );
                                    desc79.putInteger( idTrck, 0 );
                                    var idBsln = charIDToTypeID( "Bsln" );
                                    desc79.putUnitDouble( idBsln, idPnt, 0.000000 );
                                    var idimpliedBaselineShift = stringIDToTypeID( "impliedBaselineShift" );
                                    desc79.putUnitDouble( idimpliedBaselineShift, idPnt, 0.000000 );
                                    var idAtKr = charIDToTypeID( "AtKr" );
                                    var idmetricsKern = stringIDToTypeID( "metricsKern" );
                                    desc79.putEnumerated( idAtKr, idAtKr, idmetricsKern );
                                    var idfontCaps = stringIDToTypeID( "fontCaps" );
                                    var idNrml = charIDToTypeID( "Nrml" );
                                    desc79.putEnumerated( idfontCaps, idfontCaps, idNrml );
                                    var iddigitSet = stringIDToTypeID( "digitSet" );
                                    var iddefaultDigits = stringIDToTypeID( "defaultDigits" );
                                    desc79.putEnumerated( iddigitSet, iddigitSet, iddefaultDigits );
                                    var idkashidas = stringIDToTypeID( "kashidas" );
                                    var idkashidaDefault = stringIDToTypeID( "kashidaDefault" );
                                    desc79.putEnumerated( idkashidas, idkashidas, idkashidaDefault );
                                    var iddiacXOffset = stringIDToTypeID( "diacXOffset" );
                                    desc79.putUnitDouble( iddiacXOffset, idPnt, 0.000000 );
                                    var iddiacYOffset = stringIDToTypeID( "diacYOffset" );
                                    desc79.putUnitDouble( iddiacYOffset, idPnt, 0.000000 );
                                    var idmarkYDistFromBaseline = stringIDToTypeID( "markYDistFromBaseline" );
                                    desc79.putUnitDouble( idmarkYDistFromBaseline, idPnt, 24.000000 );
                                    var idbaseline = stringIDToTypeID( "baseline" );
                                    desc79.putEnumerated( idbaseline, idbaseline, idNrml );
                                    var idstrikethrough = stringIDToTypeID( "strikethrough" );
                                    var idstrikethroughOff = stringIDToTypeID( "strikethroughOff" );
                                    desc79.putEnumerated( idstrikethrough, idstrikethrough, idstrikethroughOff );
                                    var idUndl = charIDToTypeID( "Undl" );
                                    var idunderlineOff = stringIDToTypeID( "underlineOff" );
                                    desc79.putEnumerated( idUndl, idUndl, idunderlineOff );
                                    var idligature = stringIDToTypeID( "ligature" );
                                    desc79.putBoolean( idligature, true );
                                    var idaltligature = stringIDToTypeID( "altligature" );
                                    desc79.putBoolean( idaltligature, false );
                                    var idcontextualLigatures = stringIDToTypeID( "contextualLigatures" );
                                    desc79.putBoolean( idcontextualLigatures, false );
                                    var idfractions = stringIDToTypeID( "fractions" );
                                    desc79.putBoolean( idfractions, false );
                                    var idordinals = stringIDToTypeID( "ordinals" );
                                    desc79.putBoolean( idordinals, false );
                                    var idswash = stringIDToTypeID( "swash" );
                                    desc79.putBoolean( idswash, false );
                                    var idtitling = stringIDToTypeID( "titling" );
                                    desc79.putBoolean( idtitling, false );
                                    var idconnectionForms = stringIDToTypeID( "connectionForms" );
                                    desc79.putBoolean( idconnectionForms, false );
                                    var idstylisticAlternates = stringIDToTypeID( "stylisticAlternates" );
                                    desc79.putBoolean( idstylisticAlternates, false );
                                    var idornaments = stringIDToTypeID( "ornaments" );
                                    desc79.putBoolean( idornaments, false );
                                    var idjustificationAlternates = stringIDToTypeID( "justificationAlternates" );
                                    desc79.putBoolean( idjustificationAlternates, false );
                                    var idfigureStyle = stringIDToTypeID( "figureStyle" );
                                    desc79.putEnumerated( idfigureStyle, idfigureStyle, idNrml );
                                    var idproportionalMetrics = stringIDToTypeID( "proportionalMetrics" );
                                    desc79.putBoolean( idproportionalMetrics, false );
                                    var idkana = stringIDToTypeID( "kana" );
                                    desc79.putBoolean( idkana, false );
                                    var iditalics = stringIDToTypeID( "italics" );
                                    desc79.putBoolean( iditalics, false );
                                    var idbaselineDirection = stringIDToTypeID( "baselineDirection" );
                                    var idrotated = stringIDToTypeID( "rotated" );
                                    desc79.putEnumerated( idbaselineDirection, idbaselineDirection, idrotated );
                                    var idtextLanguage = stringIDToTypeID( "textLanguage" );
                                    var idenglishLanguage = stringIDToTypeID( "englishLanguage" );
                                    desc79.putEnumerated( idtextLanguage, idtextLanguage, idenglishLanguage );
                                    var idjapaneseAlternate = stringIDToTypeID( "japaneseAlternate" );
                                    var iddefaultForm = stringIDToTypeID( "defaultForm" );
                                    desc79.putEnumerated( idjapaneseAlternate, idjapaneseAlternate, iddefaultForm );
                                    var idmojiZume = stringIDToTypeID( "mojiZume" );
                                    desc79.putDouble( idmojiZume, 0.000000 );
                                    var idgridAlignment = stringIDToTypeID( "gridAlignment" );
                                    var idroman = stringIDToTypeID( "roman" );
                                    desc79.putEnumerated( idgridAlignment, idgridAlignment, idroman );
                                    var idnoBreak = stringIDToTypeID( "noBreak" );
                                    desc79.putBoolean( idnoBreak, false );
                                    var idClr = charIDToTypeID( "Clr " );
                                        var desc80 = new ActionDescriptor();
                                        var idRd = charIDToTypeID( "Rd  " );
                                        desc80.putDouble( idRd, 122.625584 );
                                        var idGrn = charIDToTypeID( "Grn " );
                                        desc80.putDouble( idGrn, 122.625591 );
                                        var idBl = charIDToTypeID( "Bl  " );
                                        desc80.putDouble( idBl, 122.625591 );
                                    var idRGBC = charIDToTypeID( "RGBC" );
                                    desc79.putObject( idClr, idRGBC, desc80 );
                                    var idstrokeColor = stringIDToTypeID( "strokeColor" );
                                        var desc81 = new ActionDescriptor();
                                        desc81.putDouble( idRd, 0.000000 );
                                        desc81.putDouble( idGrn, 0.000000 );
                                        desc81.putDouble( idBl, 0.000000 );
                                    desc79.putObject( idstrokeColor, idRGBC, desc81 );
                                    var idbaseParentStyle = stringIDToTypeID( "baseParentStyle" );
                                        var desc82 = new ActionDescriptor();
                                        desc82.putString( idfontPostScriptName, """MyriadPro-Regular""" );
                                        desc82.putString( idFntN, """Myriad Pro""" );
                                        desc82.putString( idFntS, """Regular""" );
                                        desc82.putInteger( idScrp, 0 );
                                        desc82.putInteger( idFntT, 0 );
                                        desc82.putUnitDouble( idSz, idPnt, 12.000000 );
                                        desc82.putUnitDouble( idimpliedFontSize, idPnt, 12.000000 );
                                        desc82.putDouble( idHrzS, 100.000000 );
                                        desc82.putDouble( idVrtS, 100.000000 );
                                        desc82.putBoolean( idsyntheticBold, false );
                                        desc82.putBoolean( idsyntheticItalic, false );
                                        desc82.putBoolean( idautoLeading, true );
                                        desc82.putInteger( idTrck, 0 );
                                        desc82.putUnitDouble( idBsln, idPnt, 0.000000 );
                                        desc82.putUnitDouble( idimpliedBaselineShift, idPnt, 0.000000 );
                                        var idcharacterRotation = stringIDToTypeID( "characterRotation" );
                                        desc82.putDouble( idcharacterRotation, 0.000000 );
                                        desc82.putEnumerated( idAtKr, idAtKr, idmetricsKern );
                                        desc82.putEnumerated( idfontCaps, idfontCaps, idNrml );
                                        desc82.putEnumerated( iddigitSet, iddigitSet, iddefaultDigits );
                                        var iddirOverride = stringIDToTypeID( "dirOverride" );
                                        var iddirOverrideDefault = stringIDToTypeID( "dirOverrideDefault" );
                                        desc82.putEnumerated( iddirOverride, iddirOverride, iddirOverrideDefault );
                                        desc82.putEnumerated( idkashidas, idkashidas, idkashidaDefault );
                                        var iddiacVPos = stringIDToTypeID( "diacVPos" );
                                        var iddiacVPosOpenType = stringIDToTypeID( "diacVPosOpenType" );
                                        desc82.putEnumerated( iddiacVPos, iddiacVPos, iddiacVPosOpenType );
                                        desc82.putUnitDouble( iddiacXOffset, idPnt, 0.000000 );
                                        desc82.putUnitDouble( iddiacYOffset, idPnt, 0.000000 );
                                        desc82.putUnitDouble( idmarkYDistFromBaseline, idPnt, 100.000000 );
                                        desc82.putEnumerated( idbaseline, idbaseline, idNrml );
                                        var idotbaseline = stringIDToTypeID( "otbaseline" );
                                        desc82.putEnumerated( idotbaseline, idotbaseline, idNrml );
                                        desc82.putEnumerated( idstrikethrough, idstrikethrough, idstrikethroughOff );
                                        desc82.putEnumerated( idUndl, idUndl, idunderlineOff );
                                        var idunderlineOffset = stringIDToTypeID( "underlineOffset" );
                                        desc82.putUnitDouble( idunderlineOffset, idPnt, 0.000000 );
                                        desc82.putBoolean( idligature, true );
                                        desc82.putBoolean( idaltligature, false );
                                        desc82.putBoolean( idcontextualLigatures, false );
                                        var idalternateLigatures = stringIDToTypeID( "alternateLigatures" );
                                        desc82.putBoolean( idalternateLigatures, false );
                                        var idoldStyle = stringIDToTypeID( "oldStyle" );
                                        desc82.putBoolean( idoldStyle, false );
                                        desc82.putBoolean( idfractions, false );
                                        desc82.putBoolean( idordinals, false );
                                        desc82.putBoolean( idswash, false );
                                        desc82.putBoolean( idtitling, false );
                                        desc82.putBoolean( idconnectionForms, false );
                                        desc82.putBoolean( idstylisticAlternates, false );
                                        desc82.putBoolean( idornaments, false );
                                        desc82.putBoolean( idjustificationAlternates, false );
                                        desc82.putEnumerated( idfigureStyle, idfigureStyle, idNrml );
                                        desc82.putBoolean( idproportionalMetrics, false );
                                        desc82.putBoolean( idkana, false );
                                        desc82.putBoolean( iditalics, false );
                                        var idruby = stringIDToTypeID( "ruby" );
                                        desc82.putBoolean( idruby, false );
                                        desc82.putEnumerated( idbaselineDirection, idbaselineDirection, idrotated );
                                        desc82.putEnumerated( idtextLanguage, idtextLanguage, idenglishLanguage );
                                        desc82.putEnumerated( idjapaneseAlternate, idjapaneseAlternate, iddefaultForm );
                                        desc82.putDouble( idmojiZume, 0.000000 );
                                        desc82.putEnumerated( idgridAlignment, idgridAlignment, idroman );
                                        var idenableWariChu = stringIDToTypeID( "enableWariChu" );
                                        desc82.putBoolean( idenableWariChu, false );
                                        var idwariChuCount = stringIDToTypeID( "wariChuCount" );
                                        desc82.putInteger( idwariChuCount, 2 );
                                        var idwariChuLineGap = stringIDToTypeID( "wariChuLineGap" );
                                        desc82.putInteger( idwariChuLineGap, 0 );
                                        var idwariChuScale = stringIDToTypeID( "wariChuScale" );
                                        desc82.putDouble( idwariChuScale, 0.500000 );
                                        var idwariChuWidow = stringIDToTypeID( "wariChuWidow" );
                                        desc82.putInteger( idwariChuWidow, 2 );
                                        var idwariChuOrphan = stringIDToTypeID( "wariChuOrphan" );
                                        desc82.putInteger( idwariChuOrphan, 2 );
                                        var idwariChuJustification = stringIDToTypeID( "wariChuJustification" );
                                        var idwariChuAutoJustify = stringIDToTypeID( "wariChuAutoJustify" );
                                        desc82.putEnumerated( idwariChuJustification, idwariChuJustification, idwariChuAutoJustify );
                                        var idtcyUpDown = stringIDToTypeID( "tcyUpDown" );
                                        desc82.putInteger( idtcyUpDown, 0 );
                                        var idtcyLeftRight = stringIDToTypeID( "tcyLeftRight" );
                                        desc82.putInteger( idtcyLeftRight, 0 );
                                        var idleftAki = stringIDToTypeID( "leftAki" );
                                        desc82.putDouble( idleftAki, -1.000000 );
                                        var idrightAki = stringIDToTypeID( "rightAki" );
                                        desc82.putDouble( idrightAki, -1.000000 );
                                        var idjiDori = stringIDToTypeID( "jiDori" );
                                        desc82.putInteger( idjiDori, 0 );
                                        desc82.putBoolean( idnoBreak, false );
                                            var desc83 = new ActionDescriptor();
                                            desc83.putDouble( idRd, 0.000000 );
                                            desc83.putDouble( idGrn, 0.000000 );
                                            desc83.putDouble( idBl, 0.000000 );
                                        desc82.putObject( idClr, idRGBC, desc83 );
                                            var desc84 = new ActionDescriptor();
                                            desc84.putDouble( idRd, 0.000000 );
                                            desc84.putDouble( idGrn, 0.000000 );
                                            desc84.putDouble( idBl, 0.000000 );
                                        desc82.putObject( idstrokeColor, idRGBC, desc84 );
                                        var idFl = charIDToTypeID( "Fl  " );
                                        desc82.putBoolean( idFl, true );
                                        var idStrk = charIDToTypeID( "Strk" );
                                        desc82.putBoolean( idStrk, false );
                                        var idfillFirst = stringIDToTypeID( "fillFirst" );
                                        desc82.putBoolean( idfillFirst, true );
                                        var idfillOverPrint = stringIDToTypeID( "fillOverPrint" );
                                        desc82.putBoolean( idfillOverPrint, false );
                                        var idstrokeOverPrint = stringIDToTypeID( "strokeOverPrint" );
                                        desc82.putBoolean( idstrokeOverPrint, false );
                                        var idlineCap = stringIDToTypeID( "lineCap" );
                                        var idbuttCap = stringIDToTypeID( "buttCap" );
                                        desc82.putEnumerated( idlineCap, idlineCap, idbuttCap );
                                        var idlineJoin = stringIDToTypeID( "lineJoin" );
                                        var idmiterJoin = stringIDToTypeID( "miterJoin" );
                                        desc82.putEnumerated( idlineJoin, idlineJoin, idmiterJoin );
                                        var idlineWidth = stringIDToTypeID( "lineWidth" );
                                        desc82.putUnitDouble( idlineWidth, idPnt, 1.000000 );
                                        var idmiterLimit = stringIDToTypeID( "miterLimit" );
                                        desc82.putUnitDouble( idmiterLimit, idPnt, 4.000000 );
                                        var idlineDashoffset = stringIDToTypeID( "lineDashoffset" );
                                        desc82.putDouble( idlineDashoffset, 0.000000 );
                                    desc79.putObject( idbaseParentStyle, idTxtS, desc82 );
                                desc78.putObject( idTxtS, idTxtS, desc79 );
                            list14.putObject( idTxtt, desc78 );
                        desc71.putList( idTxtt, list14 );
                        var idparagraphStyleRange = stringIDToTypeID( "paragraphStyleRange" );
                            var list15 = new ActionList();
                                var desc85 = new ActionDescriptor();
                                desc85.putInteger( idFrom, 0 );
                                desc85.putInteger( idT, 4 );
                                var idparagraphStyle = stringIDToTypeID( "paragraphStyle" );
                                    var desc86 = new ActionDescriptor();
                                    desc86.putBoolean( idstyleSheetHasParent, true );
                                    var idAlgn = charIDToTypeID( "Algn" );
                                    var idAlg = charIDToTypeID( "Alg " );
                                    desc86.putEnumerated( idAlgn, idAlg, idLeft );
                                    var idfirstLineIndent = stringIDToTypeID( "firstLineIndent" );
                                    desc86.putUnitDouble( idfirstLineIndent, idPnt, 0.000000 );
                                    var idimpliedFirstLineIndent = stringIDToTypeID( "impliedFirstLineIndent" );
                                    desc86.putUnitDouble( idimpliedFirstLineIndent, idPnt, 0.000000 );
                                    var idstartIndent = stringIDToTypeID( "startIndent" );
                                    desc86.putUnitDouble( idstartIndent, idPnt, 0.000000 );
                                    var idimpliedStartIndent = stringIDToTypeID( "impliedStartIndent" );
                                    desc86.putUnitDouble( idimpliedStartIndent, idPnt, 0.000000 );
                                    var idendIndent = stringIDToTypeID( "endIndent" );
                                    desc86.putUnitDouble( idendIndent, idPnt, 0.000000 );
                                    var idimpliedEndIndent = stringIDToTypeID( "impliedEndIndent" );
                                    desc86.putUnitDouble( idimpliedEndIndent, idPnt, 0.000000 );
                                    var idspaceBefore = stringIDToTypeID( "spaceBefore" );
                                    desc86.putUnitDouble( idspaceBefore, idPnt, 0.000000 );
                                    var idimpliedSpaceBefore = stringIDToTypeID( "impliedSpaceBefore" );
                                    desc86.putUnitDouble( idimpliedSpaceBefore, idPnt, 0.000000 );
                                    var idspaceAfter = stringIDToTypeID( "spaceAfter" );
                                    desc86.putUnitDouble( idspaceAfter, idPnt, 0.000000 );
                                    var idimpliedSpaceAfter = stringIDToTypeID( "impliedSpaceAfter" );
                                    desc86.putUnitDouble( idimpliedSpaceAfter, idPnt, 0.000000 );
                                    var idautoLeadingPercentage = stringIDToTypeID( "autoLeadingPercentage" );
                                    desc86.putDouble( idautoLeadingPercentage, 1.200000 );
                                    var idleadingType = stringIDToTypeID( "leadingType" );
                                    var idleadingBelow = stringIDToTypeID( "leadingBelow" );
                                    desc86.putEnumerated( idleadingType, idleadingType, idleadingBelow );
                                    var iddirectionType = stringIDToTypeID( "directionType" );
                                    var iddirLeftToRight = stringIDToTypeID( "dirLeftToRight" );
                                    desc86.putEnumerated( iddirectionType, iddirectionType, iddirLeftToRight );
                                    var idkashidaWidthType = stringIDToTypeID( "kashidaWidthType" );
                                    var idkashidaWidthMedium = stringIDToTypeID( "kashidaWidthMedium" );
                                    desc86.putEnumerated( idkashidaWidthType, idkashidaWidthType, idkashidaWidthMedium );
                                    var idhyphenate = stringIDToTypeID( "hyphenate" );
                                    desc86.putBoolean( idhyphenate, true );
                                    var idhyphenateWordSize = stringIDToTypeID( "hyphenateWordSize" );
                                    desc86.putInteger( idhyphenateWordSize, 6 );
                                    var idhyphenatePreLength = stringIDToTypeID( "hyphenatePreLength" );
                                    desc86.putInteger( idhyphenatePreLength, 2 );
                                    var idhyphenatePostLength = stringIDToTypeID( "hyphenatePostLength" );
                                    desc86.putInteger( idhyphenatePostLength, 2 );
                                    var idhyphenateLimit = stringIDToTypeID( "hyphenateLimit" );
                                    desc86.putInteger( idhyphenateLimit, 0 );
                                    var idhyphenationZone = stringIDToTypeID( "hyphenationZone" );
                                    desc86.putDouble( idhyphenationZone, 36.000000 );
                                    var idhyphenateCapitalized = stringIDToTypeID( "hyphenateCapitalized" );
                                    desc86.putBoolean( idhyphenateCapitalized, true );
                                    var idjustificationWordMinimum = stringIDToTypeID( "justificationWordMinimum" );
                                    desc86.putDouble( idjustificationWordMinimum, 0.800000 );
                                    var idjustificationWordDesired = stringIDToTypeID( "justificationWordDesired" );
                                    desc86.putDouble( idjustificationWordDesired, 1.000000 );
                                    var idjustificationWordMaximum = stringIDToTypeID( "justificationWordMaximum" );
                                    desc86.putDouble( idjustificationWordMaximum, 1.330000 );
                                    var idjustificationLetterMinimum = stringIDToTypeID( "justificationLetterMinimum" );
                                    desc86.putDouble( idjustificationLetterMinimum, 0.000000 );
                                    var idjustificationLetterDesired = stringIDToTypeID( "justificationLetterDesired" );
                                    desc86.putDouble( idjustificationLetterDesired, 0.000000 );
                                    var idjustificationLetterMaximum = stringIDToTypeID( "justificationLetterMaximum" );
                                    desc86.putDouble( idjustificationLetterMaximum, 0.000000 );
                                    var idjustificationGlyphMinimum = stringIDToTypeID( "justificationGlyphMinimum" );
                                    desc86.putDouble( idjustificationGlyphMinimum, 1.000000 );
                                    var idjustificationGlyphDesired = stringIDToTypeID( "justificationGlyphDesired" );
                                    desc86.putDouble( idjustificationGlyphDesired, 1.000000 );
                                    var idjustificationGlyphMaximum = stringIDToTypeID( "justificationGlyphMaximum" );
                                    desc86.putDouble( idjustificationGlyphMaximum, 1.000000 );
                                    var idhangingRoman = stringIDToTypeID( "hangingRoman" );
                                    desc86.putBoolean( idhangingRoman, false );
                                    var idburasagari = stringIDToTypeID( "burasagari" );
                                    var idburasagariNone = stringIDToTypeID( "burasagariNone" );
                                    desc86.putEnumerated( idburasagari, idburasagari, idburasagariNone );
                                    var idpreferredKinsokuOrder = stringIDToTypeID( "preferredKinsokuOrder" );
                                    var idpushIn = stringIDToTypeID( "pushIn" );
                                    desc86.putEnumerated( idpreferredKinsokuOrder, idpreferredKinsokuOrder, idpushIn );
                                    var idtextEveryLineComposer = stringIDToTypeID( "textEveryLineComposer" );
                                    desc86.putBoolean( idtextEveryLineComposer, false );
                                    var idtextComposerEngine = stringIDToTypeID( "textComposerEngine" );
                                    var idtextLatinCJKComposer = stringIDToTypeID( "textLatinCJKComposer" );
                                    desc86.putEnumerated( idtextComposerEngine, idtextComposerEngine, idtextLatinCJKComposer );
                                desc85.putObject( idparagraphStyle, idparagraphStyle, desc86 );
                            list15.putObject( idparagraphStyleRange, desc85 );
                        desc71.putList( idparagraphStyleRange, list15 );
                        var idkerningRange = stringIDToTypeID( "kerningRange" );
                            var list16 = new ActionList();
                        desc71.putList( idkerningRange, list16 );
                    desc70.putObject( idT, idTxLr, desc71 );
                executeAction( idsetd, desc70, DialogModes.NO );
                // Sample usage code
                var doc = app.documents.add(5, 7, 300);
                titem.size = new UnitValue("50", "pt");
                if (titem.size.as("pt") != 50) {
                  PSCCFontSizeFix.setFontSize(layer, 50);
                alert(titem.size);
                • 5. Re: Re: Did CC 2014.2 break textItem.size?
                  Thanks, indeed this code yields text that is 50pt (actually, not quite)...
                  But I can't get it to integrate with an existing script. When the .setFontSize() method is called, nothing else happens. The method itself also has no result. In fact, replacing that line with "exit;" has the same effect.
                  There is lots of other stuff going on in the script, but this is the first operation performed on this specific text layer as you specified.
                  Any ideas? Or do we just wait for Adobe to fix it?
                  • 6. Re: Did CC 2014.2 break textItem.size?
                    matias.kiviniemi Level 3
                    Not exactly your question since I've never tried to set it, but reading the text size is a known challenge.. The thing is that text_item.size does not include the transforms either in the object or in the document. So you have to check if there are transforms and calculate result. I have the following code for doing that
                    getTextSize: function (text_item) {
                      return Math.round(text_item.size*getTextScaleHorizontal()) // .size is a unit value and we want to round it first to a regular number
                    getTextScaleHorizontal: function () {
                      var ref = new ActionReference()
                      ref.putEnumerated( charIDToTypeID("Lyr "), charIDToTypeID("Ordn"), charIDToTypeID("Trgt") )
                      var desc = executeActionGet(ref).getObjectValue(stringIDToTypeID('textKey'))
                      if (desc.hasKey(stringIDToTypeID('transform'))) {
                      var transform = desc.getObjectValue(stringIDToTypeID('transform'))
                      var mFactor = transform.getUnitDoubleValue (stringIDToTypeID('yy'))
                      return mFactor
                      return 1
                    • 7. Re: Did CC 2014.2 break textItem.size?
                      xbytor2 Level 4
                      I can't log in to the PS/JS forums website. When I can, I'll provide a
                      response.
                      • 8. Re: Did CC 2014.2 break textItem.size?
                        Tom Ruark Adobe Employee
                        We are working on a fix for this issue.Use Action Manager code to set the entire text descriptor as shown above in the meantime.
                        • 9. Re: Did CC 2014.2 break textItem.size?
                          xbytor2 Level 4
                          Cross-posted from ps-scripts.com:
                          2014 TextItem.size bug
                          Postby xbytor » Wed Oct 08, 2014 6:06 pm
                          Text is contained in a TextItem object. One of it's it's attributes is 'size' for the font size.
                          You can set it like this:
                            textItem.size = UnitValue(50, "px");
                          or
                            textItem.size = UnitValue(15, "pt");
                          The problem in the current rev is that regardless of what you set the font size to, it will always stay 12 px. So, if your rez is 72 ppi, the font size is 12 pts. If your rez is 300 ppi, your font size will be 2.83 pts.
                          My fix was to use low-level ActionManager code from the ScriptingListener plugin. The one problem is that setting the size will bash the font, contents, and several other attributes so you need to set the size immediately after creating the layer.
                          My fix has been added to xtools and can be found here:
                          This code is cleaner than raw ScriptListener plugin output.
                          1 person found this helpful
                          • 10. Re: Re: Did CC 2014.2 break textItem.size?
                            Rune L-H Level 1
                            Hi, this also seems to work, at least in CC 2014. I haven't tested it fully, but it's shorter and doesn't seem to affect content or other text properties. That being said, I still hope Adobe gets a fix out fast for textItem.size
                            var changeTextSize = function(newSize){
                                    var desc23 = new ActionDescriptor();
                                        var ref6 = new ActionReference();
                                        var idPrpr = charIDToTypeID( "Prpr" );
                                        ref6.putProperty( idPrpr, idTxtS );
                                        ref6.putEnumerated( idTxLr, idOrdn, idTrgt );
                                    desc23.putReference( idnull, ref6 );
                                        var desc24 = new ActionDescriptor();
                                        var idtextOverrideFeatureName = stringIDToTypeID( "textOverrideFeatureName" );
                                        desc24.putInteger( idtextOverrideFeatureName, 808465458 );
                                        var idtypeStyleOperationType = stringIDToTypeID( "typeStyleOperationType" );
                                        desc24.putInteger( idtypeStyleOperationType, 3 );
                                        var idPxl = charIDToTypeID( "#Pxl" );
                                        desc24.putUnitDouble( idSz, idPxl, newSize );
                                    desc23.putObject( idT, idTxtS, desc24 );
                                executeAction( idsetd, desc23, DialogModes.NO );
                            • 11. Re: Did CC 2014.2 break textItem.size?
                              xbytor2 Level 4
                              I recognize your superior solution and will use it instead of mine. Thanks.
                              BTW, magic numbers like '808465458' give me the willies
                              • 12. Re: Re: Did CC 2014.2 break textItem.size?
                                Rune L-H Level 1
                                Yep, agree on the willies But then again, most AM code does that to me.
                                Btw, thanks for all your contributions to the scripting community. Much appreciated!
                                • 13. Re: Re: Did CC 2014.2 break textItem.size?
                                  Mikaeru69 Level 3
                                  It might be a coincidence, or some kind of private joke, but this magic number could be related to the meaning of life, since it is equal to:
                                  charIDToTypeID ("0042")
                                  • 14. Re: Did CC 2014.2 break textItem.size?
                                    Jeffrey Tranberry Adobe Employee
                                    This should be fixed in the 2014.2.2 update released tonight. Choose Help>Updates... to install.
                                    • 15. Re: Did CC 2014.2 break textItem.size?
                                      JJMack Most Valuable Participant
                                      Yes version 15.2.2 seems to have fixed this and background eraser problem that's been bugging me.   I wish the Adobe would reconsider their decision to implement the ESC key the wrong way for only the text tool and do the correct way. Esc should cancel text tool current use like it does other tools.  Why in the world does Adobe think doing it wrong is better then doing it right??????
                                      • 16. Re: Did CC 2014.2 break textItem.size?
                                        Awesome! I tried to change this to the correct answer, but it won't let me for some reason.
