1. Re: TOC button hidden when viewing responsive output in IE
Peter Grainge Oct 20, 2014 9:46 AM (in response to sockmonkey)I'm not seeing the problem using Theme 1 Standard and IE11.
Try some different images and in different formats. I used a PNG image.
2. Re: TOC button hidden when viewing responsive output in IE
sockmonkey Oct 20, 2014 2:37 PM (in response to Peter Grainge)Thanks for the response Peter.
I converted the image to a GIF and updated topic.slp to use that instead of the PNG (the WYSIWYG editor only accepts PNG) but unfortunately the issue persists in IE 10.
3. Re: TOC button hidden when viewing responsive output in IE
Peter Grainge Oct 21, 2014 12:24 AM (in response to sockmonkey)I can't check IE10 until later in the day but I now realise PNG is the correct format. Can you try a different PNG image?
4. Re: TOC button hidden when viewing responsive output in IE
sockmonkey Oct 23, 2014 10:17 AM (in response to Peter Grainge)Hi Peter,
After some more testing, it appears like this issue only occurs when viewing the responsive output in IE10 locally. After deploying the help to a test server, everything looks fine.
Thanks for your help with this.
