1. Re: Quiz answer and buttons will not show in Presenter 10 and publishing problem
Jorma Jennings Oct 13, 2014 3:24 PM (in response to adam_hu)Problem #1 seems to come up when there is a corrupt slide in the deck. I'm not 100% clear on what makes a slide corrupt, but you may have to start breaking your presentation a part in to smaller groups of slides and publishing until you can identify which slide(s) is(are) the problem slides. Then, once you have identified them, recreate them and republish the presentation as a whole.
I find that splitting the presentation in half makes the fastest work of finding the corrupt slides. If you take the first half and it publishes fine, then the corrupt slide is in the second half. Split the second half again and see if you get the corrupt slide in your portion of the presentation. Eventually you will be able to identify the corrupt slide(s).
As to the previewing issue, If you aren't seeing it in the published version, then I'd just chalk it up to the personality of previewing the presentation. I've yet to see a preview tool for any product that gives a 100% accurate representation of the actual output.
2. Re: Quiz answer and buttons will not show in Presenter 10 and publishing problem
alpi agarwal Oct 17, 2014 2:59 AM (in response to adam_hu)Could you please let us know the Powerpoint version you are using ?
Is it office 2007 or 2010 ?
Alpi Agarwal
Adobe Presenter Engineering Team
