System is win 8
office 2013
adobe presenter 10
when i try to convert ppt file to scorm packet presenter menu disappear from office menu bar
then I try to add menulauncher.dll
but i experience "menulauncher.dll does not office extention" message on the screen
I tried to oll fallowing steps but unfortunataly
Issue
The Adobe Presenter menu doesn't appear in PowerPoint even though the Adobe Presenter Add-in for Microsoft PowerPoint is installed.
Solution
Click the Office PowerPoint button (upper left), and then click PowerPoint Options.
Select Add-Ins. In the Manage pop-up menu at the bottom of the Options dialog box, select Disabled Items and click Go
In the Disabled Items dialog box, click the Presenter add-in, and then click Enable.
Note: There aren't any items listed in the screenshot. In your installation, you sometimes see the Adobe Presenter PowerPoint Add-in.
Click Close.
If the above solution doesn't work, try the following:
Select Add-Ins. In the Manage pop-up menu at the bottom of the dialog box, select COM Add-Ins and click Go.
Select Adobe Presenter Powerpoint COM Addin from the list. Write down the Location path.
Deselect all add-ins in the list except the Adobe Presenter Addin and click Remove.
Click Add and navigate to the MenuLauncher.dll file at the location you wrote down in step 3.
Click OK. Click OK again.
Click Help > About Microsoft Office PowerPoint > Disabled Items.
