Could you, please, answer the following question:
is there a possibility to create a Book TOC, as it can be done for topics Insert Placeholder -> Topic TOC, for example.
Many thanks)
Yes. You can use bookmarks in your topic and add these to the TOC. Once the bookmarks have been created, you right click in the TOC and use the New > Page menu item to navigate to the bookmark. Just make sure you save your bookmarked topic before doing so or else you won't be able to find the bookmarks.
Thanks, but... we have probably misunderstood each other
Lets suppose the Table of Contents is created already. There is a tree: 1 book and 3 pages. Is there a possibility to create some placeholder within book topic, where these three subtopics will be shown (with hyperlinks) and automatically updated on these subtopics names update.
So that on opening the book page, the user could select the subtopic he is interested in (not in the Table of Contents, but within the book topic body).
OR can these 1 book and 3 pages be treated as 1 topic? In this case, the solution is very simple - just to use the Topic TOC placeholder option...
I think your later option is the way to go. I am not aware of any other to do what you want.
Hi there
In the RoboHelp TOC designer, you have some icons at the top as shown below:
I believe if you choose to click and insert a TOC Placeholder, you will get what you are seeking. You configure the Placeholder to point to a different TOC.
Cheers... Rick
Of course, you will have to create a different TOC to have what you want inside it.
Cheers... Rick
Thank you much for your concern!
but, again (I feel I have to improve my explanatory skills )... as a result, I want to achieve the following:
1) Contents view:
Book_1
Page_1_1
Page_1_2
2) Main body: on selecting "Book_1" from the TOC, the user can see the Book_1 topic text + something like In this topic section, listing the Page_1_1 and Page_1_2 names with hyperlinks.
PS: I just want these three topics to be opened separately (not as one topic), but with the possibility for the user to reference to the subtopics from the main one
Maybe you just need to add some form of navigation. For example a hyperlink, related topics, see also, etc.
Hello again
It sounds as if you simply want to have a book that not only expands to show topics, but also presents a topic in the topic pane when it is clicked? And the topic that appears should have information about the book with links that also point to the same place the pages inside the book in the TOC point?
If so, that's easy. Just create a topic and add the information. Then right-click the Book and choose Properties. Once you do that you should see a "Book with link" option. Once you enable that, you then choose the topic to link the Book to.
Cheers... Rick
