I have a one celled table with a background image. It's really just a gradient strip (gradient going from top to bottom - ending in fade to white). I want the image to continue all the way across the page. If I set it to repeat via X, somehow you can see where the repeat begins... so I was wondering if there's a way to just stretch the image from left to right to force it to fit exactly to 98% of the window no matter how big the window is.
Thanks...
kb
(RH10 for Webhelp)
Unfortunately there is no way to automatically stretch an image in HTML. An image is of a set size. You could manually stretch the image size in each table, but you'd be in danger of losing resolution. An alternative to stretching the image could be to make the background image to the size of your largest table, and change the colour gradient so that it fades to white before the size of your shallowist table. Hope this makes sense.
yep... totally makes sense... THANKS!
On Thu, Oct 16, 2014 at 9:40 AM, RoboColum(n) <forums_noreply@adobe.com>
That's not entirely true. With CSS, you can stretch a background image to any dimension:
background-size: 10px 100%;
Also see: CSS3 background-size property
Kind regards,
Willam
Thanks William! MOST HELPFUL!
On Wed, Oct 22, 2014 at 9:44 AM, Willam van Weelden <
