Will Edge Reflow be usable?
signaledesign Jul 10, 2013 12:15 AMAn exciting tool however the Preview version doesn't suggest that it will be a fully fledged tool for mockingup or creating responsive design.
A few of the things I have noticed:
• The limit of 16 columns creates problems for anything that required more. While the settings can be adjusted and you can play with Gutters and margins, these are a work-around that create other problems.
• There seem to be a few bugs such as the inability to select the breakpoint + pulldown menu to name and adjust dimensions
• Setting dimensions for one breakpoint sometimes carry over into other breakpoints automatically. I understand that you are meant to click the button that appears "Apply property to all regions". It is also limited when attempting to create very realistic rules such text that is 90% wide but not exceeding 400px - it usually coverts the 'size' to different percentage or a px width and carries through various 'properties' into other breakpoints.
• With changes to an object, it would be useful if multiple properties are changed to apply all changes to all regions, rather than have to click each individual property. Like-wise for a group of object should inherit identical properties.
* The percentages are not working well. If I set a margin to 10% for example and select a box or text field, why will it then display 9.86% on the object? (the percentage changes slightly when the page is expanded / closed). This also happens on some object sizes. It is frustrating when object are aligned and are not touched or interferred with by any other settings suddenly lose their global settings and develop individual settings with their own new dimentsions.
• Alignment is a challenge, If I create a box and drag it to align, the magnetic/snap-to alignment function works however it is never 0%, it is always a fraction such as 0.4% and has to be corrected each time in the properties. And if chaning to pixel dimensions, I have had it change to percentage.
• Generally the tactile feedback for the application needs to be improved - basic things like hover / mouseover effects that are standard in adobe software.
My primary use currently is mockups however was still interested in reviewing the code with the developers, though will have to hold off on this.
The functionality for viewing breakpoints is good as well as the colour coding though care needs to be taken to avoid accidently deleting - a popup would be good.
