7 Replies Latest reply on Apr 29, 2018 4:32 PM by Monika Gause
    Resizing a Raster Image in Illustrator
    Elisabetta S Level 1
      Hi all,
      I have noticed that whenever I import a raster image into Illustrator and try to downsize it, the image loses quality.
      No matter what I do, if the image is raster it will always have that issue when resized, so I tend to do either one of these two things:
      1. Resize it in Photoshop first
      2. Forget about it and do the whole thing in InDesign and import the vector/raster elements within InDesign
      I just want to stress once more that I am reducing the size of the image, not enlarging it.
      So here is the question, is there a way to resize a raster image in Illustrator properly, or should I just not even try (as I am doing) and just accept that as a vector program, its kryptonite is raster imagery?
      Thanks in advance!
        • 1. Re: Resizing a Raster Image in Illustrator
          sishamDSS Adobe Community Professional & MVP
          Quick question, have you embedded the image before you resize it? If not then try that.
          Here is a screenshot of how if you are unsure:
          • 2. Re: Resizing a Raster Image in Illustrator
            Hi there
            Yes I have. the problem doesn't lie in the embedding though, as even when I open the image in Illustrator and edit it I get the issue.. You can see it less with photos like the one you have posted there, but if resize an image with lineart or text especially, or even the cut out of a person, you will start seeing some jagged edges here and there. If I resize directly in Photoshop the whole thing looks smoother.
            I attached an example of what I am talking about. The edge of the card looks jagged even before it gets resized. Once it's sized down the text becomes jagged too. When I resized in Photoshop, the hard lines of the text (obviously the part that is in focus) remained crisp.
            Sometimes clients might send me logos in raster format and they can't provide anything else (you know, JPG or PNG), and I found that the only way I could get around this issue was to stick everything in InDesign and resize there, or resize in Photoshop.
            • 3. Re: Resizing a Raster Image in Illustrator
              You may find that this is just how illustrator renders the raster image and when you actually output the artwork that the end result is as it should be. Here is a post on a similar issue: Placed high res bitmap in Illustrator not smooth, but jagged
              I just did a test with a .png transparent background image and looked jagged on-screen but when I outputted it as a pdf it looked fine...?
              I just think illustrator doesn't process raster very well..?
              I hope some of this helps, sorry I can't do anymore.
              someone in the post also states a good point that if you embed the artwotk it can then make it difficult to make any changes, etc.
              • 4. Re: Resizing a Raster Image in Illustrator
                qwertq73677868 Level 1
                This is because Unlike Photoshop, illustrator Don't "Resample" Image i.e Re-sampling involves Interpolation Techniques to Define Additional Pixels when an Image is Resized, common interpolation techniques are Bicubic (used by Photoshop), Linear etc.
                Illustrator is Doing the Same work Photoshop do if we Uncheck the Resample checkbox in the Image Dialogue Box (at Image>Image Size) while Resizing.
                Since illustrator doesn't implemented a Interpolation Technique, so it has to maintain Same Amount of Pixels, i.e If you Increase Dimensions, Resolution (PPI) will Decrease (and vice versa) to Compensate.
                • 5. Re: Resizing a Raster Image in Illustrator
                  Test Screen Name Most Valuable Participant
                  But why would it be creating extra pixels when we make the image smaller?
                  • 6. Re: Resizing a Raster Image in Illustrator
                    (Nop, while Reduction it Deletes some Pixels on Photoshop.)
                    Photoshop (while Resample is Checked) needs Additional Pixel for Enlargement and in case of Reduction it Deletes Pixels.
                    While Illustrator don't Add or Delete any Pixel, in fact it can't. (It could be a Feature Request to add Interpolation Technique in illustrator)
                    • 7. Re: Resizing a Raster Image in Illustrator
                      Monika Gause Adobe Community Professional & MVP
                      Illustrator can resample images.
                      You could use either the new crop feature or you could use the Object > Rasterize command.
                      Crop images in Illustrator
                      I would not recommend either of them for production-ready resampling, because you still need decent sharpening after resampling.
