3 Replies Latest reply: Nov 6, 2014 2:39 AM by Eddie van Leeuwen RSS
    avoid automatic (?) rotation when combining multiple files into 1 pdf
    Eddie van Leeuwen Community Member
      As I do often have to mark up (stamp) and print large number of single A3 size pdfs (converted dwg files) I am combining them (explorer) into 1 new pdf. Thus enabling just 1 print job instead of 50-100 !
      So far no problem - combining works fine & all drawings are even landscape.
      However when applying custom stamp on each sheet (first time all the way in acrobat - all next sheets with copy - paste because:
      • much faster
      • often resizing required
      • sometimes even rotating required.
      Seems originally not "landscape" orientated files were (at least in the view) re-orientated causing the applied stamp to be 90 - 180 or -90 degrees offset
      When I manually remove the stamp on this page and insert a new one via Acobe Acrobat (not copy paste) the orientation is ok. Rather amazing.
      Got some more related questions but think 1 step at the time is more convenient.
      As often 50-100 dwg's are involved the copy-paste method (after resizing once) turns out most efficient till now.
      How can I control / avoid the automatic rotation or anticipate on the (obviously) rotating stamps ?
      I will have to move the stamps anyway because I can hardly ever put a stamp at the same position on a drawing.
      [It turns out to be almost impossible to get draughtsman to leave an empty space on each drawing ...]
      Once again thanks in advance for any suggestion !
