Show 1 reply
1. Re: Visibility bug with layers nested inside groups
MitchHendrickson Oct 13, 2014 11:24 AM (in response to krios21)Hi krios21-
The top level visibility should certainly override any child layers, but there have recently been some issues with computing the right visibility when various blend modes and the like are used. It's very likely that your issue is already fixed but not yet deployed. If you would like to share the file, either publicly or privately to me via PM or mhendric (at) adobe.com, I can confirm that for you (and if not, I need to get right on fixing it :-).
-Mitch
P.S. You may find that, toggling some specific layers on and off causes it to fix itself. In that case, it is even more likely you've hit the condition I'm describing. It's also a way to work around the issue (even though it's inconvenient).
