1. Re: Single Dev Environment and Code Line for 6 and CC?
DBarranca Oct 14, 2014 4:51 AM (in response to mlavie)Hi,
I can't speak about InDesign for the HostAdapters, but for the total re-write of all your code part... I guess you're right. If you're going to support both Flash and HTML panels, you need to develop them independently (at least for the panel itself - the actual scripting can be moved easily).
Have you checked here for the adapters? Adobe CEP Resources by Adobe-CEP
Davide Barranca
www.davidebarranca.com
www.cs-extensions.com
2. Re: Single Dev Environment and Code Line for 6 and CC?
mlavie Oct 14, 2014 5:38 AM (in response to DBarranca)Hi Davide,
Thanks for the response.
If I may ask a follow-up question:
All our code was written in ActionScript. I'm talking tens of thousands of lines of code in ActionScript. To support CC 2014 and later, must we rewrite all our code from scratch - converting it manually to JavaScript?
TIA,
mlavie
3. Re: Single Dev Environment and Code Line for 6 and CC?
GeghamB Oct 14, 2014 10:51 AM (in response to mlavie)Hi mlavie,
You're no need to rewrite tens of thousands code.
You are free to use any UI framework that suits your needs.
As I understood, Adobe supporting only Photoshop HostAdapter in Extension builder 3 for now, so in any case, in my opinion, only HTML will not give a solution to your problem.
Instead you can write your own "HostAdapter" using Adobe Illustrator CC 2014 SDK, and connect it with your (Flash/Flex)extension. (check samples with Notifiers, it will help)
According to InDesign, It's strange, because everything works smoothly for me. Can you write more detailed about that?
ps, sorry for bad English.
Best Regards,
Gegham
