9 Replies Latest reply: Oct 27, 2014 9:00 AM by Lady_Madonna RSS
    Creative cloud is not syncing.
    wibble11 Community Member
      Creative cloud is not syncing. The files on my machine are missing many files that are online. Worse I cannot find how to recover the files, there seems no way to transfer back to my machine manually. It claims to be fully synced but it is not.
        • 1. Re: Creative cloud is not syncing.
          phase23
          I am experiencing the same issue and am searching for an answer.
          • 2. Re: Creative cloud is not syncing.
            Warner Harress Adobe Employee
            Hi Wibble11,
            Can you confirm that your all of your files are on creative.adobe.com under the Assets section?. Please send me your log files to harress@adobe.com.
            Your log files can be found in the following locations:
            Mac:
            /Users/<username>/Library/Application Support/Adobe/CoreSync
            Windows:
            C:\Users\<username>\AppData\Roaming\Adobe\CoreSync
            'Library' on Mac and 'AppData' on Windows are both hidden folders. Please read these pages for help on showing these folders:
            http://helpx.adobe.com/x-productkb/global/show-hidden-files-folders-extensions.html (Win)
            https://helpx.adobe.com/x-productkb/global/access-hidden-user-library-files.html (Mac)
            Warner
            • 3. Re: Creative cloud is not syncing.
              Hi phase23,
              Can you also please follow the instructions above and send me your CoreSync log file please?.
              Thank you
              Warner
              • 4. Re: Creative cloud is not syncing.
                phase23 Community Member
                I was able to restore CC functionality by signing out and signing back in. Though I also reinstalled CC, but my assumption is the sign-out based on another thread I read.
                Thanks for the follow up.
                ~ Jason
                • 5. Re: Creative cloud is not syncing.
                  There seem to be several ways to kick it back into action. I quit the app and then hid the home folder and when it restarted it synced correctly. The problem keeps reoccurring though so there is something more fundamental going on. I don't trust it with my files now so am using drop box.
                  • 6. Re: Creative cloud is not syncing.
                    Lady_Madonna Community Member
                    I am having the same trouble since few weeks. Local folders on cc-files look like being synced. When I look at "latest synced files" on topbar, I see, it is not true. I need to quit cc and open or install again, then cc sync at once. I do need to use another cloud service to be save in different locations.
                    Will send my log file and hope for an answer.
                    Regards.
                    • 7. Re: Creative cloud is not syncing.
                      kaisairanen
                      I have a similar problem: over the web I see files on cc, which never come over to the desktop. CC App says "All files up to date". Not true. I have tried to relauch the app. Does not help.
                      My team of three have problems with files syncing via cc all the time. Things that are a breeze via dropbox just do not work properly over cc. Would love to use cc, but is of no use for us yet.
                      Regards, Kai Sairanen
                      ps. will try to send log files - and hope for fixes.
                      pps. screenshots:
                      1. all files up to date
                      2. web view of cc folder with three documents and four foulders
                      3. file view of same cc folder on imac: three documents missing.
                      Screen Shot 2014-10-22 at 12.01.47.pngScreen Shot 2014-10-22 at 12.06.33.png
                      • 8. Re: Creative cloud is not syncing.
                        Hi Lady_Madonna & kaisairanen
                        I have had a look over your log files and this issue seems to be that you have double byte characters in use for some of your files names. Creative Cloud does not support this file naming as yet and is a known limitation. We plan to support this is a future release.
                        A work around for now is to rename your files to simple ASCII , not using double byte characters or multibyte Unicode characters.
                        Warner
                        • 9. Re: Creative cloud is not syncing.
                          Hi Warner,
                          the system doesnt care about names, I tested already. I do need to quit and reinstall CC and syncing starts immediately. Bevor the system looks like everything would be fine, but - looking at the web only the old files are there. There is more to be fixed.
                          Keep you updated, when I see what is going on at the other workspace I do use tomorrow.
                          Renate
                          Hi - on both workspaces I do have the same situation. CC is not working, I do need to quit and restart/install again. CC is working fine for a while. A few hours later CC falls asleep again. There is no signal, system says "all fine".
                          Hope this information is helpful and Adobe will fix that pretty soon now.
                          Renate
