1. Re: changing "Multi Folio with iTunes Subscription" to "Multi Folio"
Lohrii Alo Oct 8, 2014 9:06 PM (in response to meghillman)Application loader won't allow the new binary to be uploaded because features previously offered in your app is removed. It'll have to go as a separate app if you want it to be just multi issue.
2. Re: changing "Multi Folio with iTunes Subscription" to "Multi Folio"
meghillman Oct 9, 2014 8:58 AM (in response to Lohrii Alo)I understand it will be an separate app, outside of newsstand. But what happens to the old subscribers? Do they get reimbursed by apple for the remainder of their subscription?
And are you saying i'd have to create a "new" app completely? I can use the same app ID and certificates?
3. Re: changing "Multi Folio with iTunes Subscription" to "Multi Folio"
Lohrii Alo Oct 9, 2014 5:46 PM (in response to meghillman)Not sure about the reimbursement or refund, you need to talk to Apple about it
- Yes you will create a new app from DPS App builder because you cannot edit an existing app type.
- You cannot use the same App ID/certificates because it's being used by the existing live app. In other words, every app uses it's own unique app id
4. Re: changing "Multi Folio with iTunes Subscription" to "Multi Folio"
meghillman Oct 14, 2014 12:29 PM (in response to Lohrii Alo)Right— i will have to create a "new" app vs editing a current version.
But I should be able to use the same ID and certificates—the whole purpose is to remove the newsstand app with the multi folio app. Same magazine, just a different location.
Will follow up with apple about the reimbursement/refund situation.
Thanks.
