1. Re: Adobe Audition Interchange folder has gigabytes of files
ryclark Sep 7, 2013 4:40 AM (in response to Megawatson.com)I don't see any folder like that on my Audition only PC (no premiere Pro) so I suspect that it may be a Premiere thing rather than Audition.
2. Re: Adobe Audition Interchange folder has gigabytes of files
Megawatson.com Sep 7, 2013 11:52 PM (in response to ryclark)It is definitely a Creative Suite interaction issue, as you have to be sending something to Audition from elsewhere, so it's likely fair to blame Premiere, but that is not where the leftover folder lives. (I've also sent Captivate files to Audition and returned them with great results and no leftover files.)
I was hoping that any edits that may be in these folders were reflected in the Premiere project folders and not just referenced back to the Interchange folder, or at the very least copied into my archive when I Project Manager-backed it up ....
So how are Audition edits saved in Premiere? The answer:
This article goes over the differences between:
1) "Edit Clip in Audition" (a round trip process that automatically brings it back into Premiere and updates the file there)
or
2) editing sequences (not updated unless you export from Audition and import back to Premiere - this can be done inside the programs: After editing, choose Multitrack > Export to Premiere Pro, and in Premiere follow the dialog to Copy tracks from Audition and place them in the project
http://www.macprovideo.com/hub/premiere/essential-tips-for-premiere-editors-working-with-a udition
In my case I am confident that I used "Edit Clip" because I was quite thrilled about the feature, and actually after I was done editing, polished it in Multitrack with the second method!
So I can safely delete these files, presuming a Premiere crash or ill-timed closure caused them not to be deleted automatically.
3. Re: Adobe Audition Interchange folder has gigabytes of files
Alan Craven Oct 10, 2014 8:41 AM (in response to Megawatson.com)I have been looking for a solution to this problem, and found a solution.
The Adobe Audition Interchange folder is created when you select "Edit clip/sequence in Audition" from within Premiere, as ryclark suggested. If you are not careful, you can fill up your C: drive with gigabytes of files quite quickly as the Op discovered
When you click on this command in Premiere, you are given an opportunity to place the folder (which will contain the large extracted audio files) in a location of your choice. The default is not the best choice for me, as it is on the C: drive, but where you choose will depend on how you set up your projects. I keep all my media files in a folder for each project, on a separate media drive, so I choose to place these files in the Audio Files folder within the overall project folder on that drive.
These files which are created replace the original audio in the Premiere project, so they must be left where they are while ever the project is required. Once the project is no longer required, they can be deleted along with the rest of the media.
