1. Re: Movie frame turns black
LARV Oct 18, 2014 1:28 AM (in response to LARV)This problem is so bad now that it keeps happening after having reloaded several times and restarted both Edge and my computer. I´ve been working with this project for three days. There was no problem up untill today with the black movie screen, but it has happened before with other projects, but not like this. It seems the whole project is going in the trash because of this.
Edge staff, I NEED a solution this time. I´m paying for all these stupid bugs and errors.
2. Re: Movie frame turns black
LARV Oct 18, 2014 3:58 AM (in response to LARV)Now the whole project freezes on start-up. I don´t have the last update, so those errors probably shouldn´t affect this.
3. Re: Movie frame turns black
heathrowe Oct 18, 2014 11:36 AM (in response to LARV)Share your project files - it's hard to determine from your screenshot.
Darrell
4. Re: Movie frame turns black
LARV Oct 18, 2014 12:33 PM (in response to heathrowe)Sometimes the movie frame turns black, sometimes it doesn´t, and sometimes it makes Edge freeze on startup.
5. Re: Movie frame turns black
heathrowe Oct 18, 2014 5:21 PM (in response to LARV)You posted the published version!
Can you post the project version, including the .an file.
Darrell
6. Re: Movie frame turns black
LARV Oct 19, 2014 8:16 AM (in response to heathrowe)Here: http://adobe.ly/1sCQeSq
Two questions:
1. Why does the movie screen sometimes turn black when scrolling the timeline with movie autoplay on?
2. Why doesn´t the movie stop on the exact same movie frame everytime, and not always on the set pause?
7. Re: Movie frame turns black
LARV Oct 20, 2014 5:22 AM (in response to LARV)Heathrowe, did you (or anyone else) manage to see what the problems were?
If you couldn´t, I have to live with that, but I would appreciate if you could tell me even if you did not find anything.
Thank you.
8. Re: Movie frame turns black
heathrowe Oct 20, 2014 5:45 AM (in response to LARV)Apologies for the delay.
I do not see any black screen, of sorts - I scrubbed through and played it a few times. But it appears to run through as it should.
Darrell
10. Re: Movie frame turns black
heathrowe Oct 20, 2014 7:42 AM (in response to LARV)Have you tried using the Timeline Zooming slider feature (lower right) to help 'peg' the exact location you are looking for?
Darrell
11. Re: Movie frame turns black
LARV Oct 20, 2014 7:49 AM (in response to heathrowe)Yes, I have done that. It doesn´t help. The pause is not way off, but if I had used an animation that is faster, it would´ve be impossible to work with it in the manner that I did here. Which is a big draw back.
