1. Re: Adobe Edge CC 2014.1 bugs!!!
vivekuma Oct 6, 2014 9:34 PM (in response to adbobesuckballs)Can you share the composition for us to test it out?
2. Re: Adobe Edge CC 2014.1 bugs!!!
adbobesuckballs Oct 6, 2014 9:52 PM (in response to vivekuma)Sure if I try to move the top 4 layers (sorry div's) under the "scrubber" div then it crashes.
See file here...
3. Re: Adobe Edge CC 2014.1 bugs!!!
jesscmoore Oct 6, 2014 10:46 PM (in response to adbobesuckballs)I also got the same message when working on a motion path. I deleted the path and started over. Thank goodness my original version was saved. Terrible update, not the only problem I am experiencing.
4. Re: Adobe Edge CC 2014.1 bugs!!!
Phildsb Oct 7, 2014 2:27 AM (in response to jesscmoore)I agree, very poor update. Renaming symbols in the Symbols palette causes them to lose all their content. Deleting an image from the images folder resulted in the C++ error shown above. If I can roll back to the previous release I will, as its impossible to work with this one
5. Re: Adobe Edge CC 2014.1 bugs!!!
adbobesuckballs Oct 7, 2014 5:50 PM (in response to adbobesuckballs)Can't invert transitions either (because it then gives those errors), and sometimes when saving a file it exits you out of the symbol you were working in and up onto the main stage.
Any update on my file and if it was doing the same thing for you too vivekuma?
6. Re: Adobe Edge CC 2014.1 bugs!!!
adbobesuckballs Oct 7, 2014 6:01 PM (in response to adbobesuckballs)Importing certain svg's also import at a width and height of "auto" and can't be changed to any other dimensions.
Classic reason why Adobe needs the option for us consumers to be able to backtrack to a previous version of software!!! Edge unfortunately is beginning to become quite a pain to use.
7. Re: Adobe Edge CC 2014.1 bugs!!!
heathrowe Oct 7, 2014 7:53 PM (in response to adbobesuckballs)I have a suspicion if you have non special character (initial character) in your file names it would be smother.
Darrell
8. Re: Adobe Edge CC 2014.1 bugs!!!
adbobesuckballs Oct 7, 2014 8:49 PM (in response to heathrowe)but I guess my question is why all these issues with this new update when before with the same names it was working fine?
9. Re: Adobe Edge CC 2014.1 bugs!!!
LionKing007 Oct 8, 2014 6:33 AM (in response to adbobesuckballs)Hi adobesuckballs
I also wanted the previous version of EA to be available for my work. I could download it from creative cloud page for EA. It has a dropdown which has EA 2014.1 (which is the Max Release) and EA 2014 (which is the previous version). I could install EA 2014 and it does a side by side install with both versions coexisting. You can try this if you are a paid user. It did work for me!!!
10. Re: Adobe Edge CC 2014.1 bugs!!!
rossfranks Oct 8, 2014 3:28 PM (in response to LionKing007)Wow seems like someone's hacked this forum, because my username has been changed to adbobesuckballs but yeah LionKing007 I've downloaded the older version but it wont open the new 2014.1 file i have been working on, so now I got to see if i can copy and paste back into 2014
11. Re: Adobe Edge CC 2014.1 bugs!!!
jesscmoore Oct 8, 2014 3:43 PM (in response to rossfranks)Thanks for the heads up that you can download the older version.
Sorry for the hack. (although for this situation, the username kinda fit, despite how much I do love their software!!)
12. Re: Adobe Edge CC 2014.1 bugs!!!
resdesign Oct 8, 2014 5:17 PM (in response to jesscmoore)i was wondering about this not so polite handle!I Not my kind of language, I have to say. Hope you get this resolved!
13. Re: Adobe Edge CC 2014.1 bugs!!!
rossfranks Oct 8, 2014 5:22 PM (in response to resdesign)yeah not mine either, so i've had my username and password changed, so here's hoping it doesn't happen again
14. Re: Adobe Edge CC 2014.1 bugs!!!
Vinod Menon@Adobe Oct 8, 2014 11:13 PM (in response to rossfranks)Hi Rossfranks,
Are you saying that the content you have developed in CC 2014.1, could not be opened in CC 2014? Yes, this is possible because in this release we have moved to new runtime which does not have dependency on jquery and we have also redesigned the runtime to reduce its size. This was one of main goals in this release. Based on this change there are changes in JSON format in 'an' file. There are some structural changes in the JSON format. There is a hack some of you have suggested to change the version to 4.0 in JSON file. It may work, but we will not be able to assure you
Regards
VinodEdge Animate Team
15. Re: Adobe Edge CC 2014.1 bugs!!!
LARV Oct 8, 2014 11:36 PM (in response to adbobesuckballs)I knew it! Thank god I haven´t updated my version. With all the problems in Edge so far I had the feeling the new version would just make things worse. I´ll update in a year or so. If Adobe hasn´t fixed the major issues by then, like the placing of texts being some sort of random event, I´ll quit my subscription.
16. Re: Adobe Edge CC 2014.1 bugs!!!
Vinod Menon@Adobe Oct 8, 2014 11:45 PM (in response to LARV)Hi LARV
" placing of texts being some sort of random event" . Can you elaborate on the issue you are facing? Are you alluding to usage of inline text?
Regards
Vinod -
17. Re: Adobe Edge CC 2014.1 bugs!!!
SimonCamilo Oct 8, 2014 11:50 PM (in response to adbobesuckballs) -
18. Re: Adobe Edge CC 2014.1 bugs!!!
LARV Oct 8, 2014 11:51 PM (in response to Vinod Menon@Adobe)Hi,
What´s "inline text"? Yes, I write some of the texts in Edge, they often change placing in preview, as well as the distance between to "rows" (sorry, I don´t know these terms in english). Some texts I import from Illustrator as vector blocks, objects in other words. They always work correct.
Do you have a simple solution?
19. Re: Adobe Edge CC 2014.1 bugs!!!
adbobesuckballs Oct 9, 2014 2:52 AM (in response to SimonCamilo)Exactly what I'm getting too Simon! Amongst all the other things I've mentioned
20. Re: Adobe Edge CC 2014.1 bugs!!!
vimster303909 Oct 9, 2014 3:59 AM (in response to adbobesuckballs)hi;
getting a lot of these errors too + also getting javascript errors suddenly that corrupt files that won't open anymore!
It does seem like a very buggy update.
frustrating.
j
21. Re: Adobe Edge CC 2014.1 bugs!!!
rossfranks Oct 9, 2014 3:56 PM (in response to adbobesuckballs)yay seems my user name has been changed again, hooray for security on these forums!
22. Re: Adobe Edge CC 2014.1 bugs!!!
fgkeam Oct 10, 2014 5:17 PM (in response to adbobesuckballs)I have experienced multiple issues which are nigh impossible to pin down as elements seem to silently disappear/reappear for no reason. I believe that content created in Edge Animate 2014.1 works fine but any content upgraded from the previous version is unreliable. Here's an example of a composition with a button symbol that crashes Edge like it does in the OP when you try to delete keyframes in the symbol's timeline. I have done nothing unusual with this composition other than create it in 2014 and upgrade it using the normal procedure in 2014.1 ThisBreaksEdge.zip - Google Drive
23. Re: Adobe Edge CC 2014.1 bugs!!!
jesscmoore Oct 13, 2014 8:40 AM (in response to rossfranks)Hi RossFranks,
I was wondering where you were able to download the earlier version? Thanks.
24. Re: Adobe Edge CC 2014.1 bugs!!!
vivekuma Oct 13, 2014 9:11 AM (in response to jesscmoore)Goto page @ https://creative.adobe.com/products/animate
Then select Animate CC (2014) from dropdown selector, and download and install.
25. Re: Adobe Edge CC 2014.1 bugs!!!
npaskaleva Oct 13, 2014 6:07 PM (in response to adbobesuckballs) -
26. Re: Adobe Edge CC 2014.1 bugs!!!
Dharmendra Kumar Oct 14, 2014 8:21 AM (in response to rossfranks)Hi rossfranks,
We are looking into these issues. btw, this is with respect to your earlier post:
You should have the original file intact and you should be able to open the same in the previous version. The upgraded file gets saved into a new folder <projectName>_upgraded, which will not open in the earlier versions. However, if you try to open the file from the folder <projectName>, then it will work in earlier versions.
Dharmendra
27. Re: Adobe Edge CC 2014.1 bugs!!!
rossfranks Oct 14, 2014 3:33 PM (in response to Dharmendra Kumar)Yeah I think we've figured that out Dharmendra Kumar I think what most of us want to know is what is going on with all these other issues in this update.
28. Re: Adobe Edge CC 2014.1 bugs!!!
tjwaller Oct 24, 2014 5:32 AM (in response to Phildsb)You can. Although no one at Adobe is offering up this information. I guess they just want us to suffer through this crappy update.
Anyway, go to https://creative.adobe.com/products/animate and follow my attached pictorial instructions. I uninstalled 2014.1 first, but I don't know if you actually have to do that. I did it because 2014.1 is useless in it's present form.
30. Re: Adobe Edge CC 2014.1 bugs!!!
aqmikc Oct 30, 2014 1:48 AM (in response to aqmikc)Anyone get this ?
31. Re: Adobe Edge CC 2014.1 bugs!!!
vivekuma Oct 30, 2014 1:55 AM (in response to aqmikc)I tried with files you have shared in the post how to replay entire composition including video and other animation in edge animate cc 2014.1
I didn't face this issue, is there any specific scenario when you see this message.
32. Re: Adobe Edge CC 2014.1 bugs!!!
aqmikc Oct 30, 2014 1:59 AM (in response to vivekuma)strange but after i moved the contents to a new folder. It saves the file and i dont get the message. I will try it again.
