1. Re: Problems with Creative Cloud (apps not starting)
andy-mario Jul 1, 2013 1:15 PM (in response to andy-mario)UPDATE:
After a phone call with support, as suggested I uninstalled/reinstalled Creative Cloud Desktop and Illustrator CC, but the problem is still there. Illustrator sometimes will start, but after several minutes of splash screen and spinning wheel and if no other adobe app is running. Other apps (daily use) like Photoshop, After Effects, Premiere, Speedgrade, Media encoder, are working correctly.
2. Re: Problems with Creative Cloud (apps not starting)
GaudiumMagnum Jul 1, 2013 3:15 PM (in response to andy-mario)I have a similar problem with Photoshop.
Maybe your firewall is blocking outcoming traffic from Illustrator?
If you have any, try to disable antivirus or firewall, and make a test. -
3. Re: Problems with Creative Cloud (apps not starting)
andy-mario Jul 1, 2013 3:31 PM (in response to GaudiumMagnum)Thanks,
but no Antivirus, no Firewall are active.
I just found another thread that explained where the prefs file are in osx (user/library/Preferences/Adobe Illustrator 17), I deleted and restarted. Now Illustrator starts but takes a couple of minutes, and runs only if no other adobe app is started before Illustrator CC.
4. Re: Problems with Creative Cloud (apps not starting)
andy-mario Jul 2, 2013 12:54 AM (in response to andy-mario)Seems that deleting the preference folder (in osx it's in "user/library/Preferences/Adobe Illustrator 17 Settings") got me back on track.
Now Illustrator is launching correctly. I did also a system cleanup (permissions, caches etc...) and rebooted.Creative cloud desktop is working correctly after reinstalling.
5. Re: Problems with Creative Cloud (apps not starting)
8tracker Aug 3, 2013 9:12 AM (in response to andy-mario)Andy-Mario's fix of dumping preferences worked for me — so thanks!
However, I thought I would also list out the other problems I was experiencing in case it helps someone else.
I opened up a project in Illustrator and realized I hadn't activated a font (I use Suitcase Fusion, and my version's auto activation plugins aren't compatible with CC). So I quit AI, activated the font and relaunched Illustrator.
That's when my problems began.
I got a window asking me to login to CC. I hit the login button but got no login screen, only an end-user license agreement, which I agreed to. Then I got an advert window asking me to either seriialize the app or start a trial. As a CC subscriber for over a year, this seemed wrong: CC doesn't provide a serial number and, as a subscriber, I shouldn't have to do any trial version of anything.
I ended up initating a chat with Adobe support, which was useless. Their recommended fix was to activate the trial version which would, somehow, activate as a full version. I did this and the application did startup, but then the software was nearly unusable:
- VERY slow to open a document
- No transform handles on anything
- Unable to edit any object
- Unable to expand text boxes
- Unable to save
- When I changed something, the program didn't recognize anything had changed, so I couldn't save
- Couldn't quit the program
All this was corrected when I dumped preferences and restarted (Andy-Mario's fix: In OSX it's in "user/library/Preferences/Adobe Illustrator 17 Settings).
I blew a publication deadline because of the problems which required an apology to my client. So, add me to the list of other dissatisfied Adobe CC subscribers
Anyway, I hope this helps.
6. Re: Problems with Creative Cloud (apps not starting)
Subin ck Apr 28, 2014 2:39 AM (in response to andy-mario)Reinstall cc and install it again... It's working ok...
7. Re: Problems with Creative Cloud (apps not starting)
pattobin May 5, 2014 2:48 PM (in response to Subin ck)I can appreciate the frustration, it would seem the multiple log in options and the unbelievable slow connection makes the cc pretty much useless. Two days later
It answers the question why are the non cc versions available. I for one am going back to a product that can be registered and used off line. Wow beyond disappointed ....
8. Re: Problems with Creative Cloud (apps not starting)
AshPx72A May 6, 2014 12:11 PM (in response to pattobin)Pattobin, you've captured my total despair.
I am going to try again, so far have wasted at least 30 precious hours messing with this. My computer is brand new and I was so excited.
Now I am like a carpenter without a hammer. Every time I go to pound a nail the hammer head flies off.
9. Re: Problems with Creative Cloud (apps not starting)
RussOniMac May 17, 2014 6:45 PM (in response to andy-mario)I too had issues installing Adobe Creative Cloud app, starts then disappears from menu bar. Opened call with support they suggested after several attempts to fix it, including taking control of my Macbook Pro. Tech Support suggested creating another Admin Account, this worked I was able to install Adobe Creative Cloud app and download an app. Once I returned to my other Admin account the app was available Photoshop CC and I could run it, but that little app Adobe Creative Cloud did the same disappearing act, I'm sure Adobe will fix this (well I hope Adobe will fix this issue)
10. Re: Problems with Creative Cloud (apps not starting)
RussOniMac May 17, 2014 11:24 PM (in response to RussOniMac)UPDATE; Wow finally got Adobe Creative Cloud install. You won't believe it I created another Administrator account like I was instructed by TS.. I was able to install the application with this newly created administrator account. I then deleted that administrator account and behold Adobe Creative Cloud Application was available and working. Seems like the application disappeared because there was some attempt to login and failed seemed like the reason it disappeared. Anyway I just wanted to give an update. I'm sure Adobe will figure this out and I hope this helps Adobe to eliminate this problem.
11. Re: Problems with Creative Cloud (apps not starting)
lukewilkinsao2m May 19, 2014 5:05 AM (in response to andy-mario)This is absolutely ridiculous. I am at work and cannot download any of the Adobe products from the creative cloud? Why is it so difficult ? I should be able to log into my cloud and download? What the hell? This is an absolute joke!
12. Re: Problems with Creative Cloud (apps not starting)
james23432423 May 20, 2014 4:41 AM (in response to lukewilkinsao2m)agree. cant download them. apps screen just hangs
13. Re: Problems with Creative Cloud (apps not starting)
ecolivingcentre Jun 12, 2014 6:06 PM (in response to james23432423)I have same problem on a Windows PC, works fine on my desk top but Cloud app refuses to load on the laptop, but at least I can load Illustrator.
14. Re: Problems with Creative Cloud (apps not starting)
DivaGirl14 Jun 24, 2014 1:05 PM (in response to andy-mario)I had the same problem on iMac running Mavericks. I did these steps:
- Launched Activity Monitor app (Applications/Utilities) and deleted "Creative Cloud not responding..." from the list
- Used the Adobe Creative Cloud cleaner tool to delete the Creative Cloud app which is available on Adobe's website (CC uninstaller utility app did NOT work)
- Trashed the opm.db file in Library/Adobe/OOBE folder. Used my EasyFind app (available on iTunes Mac App Store - EasyFind) to find the opm.db file because it didn't show up by just opening the OOBE folder. (Plus, the search function with Mavericks sucks!)
- Downloaded the current Creative Cloud desktop app from Adobe.com, installed it ... and ... it worked!
15. Re: Problems with Creative Cloud (apps not starting)
rshilling Jun 27, 2014 4:08 PM (in response to andy-mario)ADOBE CREATIVE CLOUD is not ready for prime time...looks like they rushed to launch the platform before running sufficient real-world platform tests...I have wasted dozens of hours waiting for ridiculous user ID authorization scripts to run, etc.
Boot-up times for the CC apps are even WORSE than the CS6 suite...as if that were possible...
Who's gonna re-imburse me for my many hours of lost / wasted time?
Is Adobe going to reimburse me for the lost time...how about a few free months of fees until they get this nonsense sorted out?
16. Re: Problems with Creative Cloud (apps not starting)
crewmark Jul 1, 2014 4:13 PM (in response to rshilling)This is bloody pathetic... CC2014 just hangs... worked for a couple of days now nothing works... so am I supposed to uninstall everything and then download Gbs of files AGAIN!!!! I agree with rshilling... IS ADOBE GOING TO REIMBURSE ME FOR THE TIME AND BANDWIDTH TO FIX THEIR FU SYSTEM??!!
17. Re: Problems with Creative Cloud (apps not starting)
Roman Villarreal Jul 7, 2014 2:34 PM (in response to DivaGirl14)This worked for me. Thanks!
18. Re: Problems with Creative Cloud (apps not starting)
Stebo Jul 26, 2014 4:45 AM (in response to ecolivingcentre)Same problem here, works fine on my desktop but on my lap (Surface 2 pro) the app starts but the windows are empty. I have been in contact with the Adobe support but without any sucsess. Really frustrating!
19. Re: Problems with Creative Cloud (apps not starting)
crewmark Jul 27, 2014 2:38 PM (in response to Stebo)I still have the problem of the updates wanting to reinstall every day but the problem you have Stebo may have been the other problem I was having.
Log out of creative cloud totally on your desktop and close all creative could applications. Then start up your laptop and see if it works. Same applies when you want to take it back to your desktop (you have to restart each time I found). Hope that helps.
20. Re: Problems with Creative Cloud (apps not starting)
Stebo Jul 28, 2014 1:33 AM (in response to crewmark)Hi Crewmark! Unfortunately that did'nt help. Since I've already been in contact with the support without getting any help it feels like I'm stuck. As far as I can see there seems to be quite a few peple with the same problem. I hopoe Adobe ccome up with a permanent solution to this mess soon as posible. Over and out
21. Re: Problems with Creative Cloud (apps not starting)
Katrina12345 Aug 5, 2014 11:53 AM (in response to andy-mario)Just had this issue with Illustrator CC not launching and found this solution. After uninstalling and installing, the preferences folder was empty. Boss found online that TURNING ON THE FONT VERDANA in the system fonts solved the problem. Sure enough, after turning Verdana on, the application launched.
22. Re: Problems with Creative Cloud (apps not starting)
mosubu Oct 7, 2014 9:21 AM (in response to andy-mario)Thank you Adobe for reading my mind!
When I woke up this AM, I thought, "wouldn't it be nice to have the latest CC Photoshop upgrade freeze my Mac upon launch"
OMG! Thank you SOOOOOOO much !
After numerous restarts, force quitting out of CC2014 launching, uninstalling, reinstalling, force quitting, manually dumping prefs, reinstalling, freezing, force quitting, making more coffee, uninstalling, reinstalling, watching the beach ball a bit longer, going out into the yard and feeding the birds, deciding 1100 AM is an OK time to start drinking tequila, i decided to use the "old" version of CC Photoshop which thankfully I hadn't dumped. Because somewhere in the back of my mind when the "new" version came out I knew I'd be typing this exact conversation somewhere. Now that I think of it, I'm going to copy this into a log so I can reuse it next time…..and there will be a next time, won't there Adobe ?
So a couple of hours later I"m now editing this image I need to deliver at 1 EST. Oh look ! Its effin noon time !
Again, Thank You !
I know this doesn't help anyone in the same boat, but without humor we'd be dead in the water.
23. Re: Problems with Creative Cloud (apps not starting)
chrisrey Oct 13, 2014 10:32 AM (in response to mosubu)I am running the latest version of Mavericks. I have plenty of computer power. InDesign CC opens. Photoshop CC opens. I have gone through whatever possible gyration has been presented. I am not at all sure what else to do. I am nearly ready to erase my whole computer and restore from a back up from a couple of days ago. I am feeling desperate. Any suggestions? When I look for preference folders and other files to delete, I am not finding them anywhere on my computer. Thoughts?
24. Re: Problems with Creative Cloud (apps not starting)
kcrossley Oct 15, 2014 9:10 PM (in response to andy-mario)For me, the problem seemed to have something to do with Suitcase. Once I updated to Suitcase Fusion to v16.2.5 everything seemed to work okay. But, to be fair I did repair my permissions first, so that may have had something to do with the as well. FWIW, I did not trash my AI preferences.
25. Re: Problems with Creative Cloud (apps not starting)
chrisrey Oct 15, 2014 10:01 PM (in response to kcrossley)Thank you for your response. I ended up calling support. They had me install the CC Cleaner tool. It fixed it right up.
