1. Re: New version of Flash won't install
Pat Willener Oct 17, 2014 10:55 PM (in response to dmonbarren)Try the offline installer http://download.macromedia.com/pub/flashplayer/current/support/install_flash_player_osx.dm g
2. Re: New version of Flash won't install
carof Oct 19, 2014 7:14 AM (in response to dmonbarren)What worked for me is this:
(1) Download the flash installer
(2) Locate the installer (it's a dmg file) and double-click to mount the image
(3) When the image mounts on the desktop, DO NOT DOUBLE CLICK THE INSTALLER. Instead, control-click on the installer and select "Show Package Contents"
(4) A Finder window will pop up, with a folder called "Contents" inside. Open the "Contents" folder.
(5) Inside "Contents", there is a folder called "MacOS". Open it.
(6) Inside is a Unix executable file caled "Adobe Flash Player Install Manager". DOuble-click to un.
(7). It will open up the Terminal first, but then it will look like a regular install/update.
Hope this helps,
C
3. Re: New version of Flash won't install
papyrus100 Nov 6, 2014 6:45 AM (in response to dmonbarren)I have the same problem, ever since I try to update to the latest version. Here is my logs. It clearly states that the installer is trying to do something as "root". Look at the line "
Has ANYONE in Adobe tested Yosemite and Flash 15.XXXX Installer? Does not look like it. The Adobe staff are harvesting information but no one is providing a solution. Free software but no support
2011-11-19 09:24:28 -0500 ---------- log start ----------
2011-11-19 09:24:28 -0500 All install checks pass
2011-11-19 09:24:39 -0500 User does not have any processes that need to be closed before the Flash Player can be installed.
2011-11-19 09:24:39 -0500 [install started]
installer: Package name is PlugIn
installer: Installing at base path /
installer: The install was successful.
2011-11-19 09:24:54 -0500 [install completed]
2011-11-19 09:24:54 -0500 [install succeeded]
2011-11-19 09:24:58 -0500 ---------- log end ----------
2012-02-19 15:28:34 -0500 ---------- log start ----------
2012-02-19 15:28:35 -0500 1861
2012-02-19 15:28:43 -0500 ---------- log end ----------
2012-02-27 16:03:42 -0500 ---------- log start ----------
2012-02-27 16:03:43 -0500 1861
2012-02-27 16:03:53 -0500 ---------- log end ----------
2012-03-05 18:18:52 -0500 ---------- log start ----------
2012-03-05 18:18:57 -0500 1861
2012-03-05 18:19:05 -0500 ---------- log end ----------
2012-03-13 19:09:17 -0400 ---------- log start ----------
2012-03-13 19:09:18 -0400 1861
2012-03-13 19:09:26 -0400 ---------- log end ----------
2012-03-20 19:17:59 -0400 ---------- log start ----------
2012-03-20 19:17:59 -0400 1861
2012-03-20 19:18:07 -0400 ---------- log end ----------
2012-03-29 02:18:40 +0000 ---------- log start ----------
2012-03-29 02:18:43 +0000 1658
2012-03-29 02:18:50 +0000 ---------- log end ----------
2012-04-06 00:23:14 +0000 ---------- log start ----------
2012-04-06 00:23:19 +0000 1658
2012-04-06 00:23:27 +0000 ---------- log end ----------
2012-04-13 01:47:36 +0000 ---------- log start ----------
2012-04-13 01:47:39 +0000 1658
2012-04-13 01:47:46 +0000 ---------- log end ----------
2012-04-20 01:53:42 +0000 ---------- log start ----------
2012-04-20 01:53:45 +0000 1658
2012-04-20 01:53:54 +0000 ---------- log end ----------
2012-04-27 10:22:57 +0000 ---------- log start ----------
2012-04-27 10:22:59 +0000 1658
2012-04-27 10:23:00 +0000 ---------- log end ----------
2012-05-04 22:06:41 +0000 ---------- log start ----------
2012-05-04 22:06:42 +0000 1658
2012-05-04 22:08:20 +0000 ---------- log end ----------
2012-05-12 17:58:17 +0000 ---------- log start ----------
2012-05-12 17:58:18 +0000 1658
2012-05-12 17:58:29 +0000 ---------- log end ----------
2012-05-19 18:25:17 +0000 ---------- log start ----------
2012-05-19 18:25:19 +0000 1658
2012-05-19 18:25:30 +0000 ---------- log end ----------
2012-05-26 22:09:06 +0000 ---------- log start ----------
2012-05-26 22:09:10 +0000 1658
2012-05-26 22:09:25 +0000 11210280
2012-05-26 22:09:26 +0000 verifySignatureWithData : Message Verified!
2012-05-26 22:09:37 +0000 ---------- log end ----------
2012-05-26 22:09:48 +0000 ---------- log start ----------
2012-05-26 22:09:48 +0000 All install checks pass
2012-05-26 22:10:07 +0000 User has 1 process that needs to be closed before the Flash Player can be installed.
2012-05-26 22:10:23 +0000 [install started]
installer: Upgrading at base path /
installer: The upgrade was successful.
2012-05-26 22:11:48 +0000 [install completed]
2012-05-26 22:11:48 +0000 [install succeeded]
2012-05-26 22:11:53 +0000 ---------- log end ----------
2012-06-10 20:17:03 +0000 ---------- log start ----------
2012-06-10 20:17:03 +0000 1260
2012-06-10 20:17:09 +0000 ---------- log end ----------
2012-06-18 12:24:14 +0000 ---------- log start ----------
2012-06-18 12:24:16 +0000 1260
2012-06-18 12:26:42 +0000 11580012
2012-06-18 12:26:42 +0000 verifySignatureWithData : Message Verified!
2012-06-18 12:26:50 +0000 ---------- log end ----------
2012-06-18 13:29:52 +0000 ---------- log start ----------
2012-06-18 13:29:52 +0000 All install checks pass
2012-06-18 13:30:02 +0000 User does not have any processes that need to be closed before the Flash Player can be installed.
2012-06-18 13:30:02 +0000 [install started]
sudo: no tty present and no askpass program specified
2012-06-18 13:30:15 +0000 [install completed]
2012-06-18 13:30:15 +0000 [install succeeded]
2012-06-18 13:30:22 +0000 ---------- log end ----------
2012-06-18 13:30:22 +0000 Changing update mode to 1
2012-07-18 18:03:00 +0000 ---------- log start ----------
2012-07-18 18:03:09 +0000 733
2012-07-18 18:03:21 +0000 ---------- log end ----------
2012-07-26 18:59:27 +0000 ---------- log start ----------
2012-07-26 18:59:30 +0000 733
2012-07-26 18:59:41 +0000 ---------- log end ----------
2012-08-02 19:08:53 +0000 ---------- log start ----------
2012-08-02 19:08:54 +0000 733
2012-08-02 19:09:02 +0000 ---------- log end ----------
2012-08-13 13:34:11 +0000 ---------- log start ----------
2012-08-13 13:34:13 +0000 733
2012-08-13 13:51:52 +0000 ---------- log end ----------
2012-08-21 16:56:30 +0000 ---------- log start ----------
2012-08-21 16:56:35 +0000 662
2012-08-21 16:56:56 +0000 11861772
2012-08-21 16:56:56 +0000 verifySignatureWithData : Message Verified!
2012-08-21 16:57:05 +0000 ---------- log end ----------
2012-08-21 16:57:09 +0000 ---------- log start ----------
2012-08-21 16:57:09 +0000 All install checks pass
2012-08-21 16:57:18 +0000 User does not have any processes that need to be closed before the Flash Player can be installed.
2012-08-21 16:57:18 +0000 [install started]
2012-08-21 16:57:33 +0000 [install completed]
2012-08-21 16:57:33 +0000 [install succeeded]
2012-08-21 16:57:38 +0000 ---------- log end ----------
2012-08-21 16:57:38 +0000 Changing update mode to 1
2012-10-12 14:41:12 +0000 ---------- log start ----------
2012-10-12 14:41:14 +0000 662
2012-10-12 14:41:33 +0000 11866905
2012-10-12 14:41:33 +0000 verifySignatureWithData : Message Verified!
2012-10-12 14:41:48 +0000 ---------- log end ----------
2012-10-12 14:41:53 +0000 ---------- log start ----------
2012-10-12 14:41:53 +0000 All install checks pass
2012-10-12 14:42:19 +0000 User has 1 process that needs to be closed before the Flash Player can be installed.
2012-10-12 14:43:20 +0000 [install started]
2012-10-12 14:43:45 +0000 [install completed]
2012-10-12 14:43:45 +0000 [install succeeded]
2012-10-12 14:43:52 +0000 ---------- log end ----------
2012-10-12 14:43:52 +0000 Changing update mode to 1
2012-11-10 18:28:04 +0000 ---------- log start ----------
2012-11-10 18:28:06 +0000 640
2012-11-10 18:28:14 +0000 ---------- log end ----------
2012-11-17 20:39:31 +0000 ---------- log start ----------
2012-11-17 20:39:32 +0000 640
2012-11-17 20:39:39 +0000 ---------- log end ----------
2012-11-24 20:47:21 +0000 ---------- log start ----------
2012-11-24 20:47:29 +0000 640
2012-11-24 20:47:52 +0000 16875066
2012-11-24 20:47:56 +0000 verifySignatureWithData : Message Verified!
2012-11-24 20:48:15 +0000 ---------- log end ----------
2012-11-24 20:48:22 +0000 ---------- log start ----------
2012-11-24 20:48:22 +0000 All install checks pass
2012-11-24 20:48:37 +0000 User has 1 process that needs to be closed before the Flash Player can be installed.
2012-11-24 20:48:51 +0000 [install started]
2012-11-24 20:49:14 +0000 [install completed]
2012-11-24 20:49:14 +0000 [install succeeded]
2012-11-24 20:49:23 +0000 ---------- log end ----------
2012-11-24 20:49:22 +0000 Changing update mode to 1
2012-12-17 14:38:15 +0000 ---------- log start ----------
2012-12-17 14:38:16 +0000 640
2012-12-17 14:38:17 +0000 640
2012-12-17 14:38:22 +0000 ---------- log end ----------
2012-12-25 17:47:09 +0000 ---------- log start ----------
2012-12-25 17:47:09 +0000 640
2012-12-25 17:47:17 +0000 ---------- log end ----------
2013-01-01 18:38:34 +0000 ---------- log start ----------
2013-01-01 18:38:34 +0000 640
2013-01-01 18:38:41 +0000 ---------- log end ----------
2013-01-08 20:35:45 +0000 ---------- log start ----------
2013-01-08 20:35:45 +0000 640
2013-01-08 20:35:46 +0000 640
2013-01-08 20:46:24 +0000 16879485
2013-01-08 20:46:25 +0000 verifySignatureWithData : Message Verified!
2013-01-08 20:46:36 +0000 ---------- log end ----------
2013-01-08 20:46:40 +0000 ---------- log start ----------
2013-01-08 20:46:40 +0000 All install checks pass
2013-01-08 20:46:50 +0000 User has 1 process that needs to be closed before the Flash Player can be installed.
2013-01-08 20:47:00 +0000 [install started]
2013-01-08 20:47:16 +0000 [install completed]
2013-01-08 20:47:16 +0000 [install succeeded]
2013-01-08 20:47:55 +0000 ---------- log end ----------
2013-01-08 20:47:54 +0000 Changing update mode to 1
2013-02-12 13:03:04 +0000 ---------- log start ----------
2013-02-12 13:03:04 +0000 All install checks pass
2013-02-12 13:03:13 +0000 User does not have any processes that need to be closed before the Flash Player can be installed.
2013-02-12 13:03:13 +0000 [install started]
2013-02-12 13:03:26 +0000 [install completed]
2013-02-12 13:03:26 +0000 [install succeeded]
2013-02-12 13:03:31 +0000 ---------- log end ----------
2013-02-12 13:03:31 +0000 Changing update mode to 1
2013-02-28 15:44:13 +0000 ---------- log start ----------
2013-02-28 15:44:14 +0000 1328
2013-02-28 15:44:17 +0000 1328
2013-02-28 15:44:42 +0000 16931542
2013-02-28 15:44:42 +0000 verifySignatureWithData : Message Verified!
2013-02-28 15:44:51 +0000 ---------- log end ----------
2013-02-28 15:44:54 +0000 ---------- log start ----------
2013-02-28 15:44:54 +0000 All install checks pass
2013-02-28 15:45:05 +0000 User does not have any processes that need to be closed before the Flash Player can be installed.
2013-02-28 15:45:05 +0000 [install started]
2013-02-28 15:45:34 +0000 [install completed]
2013-02-28 15:45:34 +0000 [install succeeded]
2013-02-28 15:45:40 +0000 ---------- log end ----------
2013-02-28 15:45:40 +0000 Changing update mode to 1
2013-03-16 19:36:13 +0000 ---------- log start ----------
2013-03-16 19:36:15 +0000 1328
2013-03-16 19:36:21 +0000 1328
2013-03-16 19:36:36 +0000 ---------- log end ----------
2013-03-25 14:52:40 +0000 ---------- log start ----------
2013-03-25 14:52:40 +0000 1328
2013-03-25 14:52:41 +0000 1328
2013-03-25 14:52:48 +0000 ---------- log end ----------
2013-04-02 20:58:40 +0000 ---------- log start ----------
2013-04-02 20:58:41 +0000 1328
2013-04-02 20:58:51 +0000 1328
2013-04-02 20:59:01 +0000 ---------- log end ----------
2013-04-12 10:45:31 +0000 ---------- log start ----------
2013-04-12 10:45:32 +0000 1328
2013-04-12 10:45:37 +0000 1328
2013-04-12 10:45:48 +0000 ---------- log end ----------
2013-04-12 10:47:28 +0000 ---------- log start ----------
2013-04-12 10:47:28 +0000 All install checks pass
2013-04-12 10:47:29 +0000 [install started]
2013-04-12 10:47:49 +0000 [install completed]
2013-04-12 10:47:53 +0000 ---------- log end ----------
2013-04-12 10:47:53 +0000 Changing update mode to 1
2013-05-17 02:43:18 +0000 ---------- log start ----------
2013-05-17 02:43:18 +0000 1328
2013-05-17 02:43:22 +0000 1328
2013-05-17 03:54:39 +0000 ---------- log end ----------
2013-05-24 03:52:18 +0000 ---------- log start ----------
2013-05-24 03:52:18 +0000 1328
2013-05-24 03:52:19 +0000 1328
2013-05-24 03:52:23 +0000 ---------- log end ----------
2013-06-01 00:53:36 +0000 ---------- log start ----------
2013-06-01 00:53:39 +0000 1214
2013-06-01 00:53:49 +0000 1214
2013-06-01 12:41:07 +0000 ---------- log end ----------
2013-06-11 16:04:05 +0000 ---------- log start ----------
2013-06-11 16:04:06 +0000 1214
2013-06-11 16:04:10 +0000 1214
2013-06-11 16:04:16 +0000 ---------- log end ----------
2013-06-19 11:07:08 +0000 ---------- log start ----------
2013-06-19 11:07:10 +0000 1214
2013-06-19 11:07:20 +0000 1214
2013-06-19 11:08:00 +0000 18012237
2013-06-19 11:08:01 +0000 verifySignatureWithData : Message Verified!
2013-06-19 11:08:11 +0000 ---------- log end ----------
2013-06-19 11:08:14 +0000 ---------- log start ----------
2013-06-19 11:08:14 +0000 All install checks pass
2013-06-19 11:08:35 +0000 User does not have any processes that need to be closed before the Flash Player can be installed.
2013-06-19 11:08:35 +0000 [install started]
dyld: DYLD_ environment variables being ignored because main executable (/var/folders/vk/14dvbhy53kv2n9k0dhkgkfcc0000gn/T/FPInstallHelper) is setuid or setgid
dyld: DYLD_ environment variables being ignored because main executable (/System/Library/PrivateFrameworks/Install.framework/Resources/runner) is setuid or setgid
2013-06-19 11:09:10 +0000 [install completed]
2013-06-19 11:09:10 +0000 [install succeeded]
2013-06-19 11:09:29 +0000 ---------- log end ----------
2013-06-19 11:09:29 +0000 Changing update mode to 1
2013-07-17 12:37:20 +0000 ---------- log start ----------
2013-07-17 12:37:24 +0000 1213
2013-07-17 12:37:37 +0000 1213
2013-07-17 20:14:33 +0000 ---------- log end ----------
2013-07-25 14:00:03 +0000 ---------- log start ----------
2013-07-25 14:00:07 +0000 1213
2013-07-25 14:00:19 +0000 1213
2013-07-25 14:00:38 +0000 ---------- log end ----------
2013-08-02 11:21:18 +0000 ---------- log start ----------
2013-08-02 11:21:19 +0000 1213
2013-08-02 11:21:26 +0000 1213
2013-08-02 11:21:28 +0000 ---------- log end ----------
2013-08-10 20:08:06 +0000 ---------- log start ----------
2013-08-10 20:08:08 +0000 1213
2013-08-10 20:08:24 +0000 1213
2013-08-10 20:08:49 +0000 ---------- log end ----------
2013-08-17 20:11:42 +0000 ---------- log start ----------
2013-08-17 20:11:47 +0000 1213
2013-08-17 20:11:58 +0000 1213
2013-08-17 20:12:09 +0000 ---------- log end ----------
2013-08-25 19:46:54 +0000 ---------- log start ----------
2013-08-25 19:46:58 +0000 1327
2013-08-25 19:47:15 +0000 1327
2013-08-25 19:47:59 +0000 ---------- log end ----------
2013-09-02 17:41:30 +0000 ---------- log start ----------
2013-09-02 17:41:33 +0000 1327
2013-09-02 17:41:38 +0000 1327
2013-09-02 17:41:45 +0000 ---------- log end ----------
2013-09-09 20:47:45 +0000 ---------- log start ----------
2013-09-09 20:47:48 +0000 1327
2013-09-09 20:47:54 +0000 1327
2013-09-09 20:52:09 +0000 ---------- log end ----------
2013-09-14 01:45:00 +0000 ---------- log start ----------
2013-09-14 01:45:01 +0000 All install checks pass
2013-09-14 01:45:04 +0000 [install started]
2013-09-14 01:46:26 +0000 [install succeeded]
2013-09-14 01:46:51 +0000 ---------- log end ----------
2013-09-14 01:46:37 +0000 Changing update mode to 0
2013-10-13 13:57:10 +0000 ---------- log start ----------
2013-10-13 13:57:10 +0000 1552
2013-10-13 13:57:11 +0000 1552
2013-10-13 13:57:40 +0000 18408578
2013-10-13 13:57:40 +0000 verifySignatureWithData : Message Verified!
2013-10-13 13:58:00 +0000 ---------- log end ----------
2013-10-13 13:58:03 +0000 ---------- log start ----------
2013-10-13 13:58:03 +0000 All install checks pass
2013-10-13 13:58:16 +0000 User does not have any processes that need to be closed before the Flash Player can be installed.
2013-10-13 13:58:16 +0000 [install started]
installer: Package name is Adobe Flash Player
2013-10-13 13:59:50 +0000 [install completed]
2013-10-13 13:59:50 +0000 [install succeeded]
2013-10-13 14:00:07 +0000 ---------- log end ----------
2013-10-13 14:00:07 +0000 Changing update mode to 0
2013-11-19 13:30:21 +0000 ---------- log start ----------
2013-11-19 13:30:22 +0000 1552
2013-11-19 13:30:27 +0000 ---------- log end ----------
2013-11-26 16:19:37 +0000 ---------- log start ----------
2013-11-26 16:19:38 +0000 1552
2013-11-26 16:19:39 +0000 1552
2013-11-26 16:19:46 +0000 ---------- log end ----------
2013-12-03 16:21:04 +0000 ---------- log start ----------
2013-12-03 16:21:05 +0000 1552
2013-12-03 19:36:34 +0000 ---------- log end ----------
2013-12-03 19:38:03 +0000 ---------- log start ----------
2013-12-03 19:38:03 +0000 All install checks pass
2013-12-03 19:38:10 +0000 [install started]
2013-12-03 19:38:12 +0000 [install failed: 1]
2013-12-03 19:38:12 +0000 ---------- log end ----------
2013-12-03 19:39:51 +0000 ---------- log start ----------
2013-12-03 19:39:51 +0000 All install checks pass
2013-12-03 19:39:56 +0000 [install started]
2013-12-03 19:39:57 +0000 [install failed: 1]
2013-12-03 19:39:57 +0000 ---------- log end ----------
2013-12-03 19:41:38 +0000 ---------- log start ----------
2013-12-03 19:41:51 +0000 User does not have any processes that need to be closed before the Flash Player can be uninstalled.
2013-12-03 19:42:04 +0000 ---------- log end ----------
2013-12-03 19:41:51 +0000 Changing update mode to 1
2013-12-03 19:42:57 +0000 ---------- log start ----------
2013-12-03 19:42:57 +0000 All install checks pass
2013-12-03 19:42:57 +0000 [install started]
2013-12-03 19:42:58 +0000 [install failed: 1]
2013-12-03 19:42:58 +0000 ---------- log end ----------
2013-12-03 19:46:12 +0000 ---------- log start ----------
2013-12-03 19:46:12 +0000 All install checks pass
2013-12-03 19:46:12 +0000 [install started]
2013-12-03 19:46:13 +0000 [install failed: 1]
2013-12-03 19:46:13 +0000 ---------- log end ----------
2013-12-03 19:47:50 +0000 ---------- log start ----------
2013-12-03 19:47:56 +0000 User has 1 process that needs to be closed before the Flash Player can be uninstalled.
2013-12-03 19:48:06 +0000 ---------- log end ----------
2013-12-03 19:52:16 +0000 ---------- log start ----------
2013-12-03 19:52:16 +0000 All install checks pass
2013-12-03 19:52:16 +0000 [install started]
2013-12-03 19:52:18 +0000 [install failed: 1]
2013-12-03 19:52:18 +0000 ---------- log end ----------
2013-12-03 19:54:22 +0000 ---------- log start ----------
2013-12-03 19:54:22 +0000 All install checks pass
2013-12-03 19:54:22 +0000 [install started]
2013-12-03 19:54:23 +0000 [install failed: 1]
2013-12-03 19:54:23 +0000 ---------- log end ----------
2013-12-03 20:04:12 +0000 ---------- log start ----------
2013-12-03 20:04:12 +0000 All install checks pass
2013-12-03 20:04:22 +0000 User does not have any processes that need to be closed before the Flash Player can be installed.
2013-12-03 20:04:22 +0000 [install started]
installer: Must be run as root to install this package.
2013-12-03 20:04:23 +0000 [install completed]
2013-12-03 20:04:23 +0000 [install failed]
2013-12-03 20:04:29 +0000 ---------- log end ----------
2013-12-03 20:04:48 +0000 ---------- log start ----------
2013-12-03 20:04:53 +0000 User does not have any processes that need to be closed before the Flash Player can be uninstalled.
2013-12-03 20:04:55 +0000 ---------- log end ----------
2013-12-11 00:31:25 +0000 ---------- log start ----------
2013-12-11 00:31:25 +0000 1552
2013-12-11 00:31:26 +0000 1552
2013-12-11 00:31:31 +0000 ---------- log end ----------
2013-12-18 23:36:48 +0000 ---------- log start ----------
2013-12-18 23:36:48 +0000 1552
2013-12-18 23:36:49 +0000 1552
2013-12-18 23:36:58 +0000 ---------- log end ----------
2013-12-26 21:09:52 +0000 ---------- log start ----------
2013-12-26 21:09:53 +0000 1552
2013-12-26 21:09:58 +0000 ---------- log end ----------
2014-01-03 15:00:47 +0000 ---------- log start ----------
2014-01-03 15:00:47 +0000 1552
2014-01-03 15:00:48 +0000 1552
2014-01-03 15:00:51 +0000 ---------- log end ----------
2014-01-10 15:53:54 +0000 ---------- log start ----------
2014-01-10 15:53:54 +0000 1552
2014-01-10 15:54:30 +0000 18417494
2014-01-10 15:54:31 +0000 verifySignatureWithData : Message Verified!
2014-01-10 15:54:38 +0000 ---------- log end ----------
2014-01-10 15:54:56 +0000 ---------- log start ----------
2014-01-10 15:54:56 +0000 All install checks pass
2014-01-10 15:55:08 +0000 User does not have any processes that need to be closed before the Flash Player can be installed.
2014-01-10 15:55:08 +0000 [install started]
installer: Error the package path specified was invalid: '/var/folders/vk/14dvbhy53kv2n9k0dhkgkfcc0000gn/T/FPUnpackPath/Install Adobe Flash Player.app/Contents/Resources/Adobe Flash Player.pkg'.
2014-01-10 15:55:09 +0000 [install completed]
2014-01-10 15:55:09 +0000 [install failed]
2014-01-10 15:55:19 +0000 ---------- log end ----------
2014-01-10 15:55:18 +0000 Changing update mode to 0
2014-01-18 14:13:55 +0000 ---------- log start ----------
2014-01-18 14:13:56 +0000 1549
2014-01-18 14:14:20 +0000 ---------- log end ----------
2014-01-18 09:16:04 -0500 [I] IM: ---------- log start ----------
2014-01-18 09:16:04 -0500 [I] IM: All install checks pass
2014-01-18 09:16:04 -0500 [W] IM: Unexpected umask value for process: 0
2014-01-18 09:16:08 -0500 [I] IM: User does not have any processes that need to be closed.
2014-01-18 09:16:08 -0500 [I] IM: [install started]
2014-01-18 09:16:12 -0500 [E] IM: [install failed: 1]
2014-01-18 09:16:12 -0500 [E] IM: Install failed with error code: 1.
2014-01-18 09:16:12 -0500 [I] IM: ---------- log end ----------
2014-01-25 17:57:08 +0000 ---------- log start ----------
2014-01-25 17:57:08 +0000 1549
2014-01-25 17:57:09 +0000 1549
2014-01-25 17:59:24 +0000 ---------- log end ----------
2014-02-04 15:19:32 +0000 ---------- log start ----------
2014-02-04 15:19:32 +0000 1549
2014-02-04 15:19:39 +0000 ---------- log end ----------
2014-02-05 10:05:43 -0500 [I] IM: ---------- log start ----------
2014-02-05 10:05:44 -0500 [I] IM: All install checks pass
2014-02-05 10:05:44 -0500 [I] IM: [install started]
2014-02-05 10:05:56 -0500 [I] FIN: [finalizer started]
2014-02-05 10:05:56 -0500 [I] FIN: Compression Output Path: '/Library/Internet Plug-Ins/Flash Player.plugin'.
2014-02-05 10:05:56 -0500 [I] FIN: Compression Input Path: '/Library/Internet Plug-Ins/Flash Player.plugin.lzma'.
2014-02-05 10:06:02 -0500 [E] FIN: Unable to create directory '(null)'.
2014-02-05 10:06:02 -0500 [E] FIN: [finalizer failed]
2014-02-05 10:06:08 -0500 [I] IM: [install succeeded]
2014-02-05 10:06:08 -0500 [I] IM: ---------- log end ----------
2014-02-10 07:17:17 -0500 [E] SAU: End SAU run with exit code: 2002
2014-02-21 07:58:50 -0500 [I] IM: ---------- log start ----------
2014-02-21 07:58:50 -0500 [I] IM: All install checks pass
2014-02-21 07:58:50 -0500 [I] IM: [install started]
2014-02-21 07:58:59 -0500 [I] FIN: [finalizer started]
2014-02-21 07:58:59 -0500 [I] FIN: Compression Output Path: '/Library/Internet Plug-Ins/Flash Player.plugin'.
2014-02-21 07:58:59 -0500 [I] FIN: Compression Input Path: '/Library/Internet Plug-Ins/Flash Player.plugin.lzma'.
2014-02-21 07:59:04 -0500 [E] FIN: Unable to create directory '(null)'.
2014-02-21 07:59:04 -0500 [E] FIN: [finalizer failed]
2014-02-21 07:59:09 -0500 [I] IM: [install succeeded]
2014-02-21 07:59:09 -0500 [I] IM: ---------- log end ----------
2014-02-26 06:56:36 -0500 [E] SAU: End SAU run with exit code: 2002
2014-03-04 06:50:26 -0500 [E] SAU: End SAU run with exit code: 2002
2014-03-08 23:20:38 -0500 [E] SAU: End SAU run with exit code: 2002
2014-03-12 02:42:32 -0400 [E] SAU: Unable to verify signature on downloaded installer.
2014-03-12 02:42:32 -0400 [E] SAU: End SAU run with exit code: 2005
2014-03-13 07:10:42 -0400 [I] IM: ---------- log start ----------
2014-03-13 07:10:42 -0400 [I] IM: All install checks pass
2014-03-13 07:10:42 -0400 [I] IM: [install started]
2014-03-13 07:10:49 -0400 [I] FIN: [finalizer started]
2014-03-13 07:10:49 -0400 [I] FIN: Compression Output Path: '/Library/Internet Plug-Ins/Flash Player.plugin'.
2014-03-13 07:10:49 -0400 [I] FIN: Compression Input Path: '/Library/Internet Plug-Ins/Flash Player.plugin.lzma'.
2014-03-13 07:10:55 -0400 [E] FIN: Unable to create directory '(null)'.
2014-03-13 07:10:55 -0400 [E] FIN: [finalizer failed]
2014-03-13 07:11:01 -0400 [I] IM: [install succeeded]
2014-03-13 07:11:01 -0400 [I] IM: ---------- log end ----------
2014-03-14 12:30:17 -0400 [E] SAU: End SAU run with exit code: 2002
2014-03-19 07:05:08 -0400 [E] SAU: End SAU run with exit code: 2002
2014-03-22 09:16:48 -0400 [E] SAU: End SAU run with exit code: 2002
2014-03-24 16:11:59 -0400 [E] SAU: End SAU run with exit code: 2002
2014-03-26 06:50:18 -0400 [E] SAU: End SAU run with exit code: 2002
2014-03-28 06:53:05 -0400 [E] SAU: End SAU run with exit code: 2002
2014-04-02 16:55:04 -0400 [E] SAU: End SAU run with exit code: 2002
2014-04-09 07:53:28 -0400 [E] SAU: End SAU run with exit code: 2002
2014-04-11 07:27:46 -0400 [I] IM: ---------- log start ----------
2014-04-11 07:27:46 -0400 [I] IM: 1550
2014-04-11 07:27:52 -0400 [I] IM: ---------- log end ----------
2014-04-16 21:04:06 -0400 [I] IM: ---------- log start ----------
2014-04-16 21:04:06 -0400 [I] IM: All install checks pass
2014-04-16 21:04:06 -0400 [I] IM: [install started]
2014-04-16 21:04:14 -0400 [I] FIN: [finalizer started]
2014-04-16 21:04:14 -0400 [I] FIN: Compression Output Path: '/Library/Internet Plug-Ins/Flash Player.plugin'.
2014-04-16 21:04:14 -0400 [I] FIN: Compression Input Path: '/Library/Internet Plug-Ins/Flash Player.plugin.lzma'.
2014-04-16 21:04:17 -0400 [E] FIN: Unable to create directory '(null)'.
2014-04-16 21:04:17 -0400 [E] FIN: [finalizer failed]
2014-04-16 21:04:21 -0400 [I] IM: [install succeeded]
2014-04-16 21:04:21 -0400 [I] IM: ---------- log end ----------
2014-04-21 18:41:27 -0400 [E] SAU: End SAU run with exit code: 2002
2014-04-23 06:49:43 -0400 [E] SAU: End SAU run with exit code: 2002
2014-04-28 21:07:48 -0400 [I] IM: ---------- log start ----------
2014-04-28 21:07:48 -0400 [I] IM: All install checks pass
2014-04-28 21:07:48 -0400 [I] IM: [install started]
2014-04-28 21:08:12 -0400 [I] FIN: [finalizer started]
2014-04-28 21:08:12 -0400 [I] FIN: Compression Output Path: '/Library/Internet Plug-Ins/Flash Player.plugin'.
2014-04-28 21:08:12 -0400 [I] FIN: Compression Input Path: '/Library/Internet Plug-Ins/Flash Player.plugin.lzma'.
2014-04-28 21:08:27 -0400 [E] FIN: Unable to create directory '(null)'.
2014-04-28 21:08:27 -0400 [E] FIN: [finalizer failed]
2014-04-28 21:08:34 -0400 [I] IM: [install succeeded]
2014-04-28 21:08:34 -0400 [I] IM: ---------- log end ----------
2014-04-30 07:15:20 -0400 [E] SAU: End SAU run with exit code: 2002
2014-05-12 16:38:24 -0400 [E] SAU: End SAU run with exit code: 2002
2014-05-13 16:50:01 -0400 [E] SAU: End SAU run with exit code: 2002
2014-05-13 18:19:10 -0400 [I] IM: ---------- log start ----------
2014-05-13 18:19:10 -0400 [I] IM: All install checks pass
2014-05-13 18:19:10 -0400 [I] IM: [install started]
2014-05-13 18:19:15 -0400 [I] FIN: [finalizer started]
2014-05-13 18:19:15 -0400 [I] FIN: Compression Output Path: '/Library/Internet Plug-Ins/Flash Player.plugin'.
2014-05-13 18:19:15 -0400 [I] FIN: Compression Input Path: '/Library/Internet Plug-Ins/Flash Player.plugin.lzma'.
2014-05-13 18:19:18 -0400 [E] FIN: Unable to create directory '(null)'.
2014-05-13 18:19:18 -0400 [E] FIN: [finalizer failed]
2014-05-13 18:19:22 -0400 [I] IM: [install succeeded]
2014-05-13 18:19:22 -0400 [I] IM: ---------- log end ----------
2014-05-21 06:47:46 -0400 [E] SAU: End SAU run with exit code: 2002
2014-05-23 07:06:44 -0400 [E] SAU: End SAU run with exit code: 2002
2014-05-28 17:34:49 -0400 [E] SAU: End SAU run with exit code: 2002
2014-06-03 17:06:02 -0400 [E] SAU: End SAU run with exit code: 2002
2014-06-11 06:55:22 -0400 [E] SAU: End SAU run with exit code: 2002
2014-06-11 16:50:08 -0400 [E] SAU: End SAU run with exit code: 2002
2014-06-16 16:51:13 -0400 [E] SAU: End SAU run with exit code: 2002
2014-06-17 21:43:58 -0400 [I] IM: ---------- log start ----------
2014-06-17 21:43:58 -0400 [I] IM: 1550
2014-06-17 21:44:01 -0400 [I] IM: 1550
2014-06-17 21:44:15 -0400 [I] IM: ---------- log end ----------
2014-06-25 19:50:58 -0400 [I] IM: ---------- log start ----------
2014-06-25 19:50:58 -0400 [I] IM: 1550
2014-06-25 19:50:59 -0400 [I] IM: 1550
2014-06-25 19:51:05 -0400 [I] IM: ---------- log end ----------
2014-06-30 07:14:42 -0400 [E] SAU: End SAU run with exit code: 2002
2014-07-03 06:39:15 -0400 [E] SAU: End SAU run with exit code: 2002
2014-07-03 17:05:41 -0400 [E] SAU: End SAU run with exit code: 2002
2014-07-04 18:10:34 -0400 [I] IM: ---------- log start ----------
2014-07-04 18:10:34 -0400 [I] IM: 1550
2014-07-04 18:10:39 -0400 [I] IM: ---------- log end ----------
2014-07-09 20:55:35 -0400 [I] IM: ---------- log start ----------
2014-07-09 20:55:35 -0400 [I] IM: All install checks pass
2014-07-09 20:55:35 -0400 [I] IM: [install started]
2014-07-09 20:55:53 -0400 [I] FIN: [finalizer started]
2014-07-09 20:55:53 -0400 [I] FIN: Compression Output Path: '/Library/Internet Plug-Ins/Flash Player.plugin'.
2014-07-09 20:55:53 -0400 [I] FIN: Compression Input Path: '/Library/Internet Plug-Ins/Flash Player.plugin.lzma'.
2014-07-09 20:56:00 -0400 [E] FIN: Unable to create directory '(null)'.
2014-07-09 20:56:00 -0400 [E] FIN: [finalizer failed]
2014-07-09 20:56:04 -0400 [I] IM: [install succeeded]
2014-07-09 20:56:04 -0400 [I] IM: ---------- log end ----------
2014-08-13 14:48:13 -0400 [I] IM: ---------- log start ----------
2014-08-13 14:48:14 -0400 [I] IM: 1568
2014-08-13 14:48:16 -0400 [I] IM: 1568
2014-08-13 14:48:36 -0400 [I] IM: ---------- log end ----------
2014-08-20 20:35:34 -0400 [I] IM: ---------- log start ----------
2014-08-20 20:35:35 -0400 [I] IM: 1568
2014-08-20 20:35:55 -0400 [I] IM: ---------- log end ----------
2014-08-21 16:54:47 -0400 [E] SAU: End SAU run with exit code: 2002
2014-08-27 16:46:28 -0400 [E] SAU: End SAU run with exit code: 2002
2014-08-27 20:48:23 -0400 [I] IM: ---------- log start ----------
2014-08-27 20:48:23 -0400 [I] IM: 1568
2014-08-27 20:48:24 -0400 [I] IM: 1568
2014-08-27 21:27:14 -0400 [I] IM: ---------- log end ----------
2014-09-03 06:59:01 -0400 [E] SAU: End SAU run with exit code: 2002
2014-09-03 20:52:04 -0400 [I] IM: ---------- log start ----------
2014-09-03 20:52:04 -0400 [I] IM: 1568
2014-09-03 20:52:17 -0400 [I] IM: ---------- log end ----------
2014-09-04 17:21:47 -0400 [E] SAU: End SAU run with exit code: 2002
2014-09-09 21:57:50 -0400 [I] IM: ---------- log start ----------
2014-09-09 21:57:50 -0400 [I] IM: All install checks pass
2014-09-09 21:57:50 -0400 [I] IM: [install started]
2014-09-09 21:58:08 -0400 [I] FIN: [finalizer started]
2014-09-09 21:58:08 -0400 [I] FIN: Compression Output Path: '/Library/Internet Plug-Ins/Flash Player.plugin'.
2014-09-09 21:58:08 -0400 [I] FIN: Compression Input Path: '/Library/Internet Plug-Ins/Flash Player.plugin.lzma'.
2014-09-09 21:58:19 -0400 [E] FIN: Unable to create directory '(null)'.
2014-09-09 21:58:19 -0400 [E] FIN: [finalizer failed]
2014-09-09 21:58:25 -0400 [I] IM: [install succeeded]
2014-09-09 21:58:25 -0400 [I] IM: ---------- log end ----------
2014-09-10 07:09:29 -0400 [E] SAU: End SAU run with exit code: 2002
2014-09-10 16:19:29 -0400 [E] SAU: End SAU run with exit code: 2002
2014-09-10 18:55:10 -0400 [I] IM: ---------- log start ----------
2014-09-10 18:55:11 -0400 [I] IM: All install checks pass
2014-09-10 18:55:11 -0400 [I] IM: [install started]
2014-09-10 18:55:23 -0400 [I] FIN: [finalizer started]
2014-09-10 18:55:23 -0400 [I] FIN: Compression Output Path: '/Library/Internet Plug-Ins/Flash Player.plugin'.
2014-09-10 18:55:23 -0400 [I] FIN: Compression Input Path: '/Library/Internet Plug-Ins/Flash Player.plugin.lzma'.
2014-09-10 18:55:28 -0400 [E] FIN: Unable to create directory '(null)'.
2014-09-10 18:55:28 -0400 [E] FIN: [finalizer failed]
2014-09-10 18:55:30 -0400 [I] IM: [install succeeded]
2014-09-10 18:55:30 -0400 [I] IM: ---------- log end ----------
2014-09-24 07:29:24 -0400 [E] SAU: End SAU run with exit code: 2002
2014-09-30 16:40:14 -0400 [E] SAU: End SAU run with exit code: 2002
2014-10-07 06:25:22 -0400 [E] SAU: End SAU run with exit code: 2002
2014-10-10 06:47:17 -0400 [E] SAU: End SAU run with exit code: 2002
2014-10-16 03:26:26 -0400 [E] SAU: End SAU run with exit code: 2002
2014-10-16 06:35:51 -0400 [E] SAU: End SAU run with exit code: 2002
2014-10-16 17:04:15 -0400 [E] SAU: End SAU run with exit code: 2002
2014-10-18 12:33:40 -0400 [I] IM: ---------- log start ----------
2014-10-18 12:33:40 -0400 [I] IM: 1574
2014-10-18 12:33:42 -0400 [I] IM: 1574
2014-10-18 12:33:58 -0400 [I] IM: ---------- log end ----------
2014-10-18 12:34:02 -0400 [I] IM: ---------- log end ----------
2014-10-24 07:01:31 -0400 [E] SAU: End SAU run with exit code: 2002
2014-10-24 16:54:56 -0400 [E] SAU: End SAU run with exit code: 2002
2014-10-26 17:47:01 -0400 [I] IM: ---------- log start ----------
2014-10-26 17:47:01 -0400 [I] IM: All install checks pass
2014-10-26 17:47:01 -0400 [W] IM: Unexpected umask value for process: 0
2014-10-26 17:47:02 -0400 [I] IM: User does not have any processes that need to be closed.
2014-10-26 17:47:02 -0400 [I] IM: [install started]
2014-10-26 17:47:07 -0400 [E] IM: [install failed: 1]
2014-10-26 17:47:07 -0400 [E] IM: Install failed with error code: 1.
2014-10-26 17:47:07 -0400 [I] IM: ---------- log end ----------
2014-10-28 19:08:19 -0400 [I] IM: ---------- log start ----------
2014-10-28 19:08:19 -0400 [I] IM: All install checks pass
2014-10-28 19:08:19 -0400 [W] IM: Unexpected umask value for process: 0
2014-10-28 19:08:20 -0400 [I] IM: User does not have any processes that need to be closed.
2014-10-28 19:08:20 -0400 [I] IM: [install started]
2014-10-28 19:08:22 -0400 [E] IM: [install failed: 1]
2014-10-28 19:08:22 -0400 [E] IM: Install failed with error code: 1.
2014-10-28 19:08:22 -0400 [I] IM: ---------- log end ----------
2014-10-28 19:09:43 -0400 [I] IM: ---------- log start ----------
2014-10-28 19:09:50 -0400 [I] IM: User does not have any processes that need to be closed before the Flash Player can be uninstalled.
2014-10-28 19:09:50 -0400 [I] IM: Uninstall Started
2014-10-28 19:09:52 -0400 [I] IM: [uninstall start]
2014-10-28 19:09:52 -0400 [I] IM: user authorized
2014-10-28 19:09:52 -0400 [I] IM: [file removal start]
2014-10-28 19:09:53 -0400 [I] IM: Did not find file '/Library/Internet Plug-Ins/Shockwave Flash NP-PPC' to remove.
2014-10-28 19:09:53 -0400 [I] IM: Removed file: '/Library/Internet Plug-Ins/Flash Player.plugin'
2014-10-28 19:09:53 -0400 [I] IM: Did not find file '/Library/Internet Plug-Ins/PepperFlashPlayer/PepperFlashPlayer.plugin' to remove.
2014-10-28 19:09:53 -0400 [I] IM: Did not find file '/Library/Internet Plug-Ins/Flash Player Enabler.plugin' to remove.
2014-10-28 19:09:54 -0400 [I] IM: Removed file: '/Library/Internet Plug-Ins/flashplayer.xpt'
2014-10-28 19:09:54 -0400 [I] IM: Did not find file '/Library/Internet Plug-Ins/PepperFlashPlayer/manifest.json' to remove.
2014-10-28 19:09:54 -0400 [I] IM: Did not find file '/Users/rdufresne50/Library/Internet Plug-Ins/Shockwave Flash NP-PPC' to remove.
2014-10-28 19:09:54 -0400 [I] IM: Did not find file '/Users/rdufresne50/Library/Internet Plug-Ins/Flash Player.plugin' to remove.
2014-10-28 19:09:54 -0400 [I] IM: Did not find file '/Users/rdufresne50/Library/Internet Plug-Ins/PepperFlashPlayer/PepperFlashPlayer.plugin' to remove.
2014-10-28 19:09:54 -0400 [I] IM: Did not find file '/Users/rdufresne50/Library/Internet Plug-Ins/Flash Player Enabler.plugin' to remove.
2014-10-28 19:09:54 -0400 [I] IM: Did not find file '/Users/rdufresne50/Library/Internet Plug-Ins/flashplayer.xpt' to remove.
2014-10-28 19:09:54 -0400 [I] IM: Did not find file '/Users/rdufresne50/Library/Internet Plug-Ins/PepperFlashPlayer/manifest.json' to remove.
2014-10-28 19:09:54 -0400 [I] IM: Removed file: '/Library/LaunchDaemons/com.adobe.fpsaud.plist'
2014-10-28 19:09:54 -0400 [I] IM: Removed file: '/Library/Application Support/Adobe/Flash Player Install Manager/fpsaud'
2014-10-28 19:09:54 -0400 [I] IM: Removed file: '/Library/Application Support/Adobe/Flash Player Install Manager/FPSAUConfig.xml'
2014-10-28 19:09:54 -0400 [I] IM: Did not find bundle receipt to remove.
2014-10-28 19:10:00 -0400 [I] IM: Removed file: '/Library/PreferencePanes/Flash Player.prefPane'
2014-10-28 19:10:00 -0400 [I] IM: Removed PrefPane preferences from within: ~/Library/Preferences/com.apple.systempreferences.plist
2014-10-28 19:10:00 -0400 [I] IM: [file removal end]
2014-10-28 19:10:00 -0400 [I] IM: [uninstall end]
2014-10-28 19:10:00 -0400 [I] IM: Uninstall Ended
2014-10-28 19:10:03 -0400 [I] IM: ---------- log end ----------
2014-10-28 19:10:54 -0400 [I] IM: ---------- log start ----------
2014-10-28 19:10:54 -0400 [I] IM: All install checks pass
2014-10-28 19:10:54 -0400 [W] IM: Unexpected umask value for process: 0
2014-10-28 19:10:54 -0400 [I] IM: User does not have any processes that need to be closed.
2014-10-28 19:10:54 -0400 [I] IM: [install started]
2014-10-28 19:10:56 -0400 [E] IM: [install failed: 1]
2014-10-28 19:10:56 -0400 [E] IM: Install failed with error code: 1.
2014-10-28 19:10:56 -0400 [I] IM: ---------- log end ----------
2014-10-28 19:14:18 -0400 [I] IM: ---------- log start ----------
2014-10-28 19:14:18 -0400 [I] IM: All install checks pass
2014-10-28 19:14:18 -0400 [W] IM: Unexpected umask value for process: 0
2014-10-28 19:14:18 -0400 [E] IM: User has 1 process that needs to be closed.
2014-10-28 19:14:18 -0400 [E] IM: Install failed with error code: 17.
2014-10-28 19:14:18 -0400 [I] IM: ---------- log end ----------
2014-10-28 19:14:27 -0400 [I] IM: ---------- log start ----------
2014-10-28 19:14:27 -0400 [I] IM: All install checks pass
2014-10-28 19:14:27 -0400 [W] IM: Unexpected umask value for process: 0
2014-10-28 19:14:27 -0400 [I] IM: User does not have any processes that need to be closed.
2014-10-28 19:14:27 -0400 [I] IM: [install started]
2014-10-28 19:14:28 -0400 [E] IM: [install failed: 1]
2014-10-28 19:14:28 -0400 [E] IM: Install failed with error code: 1.
2014-10-28 19:14:28 -0400 [I] IM: ---------- log end ----------
2014-10-28 19:16:54 -0400 [I] IM: ---------- log start ----------
2014-10-28 19:16:54 -0400 [I] IM: All install checks pass
2014-10-28 19:17:06 -0400 [I] IM: User does not have any processes that need to be closed before the Flash Player can be installed.
2014-10-28 19:17:06 -0400 [I] IM: [install started]
2014-10-28 19:17:07 -0400 [I] IM: [install completed]
2014-10-28 19:17:07 -0400 [E] IM: [install failed]
2014-10-28 19:17:22 -0400 [I] IM: ---------- log end ----------
2014-10-28 19:17:42 -0400 [I] IM: ---------- log start ----------
2014-10-28 19:17:42 -0400 [I] IM: All install checks pass
2014-10-28 19:17:50 -0400 [I] IM: User does not have any processes that need to be closed before the Flash Player can be installed.
2014-10-28 19:17:50 -0400 [I] IM: [install started]
2014-10-28 19:17:51 -0400 [I] IM: [install completed]
2014-10-28 19:17:51 -0400 [E] IM: [install failed]
2014-10-28 19:21:32 -0400 [E] RA: Unable to execute privileged task '/Library/Application Support/Adobe/Flash Player Install Manager/fpsaud'
2014-10-28 19:21:33 -0400 [I] IM: ---------- log end ----------
2014-10-28 19:22:01 -0400 [I] IM: ---------- log start ----------
2014-10-28 19:22:01 -0400 [I] IM: All install checks pass
2014-10-28 19:22:09 -0400 [E] IM: User has 1 process that needs to be closed before the Flash Player can be installed.
2014-10-28 19:22:18 -0400 [I] IM: [install started]
2014-10-28 19:22:19 -0400 [I] IM: [install completed]
2014-10-28 19:22:19 -0400 [E] IM: [install failed]
2014-10-28 19:22:21 -0400 [E] RA: Unable to execute privileged task '/Library/Application Support/Adobe/Flash Player Install Manager/fpsaud'
2014-10-28 19:22:21 -0400 [I] IM: ---------- log end ----------
2014-10-28 19:33:41 -0400 [I] IM: ---------- log start ----------
2014-10-28 19:33:42 -0400 [I] IM: All install checks pass
2014-10-28 19:33:54 -0400 [I] IM: User does not have any processes that need to be closed before the Flash Player can be installed.
2014-10-28 19:33:54 -0400 [I] IM: [install started]
2014-10-28 19:33:55 -0400 [I] IM: [install completed]
2014-10-28 19:33:55 -0400 [E] IM: [install failed]
2014-10-28 19:34:00 -0400 [E] RA: Unable to execute privileged task '/Library/Application Support/Adobe/Flash Player Install Manager/fpsaud'
2014-10-28 19:34:00 -0400 [I] IM: ---------- log end ----------
2014-11-05 20:25:32 -0500 [I] IM: ---------- log start ----------
2014-11-05 20:25:32 -0500 [I] IM: All install checks pass
2014-11-05 20:25:32 -0500 [W] IM: Unexpected umask value for process: 0
2014-11-05 20:25:32 -0500 [I] IM: User does not have any processes that need to be closed.
2014-11-05 20:25:32 -0500 [I] IM: [install started]
2014-11-05 20:25:36 -0500 [E] IM: [install failed: 1]
2014-11-05 20:25:36 -0500 [E] IM: Install failed with error code: 1.
2014-11-05 20:25:36 -0500 [I] IM: ---------- log end ----------
2014-11-06 08:45:06 -0500 [I] IM: ---------- log start ----------
2014-11-06 08:45:07 -0500 [I] IM: All install checks pass
2014-11-06 08:45:07 -0500 [W] IM: Unexpected umask value for process: 0
2014-11-06 08:45:07 -0500 [I] IM: User does not have any processes that need to be closed.
2014-11-06 08:45:07 -0500 [I] IM: [install started]
2014-11-06 08:45:09 -0500 [E] IM: [install failed: 1]
2014-11-06 08:45:09 -0500 [E] IM: Install failed with error code: 1.
2014-11-06 08:45:09 -0500 [I] IM: ---------- log end ----------
2014-11-06 08:47:06 -0500 [I] IM: ---------- log start ----------
2014-11-06 08:47:12 -0500 [I] IM: User does not have any processes that need to be closed before the Flash Player can be uninstalled.
2014-11-06 08:47:12 -0500 [I] IM: Uninstall Started
2014-11-06 08:47:12 -0500 [E] RA: Unable to execute privileged task '/Library/Application Support/Adobe/Flash Player Install Manager/fpsaud'
2014-11-06 08:47:12 -0500 [I] IM: [uninstall start]
2014-11-06 08:47:12 -0500 [I] IM: user authorized
2014-11-06 08:47:12 -0500 [I] IM: [file removal start]
2014-11-06 08:47:14 -0500 [I] IM: Did not find file '/Library/Internet Plug-Ins/Shockwave Flash NP-PPC' to remove.
2014-11-06 08:47:14 -0500 [I] IM: Did not find file '/Library/Internet Plug-Ins/Flash Player.plugin' to remove.
2014-11-06 08:47:14 -0500 [I] IM: Did not find file '/Library/Internet Plug-Ins/PepperFlashPlayer/PepperFlashPlayer.plugin' to remove.
2014-11-06 08:47:14 -0500 [I] IM: Did not find file '/Library/Internet Plug-Ins/Flash Player Enabler.plugin' to remove.
2014-11-06 08:47:14 -0500 [I] IM: Did not find file '/Library/Internet Plug-Ins/flashplayer.xpt' to remove.
2014-11-06 08:47:14 -0500 [I] IM: Did not find file '/Library/Internet Plug-Ins/PepperFlashPlayer/manifest.json' to remove.
2014-11-06 08:47:14 -0500 [I] IM: Did not find file '/Users/rdufresne50/Library/Internet Plug-Ins/Shockwave Flash NP-PPC' to remove.
2014-11-06 08:47:14 -0500 [I] IM: Did not find file '/Users/rdufresne50/Library/Internet Plug-Ins/Flash Player.plugin' to remove.
2014-11-06 08:47:14 -0500 [I] IM: Did not find file '/Users/rdufresne50/Library/Internet Plug-Ins/PepperFlashPlayer/PepperFlashPlayer.plugin' to remove.
2014-11-06 08:47:14 -0500 [I] IM: Did not find file '/Users/rdufresne50/Library/Internet Plug-Ins/Flash Player Enabler.plugin' to remove.
2014-11-06 08:47:14 -0500 [I] IM: Did not find file '/Users/rdufresne50/Library/Internet Plug-Ins/flashplayer.xpt' to remove.
2014-11-06 08:47:14 -0500 [I] IM: Did not find file '/Users/rdufresne50/Library/Internet Plug-Ins/PepperFlashPlayer/manifest.json' to remove.
2014-11-06 08:47:14 -0500 [I] IM: Did not find file '/Library/LaunchDaemons/com.adobe.fpsaud.plist' to remove.
2014-11-06 08:47:14 -0500 [I] IM: Did not find file '/Library/Application Support/Adobe/Flash Player Install Manager/fpsaud' to remove.
2014-11-06 08:47:14 -0500 [I] IM: Did not find file '/Library/Application Support/Adobe/Flash Player Install Manager/FPSAUConfig.xml' to remove.
2014-11-06 08:47:14 -0500 [I] IM: Did not find bundle receipt to remove.
2014-11-06 08:47:20 -0500 [I] IM: Removed PrefPane preferences from within: ~/Library/Preferences/com.apple.systempreferences.plist
2014-11-06 08:47:20 -0500 [I] IM: [file removal end]
2014-11-06 08:47:20 -0500 [I] IM: [uninstall end]
2014-11-06 08:47:20 -0500 [I] IM: Uninstall Ended
2014-11-06 08:47:24 -0500 [I] IM: ---------- log end ----------
2014-11-06 08:54:08 -0500 [I] IM: ---------- log start ----------
2014-11-06 08:54:08 -0500 [I] IM: All install checks pass
2014-11-06 08:54:08 -0500 [W] IM: Unexpected umask value for process: 0
2014-11-06 08:54:08 -0500 [I] IM: User does not have any processes that need to be closed.
2014-11-06 08:54:08 -0500 [I] IM: [install started]
2014-11-06 08:54:10 -0500 [E] IM: [install failed: 1]
2014-11-06 08:54:10 -0500 [E] IM: Install failed with error code: 1.
2014-11-06 08:54:10 -0500 [I] IM: ---------- log end ----------
2014-11-06 08:55:59 -0500 [I] IM: ---------- log start ----------
2014-11-06 08:56:08 -0500 [E] IM: User has 1 process that needs to be closed before the Flash Player can be uninstalled.
2014-11-06 08:56:21 -0500 [I] IM: Uninstall Started
2014-11-06 08:56:21 -0500 [E] RA: Unable to execute privileged task '/Library/Application Support/Adobe/Flash Player Install Manager/fpsaud'
2014-11-06 08:56:21 -0500 [I] IM: [uninstall start]
2014-11-06 08:56:21 -0500 [I] IM: user authorized
2014-11-06 08:56:21 -0500 [I] IM: [file removal start]
2014-11-06 08:56:22 -0500 [I] IM: Did not find file '/Library/Internet Plug-Ins/Shockwave Flash NP-PPC' to remove.
2014-11-06 08:56:22 -0500 [I] IM: Did not find file '/Library/Internet Plug-Ins/Flash Player.plugin' to remove.
2014-11-06 08:56:22 -0500 [I] IM: Did not find file '/Library/Internet Plug-Ins/PepperFlashPlayer/PepperFlashPlayer.plugin' to remove.
2014-11-06 08:56:22 -0500 [I] IM: Did not find file '/Library/Internet Plug-Ins/Flash Player Enabler.plugin' to remove.
2014-11-06 08:56:22 -0500 [I] IM: Did not find file '/Library/Internet Plug-Ins/flashplayer.xpt' to remove.
2014-11-06 08:56:22 -0500 [I] IM: Did not find file '/Library/Internet Plug-Ins/PepperFlashPlayer/manifest.json' to remove.
2014-11-06 08:56:22 -0500 [I] IM: Did not find file '/Users/rdufresne50/Library/Internet Plug-Ins/Shockwave Flash NP-PPC' to remove.
2014-11-06 08:56:22 -0500 [I] IM: Did not find file '/Users/rdufresne50/Library/Internet Plug-Ins/Flash Player.plugin' to remove.
2014-11-06 08:56:22 -0500 [I] IM: Did not find file '/Users/rdufresne50/Library/Internet Plug-Ins/PepperFlashPlayer/PepperFlashPlayer.plugin' to remove.
2014-11-06 08:56:22 -0500 [I] IM: Did not find file '/Users/rdufresne50/Library/Internet Plug-Ins/Flash Player Enabler.plugin' to remove.
2014-11-06 08:56:22 -0500 [I] IM: Did not find file '/Users/rdufresne50/Library/Internet Plug-Ins/flashplayer.xpt' to remove.
2014-11-06 08:56:22 -0500 [I] IM: Did not find file '/Users/rdufresne50/Library/Internet Plug-Ins/PepperFlashPlayer/manifest.json' to remove.
2014-11-06 08:56:22 -0500 [I] IM: Did not find file '/Library/LaunchDaemons/com.adobe.fpsaud.plist' to remove.
2014-11-06 08:56:22 -0500 [I] IM: Did not find file '/Library/Application Support/Adobe/Flash Player Install Manager/fpsaud' to remove.
2014-11-06 08:56:22 -0500 [I] IM: Did not find file '/Library/Application Support/Adobe/Flash Player Install Manager/FPSAUConfig.xml' to remove.
2014-11-06 08:56:22 -0500 [I] IM: Did not find bundle receipt to remove.
2014-11-06 08:56:27 -0500 [I] IM: Removed PrefPane preferences from within: ~/Library/Preferences/com.apple.systempreferences.plist
2014-11-06 08:56:27 -0500 [I] IM: [file removal end]
2014-11-06 08:56:27 -0500 [I] IM: [uninstall end]
2014-11-06 08:56:27 -0500 [I] IM: Uninstall Ended
2014-11-06 08:56:30 -0500 [I] IM: ---------- log end ----------
2014-11-06 09:02:12 -0500 [I] IM: ---------- log start ----------
2014-11-06 09:02:12 -0500 [I] IM: All install checks pass
2014-11-06 09:02:20 -0500 [I] IM: User does not have any processes that need to be closed before the Flash Player can be installed.
2014-11-06 09:02:20 -0500 [I] IM: [install started]
2014-11-06 09:02:21 -0500 [I] IM: [install completed]
2014-11-06 09:02:21 -0500 [E] IM: [install failed]
2014-11-06 09:02:25 -0500 [E] RA: Unable to execute privileged task '/Library/Application Support/Adobe/Flash Player Install Manager/fpsaud'
2014-11-06 09:02:25 -0500 [I] IM: ---------- log end ----------
2014-11-06 09:21:45 -0500 [I] IM: ---------- log start ----------
2014-11-06 09:21:45 -0500 [I] IM: All install checks pass
2014-11-06 09:22:01 -0500 [E] IM: User has 1 process that needs to be closed before the Flash Player can be installed.
2014-11-06 09:22:10 -0500 [I] IM: [install started]
2014-11-06 09:22:11 -0500 [I] IM: [install completed]
2014-11-06 09:22:11 -0500 [E] IM: [install failed]
2014-11-06 09:22:14 -0500 [E] RA: Unable to execute privileged task '/Library/Application Support/Adobe/Flash Player Install Manager/fpsaud'
2014-11-06 09:22:14 -0500 [I] IM: ---------- log end ----------
4. Re: New version of Flash won't install
Jeromie Clark Nov 6, 2014 4:45 PM (in response to papyrus100)On Yosemite, you may need to change your GateKeeper settings to Allow apps downloaded from Mac App Store and Identified Developers.
Also, are you running as Administrator or as a standard user? You may need to do the installation from an Administrator account.
5. Re: New version of Flash won't install
papyrus100 Nov 7, 2014 5:05 PM (in response to Jeromie Clark)Sorry Staff, but your comment are not great, and really not good. By default, Gatekeeper is adjusted to the settings you are mentioning. Furthermore, I am an Apple Certified Support Professional,... Your comments adds nothing to the thread that something is wrong with Flash, the current version and Yosemite.
6. Re: New version of Flash won't install
zm76 Nov 7, 2014 8:36 PM (in response to papyrus100)Not to mention that most of us turn the annoying Gatekeeper off. Does anyone on the support staff have any Macintosh experience at all? As is proven by all the evidence given, the fault is with the installer, not with our Macs. Please take your heads out of your rears and attempt to do something about this.
7. Re: New version of Flash won't install
Jeromie Clark Nov 8, 2014 12:39 PM (in response to papyrus100)We tested Flash Player extensively and are unable to reproduce the installation issue described.
If you boot into safe mode, does the installation complete?
8. Re: New version of Flash won't install
AB318 Nov 8, 2014 8:02 PM (in response to Jeromie Clark)No - you kindly suggested that on another thread and I tried it, but to no avail.
Please - it can't be this hard - can it? It was working one day (after I installed Yosemite) but the next it said Flash Player had expired - no choice to use the old version. Now I can't do the on-line course I've paid lots for because it uses flash player.
It is becoming more and more frustrating!
9. Re: New version of Flash won't install
Pat Willener Nov 8, 2014 8:11 PM (in response to AB318)It expired? Can you post a screenshot of that?
10. Re: New version of Flash won't install
AB318 Nov 8, 2014 8:50 PM (in response to Pat Willener)Sorry - I wouldn't know how to find it now. It was a message that came up on the screen when I was doing my course.
The website needed Flash Player and it said something along the lines of 'the version of Flash Player you are using has expired please download new version'. Since then I have totally uninstalled Flash Player as per instructions of many after the new version would not install properly.
I am using Chrome as an emergency method now but really prefer Safari.
11. Re: New version of Flash won't install
Pat Willener Nov 9, 2014 12:15 AM (in response to AB318)Apple instructed Safari to reject all previous Flash Player versions as "blocked plugin".
Did you try to install it using the offline installer that I posted earlier?
12. Re: New version of Flash won't install
AB318 Nov 9, 2014 3:27 AM (in response to Pat Willener)Yes I did that and it did exactly the same thing. I replied to the original post to that effect too.
It has been a few days and I heard no more from it so googled the problem again and found this thread.
Any further advice much appreciated!
Sent from my iPad
13. Re: New version of Flash won't install
Pat Willener Nov 9, 2014 8:25 PM (in response to AB318)It is possible that some remains of an older version are still somewhere on your system.
Uninstall Flash Player using http://helpx.adobe.com/flash-player/kb/uninstall-flash-player-mac-os.html then reinstall the latest version again.
14. Re: New version of Flash won't install
AB318 Nov 9, 2014 10:59 PM (in response to Pat Willener)Thanks for all your suggestions. I have run the Uninstaller at least twice now and tried the offline installer also.
I must admit to not being very 'technology savvy' but am doing my best.
Alex Bishop
15. Re: New version of Flash won't install
Jeromie Clark Nov 10, 2014 10:49 AM (in response to AB318)Safari blocklisted old Flash Player versions a week or two ago to ensure that all users picked up an important security change. They had an older version of Flash Player installed and hit the Safari blocklist dialog.
The installation logs provide some pretty good clues:
2014-11-06 09:22:10 -0500 [I] IM: [install started] installer: Must be run as root to install this package.
If you go to Control Panel > Users & Groups, there should be a list of users. Under the username that you're currently using, does it say "Admin" or "Standard" underneath?
In Control Panel > Security & Privacy, is Allow apps downloaded from Mac App Store and Identified Developers selected?
If the answer to both of those is "yes", and you're still stuck, what happens when you run the Beta installer?
http://labsdownload.adobe.com/pub/labs/flashruntimes/flashplayer/flashplayer15_install_mac .dmg
